		brubakermal(at)yahoo.com Guest
				 Posted: Wed Feb 15, 2012 6:08 pm    Post subject: frunt mounted radiator |
				I would like to remount a radiator in frunt of the starter (mag end)
 anyone have a nice aftermarket supplier for my 582. I am also looking for a aftermufler for the stock mufler.   mal
 Malcolm & Jeanne Brubaker
 Michigan Sport Pilot Repair
 LSRM-A, PPC, WS
 Great Sails - Sailmaker
 for Ultralight & Light Sport
 (989)513-3022
		Richard Pike
				 Posted: Fri Feb 17, 2012 9:03 am    Post subject: Re: frunt mounted radiator |
				Why do you want one at that end? I tried that the first year I had my MKIII, and noticed two things: if you were unable to take off as soon as you wanted, the engine would overheat, and it also seemed to hurt the rate of climb. I like having the radiator just ahead of the prop so that the temps stay normal while taxiing.
 I do currently have a small radiator just in front of the air filter/silencer box to augment the main radiator that is behind and under the wing/in front of the prop, as the original was not quite enough in July & August. I can post pictures if you are interested.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
		rickofudall
				 Posted: Fri Feb 17, 2012 11:07 am    Post subject: frunt mounted radiator |
				Richard, I have put the Honda Magna radiator on two Kolb Mk III's now. I have a 1/2 mile taxi when the wind is from the south and have never had an overheat situation with either airplane even in last summer's 115+ temperatures. If it was a problem, I think I'd have seen it by now. The Mark III has enough issue with in flow to the prop without putting a radiator right in front. The Magna radiator also has provision for a cooling fan if it was required, but so far there has been no need. I have had overheat issues with the stock Rotax radiators mounted in front of the engine and at the gearbox. That was what started me on the trail to a single radiator. That, and the expense.
 Rick Girard
 On Fri, Feb 17, 2012 at 11:03 AM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
  	  | Quote: | 	 		   --> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
  Richard Pike
  richard (at) bcchapel(dot)org
  Kingsport, TN 3TN0
  Now faith is the substance of things hoped for, the evidence of things not seen.
  Hebrews 11:1
  http://forums.matronics.com/viewtopic.php?p=366484#366484
  le, List Admin.
 Zulu Delta
 Mk IIIC
 Thanks, Homer GBYM
 It isn't necessary to have relatives in Kansas City in order to be unhappy.
    - Groucho Marx
				 Posted: Fri Feb 17, 2012 1:21 pm    Post subject: frunt mounted radiator |
				Hi Rick,
      Next time you're at the plane, would you mind getting some     measurements? I'd like to know the face area & thickness of the     core itself, and also the overall dimensions including the tanks     (not including fittings, hoses, etc).
      Charlie
      On 02/17/2012 01:06 PM, Richard Girard wrote:     [quote]Richard, I have put the Honda Magna radiator on two       Kolb Mk III's now. I have a 1/2 mile taxi when the wind is from       the south and have never had an overheat situation with either       airplane even in last summer's 115+ temperatures. If it was a       problem, I think I'd have seen it by now. The Mark III has enough       issue with in flow to the prop without putting a radiator right in       front. The Magna radiator also has provision for a cooling fan if       it was required, but so far there has been no need.                I have had overheat issues with the stock Rotax radiators         mounted in front of the engine and at the gearbox. That was what         started me on the trail to a single radiator. That, and the         expense.
          Rick Girard
                  Richard Pike
                  Kingsport, TN 3TN0
                  Hebrews 11:1
                  le, List Admin.
              Zulu Delta
              Mk IIIC
              Thanks, Homer GBYM
                      - Groucho Marx
		rickofudall
				 Posted: Sun Feb 19, 2012 9:46 pm    Post subject: frunt mounted radiator |
				Charlie, It's about 95.5 sq.in. (11 X 8.7) and the core is an inch thick. It's about 14 inches wide including the tanks.
 Rick
 On Fri, Feb 17, 2012 at 3:21 PM, Charlie England <ceengland(at)bellsouth.net (ceengland(at)bellsouth.net)> wrote:
   	  | Quote: | 	 		                     Hi Rick,
      Charlie
  	  | Quote: | 	 		  Richard, I have put the Honda Magna radiator on two       Kolb Mk III's now. I have a 1/2 mile taxi when the wind is from       the south and have never had an overheat situation with either       airplane even in last summer's 115+ temperatures. If it was a       problem, I think I'd have seen it by now. The Mark III has enough       issue with in flow to the prop without putting a radiator right in       front. The Magna radiator also has provision for a cooling fan if       it was required, but so far there has been no need.
 Rick Girard
                  Richard Pike
                  Kingsport, TN 3TN0
                  Hebrews 11:1
                  le, List Admin.
              Zulu Delta
              Mk IIIC
              Thanks, Homer GBYM
                      - Groucho Marx
 Zulu Delta
 Mk IIIC
 Thanks, Homer GBYM
    - Groucho Marx
				 Posted: Mon Feb 20, 2012 6:28 am    Post subject: frunt mounted radiator |
				Many thanks!
      On 02/19/2012 11:45 PM, Richard Girard wrote:     [quote]Charlie, It's about 95.5 sq.in. (11 X 8.7) and the core is an       inch thick. It's about 14 inches wide including the tanks.
        Rick
             	  | Quote: | 	 		                Hi Rick,
                Charlie
                    Rick Girard
                              Richard Pike
                              Kingsport, TN 3TN0
                              Hebrews 11:1
                            le, List Admin.
                            Zulu Delta
                            Mk IIIC
                            Thanks, Homer GBYM
                                    - Groucho Marx
          Zulu Delta
          Mk IIIC
          Thanks, Homer GBYM
