Dennis Jones
Joined: 17 Sep 2006 Posts: 45 Location: Poplar Grove, IL
Posted: Tue Jan 31, 2012 5:05 pm Post subject: Thermocouple leads |
I had to increase the length of the thermocouple leads to reach the data processing unit. All six cylinders show abnormally high temps. Could the increase in resistance cause the temperature increase?
berkut13(at)berkut13.com Guest
Posted: Tue Jan 31, 2012 5:54 pm Post subject: Thermocouple leads |
EGT or CHT?
How were they "extended"?
What type of thermocouple? (K, J, Resistive)
mrspudandcompany(at)veriz Guest
Posted: Tue Jan 31, 2012 5:55 pm Post subject: Thermocouple leads |
Dennis,
Did you use thermocouple wire for the extension?
Thermocouples generate a potential depending upon the temperature difference
from one end to the other. You must use proper procedure when extending
these wires.
Roger
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
3.51 KB |
Downloaded: |
562 Time(s) |
Dennis Jones
Posted: Tue Jan 31, 2012 8:33 pm Post subject: Re: Thermocouple leads |
Both CHT and EGT. They are thermocouple wire. I used the exact same wire as the equipment came with. I silver soldered the new lead extensions as shown by Bob. I do have a multimeter that will test thermocouple wire however I have not used that feature as of yet. The one test I have not attempted is the check of the indication without the engine running. My studies show that they should indicate ambient temperature.
jason(at)jasonbeaver.com Guest
Posted: Tue Jan 31, 2012 8:59 pm Post subject: Thermocouple leads |
Does anyone know if there are any issues in running EGT/CHT thermocouple wires along side the coax ignition leads from a Lightspeed Plasma II ignition (the lines between the ignition box and the coils)? My tech counselor said this could be a source of inaccuracy in the temperature reading.
thanks,
jason
On Jan 31, 2012, at 10:33 PM, Dennis Jones wrote:
http://forums.matronics.com/viewtopic.php?p=365354#365354
Posted: Wed Feb 01, 2012 6:27 am Post subject: Thermocouple leads |
I doubt it very much. The coax is double shielded
(electro-static coupling ZERO) and the currents
flowing in the center-conductor (outbound) exactly
compliment return currents flowing in the shield.
How much inaccuracy? You said they read high? All
read high by the same amount? Are your probes isolated
from engine ground or do they both electrically and
thermally connect to the engine? Does turning the
alternator on/off make any difference? Try turning
EVERYTHING on to make this test. Present the alternator
with the largest possibible load.
Posted: Wed Feb 01, 2012 7:08 am Post subject: Thermocouple leads |
I believe you are combining 2 questions from different
listers. One extended thermocouple wires and has a high reading and the
other is questioning if running thermocouple next to ignition wires causes
incorrect readings.
Roger
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
3.87 KB |
Downloaded: |
555 Time(s) |
Posted: Wed Feb 01, 2012 8:33 am Post subject: Thermocouple leads |
I'm not flying yet, so I have no way of testing. The tech counselor was just speculating that this could be a source of inaccurate readings.
Jason
On Feb 1, 2012, at 10:04 AM, "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net> wrote:
incorrect readings.
Roger
<winmail.dat>
Posted: Wed Feb 01, 2012 9:25 am Post subject: Thermocouple leads |
Okay, thanks for getting me back on track! Don't
worry about your wire routing.
tim2542(at)sbcglobal.net Guest
Posted: Wed Feb 01, 2012 10:22 am Post subject: Thermocouple leads |
On 2/1/2012 8:25 AM, Jason Beaver wrote:
Jason
Even if its off so what? You don't really care what the temps are, you
want to know the peak and then turn to your own set of beliefs re: LOP
or ROP operations.
You will be the one to drill the hole in your exhaust and where you put
it makes a tremendous difference in the actual temp.
CHTs different story of course.
tperry(at)lvtofly.com Guest
Posted: Wed Feb 01, 2012 10:59 am Post subject: Thermocouple leads |
If it a jpi, I have seen an improper ground cause all to read high. Make sure your instrument is grounded to the engine and not a ground bus inside.
Tim Perry
On Jan 31, 2012, at 11:33 PM, "Dennis Jones" <djones(at)northboone.net> wrote:
longg(at)pjm.com Guest
Posted: Wed Feb 01, 2012 11:25 am Post subject: Thermocouple leads |
I'll second that. On the Dynon an improper ground on 1 device/sensor can/will impact the reading on another. I used to have an old Cadillac which when you moved the electric seat the high beams flashed. They called it a feature.
