brubakermal(at)yahoo.com Guest
Posted: Wed Feb 15, 2012 6:08 pm Post subject: frunt mounted radiator |
I would like to remount a radiator in frunt of the starter (mag end)
anyone have a nice aftermarket supplier for my 582. I am also looking for a aftermufler for the stock mufler. mal
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Richard Pike
Posted: Fri Feb 17, 2012 9:03 am Post subject: Re: frunt mounted radiator |
Why do you want one at that end? I tried that the first year I had my MKIII, and noticed two things: if you were unable to take off as soon as you wanted, the engine would overheat, and it also seemed to hurt the rate of climb. I like having the radiator just ahead of the prop so that the temps stay normal while taxiing.
I do currently have a small radiator just in front of the air filter/silencer box to augment the main radiator that is behind and under the wing/in front of the prop, as the original was not quite enough in July & August. I can post pictures if you are interested.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
rickofudall
Posted: Fri Feb 17, 2012 11:07 am Post subject: frunt mounted radiator |
Richard, I have put the Honda Magna radiator on two Kolb Mk III's now. I have a 1/2 mile taxi when the wind is from the south and have never had an overheat situation with either airplane even in last summer's 115+ temperatures. If it was a problem, I think I'd have seen it by now. The Mark III has enough issue with in flow to the prop without putting a radiator right in front. The Magna radiator also has provision for a cooling fan if it was required, but so far there has been no need. I have had overheat issues with the stock Rotax radiators mounted in front of the engine and at the gearbox. That was what started me on the trail to a single radiator. That, and the expense.
Rick Girard
On Fri, Feb 17, 2012 at 11:03 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
| Quote: | --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
richard (at) bcchapel(dot)org
Kingsport, TN 3TN0
Now faith is the substance of things hoped for, the evidence of things not seen.
Hebrews 11:1
http://forums.matronics.com/viewtopic.php?p=366484#366484
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Posted: Fri Feb 17, 2012 1:21 pm Post subject: frunt mounted radiator |
Hi Rick,
Next time you're at the plane, would you mind getting some measurements? I'd like to know the face area & thickness of the core itself, and also the overall dimensions including the tanks (not including fittings, hoses, etc).
Charlie
On 02/17/2012 01:06 PM, Richard Girard wrote: [quote]Richard, I have put the Honda Magna radiator on two Kolb Mk III's now. I have a 1/2 mile taxi when the wind is from the south and have never had an overheat situation with either airplane even in last summer's 115+ temperatures. If it was a problem, I think I'd have seen it by now. The Mark III has enough issue with in flow to the prop without putting a radiator right in front. The Magna radiator also has provision for a cooling fan if it was required, but so far there has been no need. I have had overheat issues with the stock Rotax radiators mounted in front of the engine and at the gearbox. That was what started me on the trail to a single radiator. That, and the expense.
Rick Girard
Richard Pike
Kingsport, TN 3TN0
Hebrews 11:1
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
rickofudall
Posted: Sun Feb 19, 2012 9:46 pm Post subject: frunt mounted radiator |
Charlie, It's about 95.5 sq.in. (11 X 8.7) and the core is an inch thick. It's about 14 inches wide including the tanks.
Rick
On Fri, Feb 17, 2012 at 3:21 PM, Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)> wrote:
| Quote: | Hi Rick,
Charlie
| Quote: | Richard, I have put the Honda Magna radiator on two Kolb Mk III's now. I have a 1/2 mile taxi when the wind is from the south and have never had an overheat situation with either airplane even in last summer's 115+ temperatures. If it was a problem, I think I'd have seen it by now. The Mark III has enough issue with in flow to the prop without putting a radiator right in front. The Magna radiator also has provision for a cooling fan if it was required, but so far there has been no need.
Rick Girard
Richard Pike
Kingsport, TN 3TN0
Hebrews 11:1
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Posted: Mon Feb 20, 2012 6:28 am Post subject: frunt mounted radiator |
Many thanks!
On 02/19/2012 11:45 PM, Richard Girard wrote: [quote]Charlie, It's about 95.5 sq.in. (11 X 8.7) and the core is an inch thick. It's about 14 inches wide including the tanks.
Rick
| Quote: | Hi Rick,
Charlie
Rick Girard
Richard Pike
Kingsport, TN 3TN0
Hebrews 11:1
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