Glenn
Posted: Wed Feb 01, 2012 5:54 pm Post subject: Thermocouple leads |
Glenn
Kudos Tim and Glenn. If the thermocouples are physically
welded to the bottoms of their thermowells . . . and they
often are . . . then what ever voltage difference that
exists between the crankcase and the instrument's ground
will ride on top of the thermocouple signals as a common
mode voltage.
All of thermocouple conditioning chips I've worked with
for the last 20 years have a considerable tolerance to
DC common mode interference but if the interference has
alternator ripple on it, it might be another matter. Hence
the questions about effects of alternator ON versus OFF.
It would also be a good experiment to run a temporary
instrument ground to the crankcase just to see if it
makes any difference.
james(at)etravel.org Guest
Posted: Thu Feb 02, 2012 2:00 am Post subject: Thermocouple leads |
Another "lightbulb" reply, thank you. I know I've read this in the Connection, but still, a reminder doesn't go amiss.
Is this effect mitigated by having a common ground on the firewall, with a braided strap to the engine? If the instruments are grounded to the forest of tabs, and that's only a short distance along a fat piece of copper to the engine...
James
On 1 February 2012 22:22, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
Quote: | --> AeroElectric-List message posted by: <longg(at)pjm.com (longg(at)pjm.com)>
Glenn
mode voltage.
ainut(at)knology.net Guest
Posted: Thu Feb 02, 2012 4:32 pm Post subject: Thermocouple leads |
That brings up a q that you might have answered in the original post:
Does each TC have it's own ground connected to it's own gauge? That is,
does each thermocouple supply two distinct lines to it's gauge? You
cannot use a common ground for each TC and only tie the signal wire to
the instrument.
David M.
Robert L. Nuckolls, III wrote:
Quote: |
<nuckolls.bob(at)aeroelectric.com>
> <jason(at)jasonbeaver.com>
Tell the truth. Be honest. Be responsible to and for yourself.
I liked America when it was free and it's people were responsible and had morals.
Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it.
Posted: Thu Feb 02, 2012 4:35 pm Post subject: Thermocouple leads |
Also, any (new) junction will create an inaccuracy unless you calibrate
with the total installation.
David M.
Jason Beaver wrote:
Jason
On Feb 1, 2012, at 10:04 AM, "ROGER& JEAN CURTIS"<mrspudandcompany(at)verizon.net> wrote:
> Bob . . .
> incorrect readings.
> Roger
> <winmail.dat>
Posted: Thu Feb 02, 2012 5:39 pm Post subject: Thermocouple leads |
At 06:01 PM 2/2/2012, you wrote:
calibrate with the total installation.
David M.
A set of thermocouple leads can have quite a few
extraneous junctions without affecting accuracy
as long as (1) current in the leads is very low
indeed approaching zero. Such is the case with most
modern thermocouple instruments using specialized
integrated circuits for thermocouple signal
conditioning. And (2) EACH junction needs to be
repeated in number and kind on both sides of the
thermocouple pair.
This is described in more detail here:
http://aeroelectric.com/articles/excerpt.pdf
millner(at)me.com Guest
Posted: Thu Feb 02, 2012 7:48 pm Post subject: Thermocouple leads |
Not exactly grue, David... if it's a chromel/chromel junction and a
alumel/alumel junction, there's no potential developed across it, so
nothing to calibrate out. If, for instance, someone inserts some
copper wire, you'll have chromel/copper and copper chromel junctions,
and assuming they're separated, and at different temperatures, that
temperature difference CANNOT be assumed to be constant... so there's no
way to calibrate it out.
So... either it doesn't matter, or it can't be known. No middle ground.
Paul
David M.
Hmmm, Bob... the physics doesn't support your assertion, unless you
(mistakenly I'd think) assume that all those junctions are somehow held
at the same temperature. And how would you accomplish that?
With the relatively common high impedance measuring devices, resistance
in the leads isn't really the issue... but adding uncontrolled junctions
at different temperatures can sure play havoc with accuracy.
Paul
thermocouple pair.
Please note my new email address!
millner(at)me.com
Posted: Thu Feb 02, 2012 8:04 pm Post subject: Thermocouple leads |
The OP didn't say whether he was using old style instruments or newer,
(more digital) ones.
David M.
> David M.
thermocouple pair.
