GRT Panel Layout
Goto page Previous  1, 2, 3  Next
Tim Olson
PostPosted: Fri May 25, 2012 6:12 am    Post subject: GRT Panel Layout Reply with quote
I'd agree with that...it really depends. There are many times in the
summer that you'll get lines of stuff or many splotches scattered,
of popup cells. (Lines are usually worse) I've found that it's
usually best to stay VFR on those days....save the IFR for layers
and for wide areas of rain. So you stay VFR, but you end up
flying surprisingly nice air weaving between all of the buildups.
I am careful not to get where there are clouds overhead, because
then you have no idea what's above you that could fall (hail)
out of the cloud. But I've had many trips where I had to
weave through buildups to get places, and it didn't feel
especially dangerous at all. At the same time, I don't think
lightning would be likely to jump out to where I was either.
But, I think if you're flying IFR through rain clouds, you'd
have more worry about lightning even if it's only mildly
convective, and probably what's more of a concern than lightning
is P-static. You'll be far more likely to be affected by
P-static flying IFR than lighting, because as Thane States states
(fun to say) you probably will be avoiding the convective
stuff as much as possible anyway, and definitely you'll be
staying out of the worrysome convective stuff.
On my screens, I've found Green is usually good, yellow
is usually doable, and with WSI at least, it's been
pretty darn accurate with minimal delay, so easy
to navigate past. Red, is bad (or so I'd think), but I've
never flown through it to find out.
On 5/25/2012 8:32 AM, Jesse Saint wrote:
[quote] I guess that depends on how you define "anywhere near". Flying through a
thunderstorm is not wise, but flying near one is often necessary,
especially on a typical Florida summer day.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org>
www.mavericklsa.com <http://www.mavericklsa.com>
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On May 25, 2012, at 8:36 AM, "Thane States" <thane2(at)comporium.net
<mailto:thane2(at)comporium.net>> wrote:
> Just my opinion, but if you are anywhere near lightning, then you are
> taking added risk that is unnecessary. Where there is lightning there
> is way to much convective activity. I would never put my family in
> that scenario. With all those fancy avionics you can avoid WX like
> that. Just my 2 cents. Great loking panel, I love my GRT.
> Thane
jesse(at)saintaviation.co
PostPosted: Fri May 25, 2012 8:48 am    Post subject: GRT Panel Layout Reply with quote
My point exactly. I actually have seen lightning as much as about 5nm (estimated) away from the CB clouds when skirting a squall line before, but if you look at a NEXRAD and Strikes overlay, the strikes are almost exclusively in the red. I fly through green as often as necessary, yellow to avoid huge detours, and NEVER red. I don't mind flying through building clouds with tops up to maybe 12,000-15,000 ft or so, but avoid towering cumulous much above that. I also try to avoid flying under that stuff for the same reasons and because it's usually pretty bumpy, although sometimes its necessary for takeoff and landing. I would certainly much sooner go high and pick my way between the tops before going under to get past a line.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
dave.saylor.aircrafters(a
PostPosted: Fri May 25, 2012 9:08 am    Post subject: GRT Panel Layout Reply with quote
This is a great discussion for me since the only weather we ever
really see at home is fog. Since I don't have much T-storm
experience, I was told to give them 20 miles. Is that too
conservative?
Along the same lines, there's a line of reasoning that says that EFIS
should be backed up with spinning gyro instruments. Gyros would
theoretically be less susceptible to a lightning strike or other major
electrical issue. I have a D-10A as my backup, and I'm starting to
wonder about it. We're designing a panel as I type and I'm
considering going with a turn coordinator, airspeed, altimeter, and
wet compass as the mechanical backups. I'm thinking that most of us
did some partial panel training with a failed attitude indicator, and
using the remaining "five-pack" works OK. Not great, but OK, and
maybe the TC will be a little more reliable than an electric attitude
indicator. I haven't had great luck with them.
I'm interested in what you all think about that scheme.
Dave Saylor
831-750-0284 CL
On Fri, May 25, 2012 at 9:40 AM, Jesse Saint <jesse(at)saintaviation.com> wrote:
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
> Tim
dlm34077(at)q.com
PostPosted: Fri May 25, 2012 9:28 am    Post subject: GRT Panel Layout Reply with quote
Don't know how the EFISs hold up with lightning, however, I did
inadvertently (during an O sh*t moment) short an Odyssey 680 to ground via a
Chelton IDU case with no ill effect. The Cheltons can be installed in
certified aircraft so I believe they have been tested in adverse conditions.
Tim Olsen may know more.
carl.froehlich(at)verizon
PostPosted: Fri May 25, 2012 10:13 am    Post subject: GRT Panel Layout Reply with quote
I ratcheted though this thought process awhile back and ending up firmly on the "no spinning gyro" answer.
I started with a very expensive RC Allen electric AI in my 8A. It started to go south at 200 hours and I had to pull it shortly thereafter. I now have a Dynon D10A in its place that been flawless for the last 500+ hours. This set the stage for my choice of a dual SkyView EFIS install (with primary and back up ADHRS) in the RV-10. Considering my experience and others I have engaged, the reliability of dual EFIS and dual ADHRS far exceeds that of spinning gyros.
Note however that I have taken steps to mitigate against electrical failure from taking down both EFIS systems. If you have a single power distribution scheme and don't want to change it, then vacuum gyros may be the way to go.
Also of note, while the FARs state you must have a "magnetic heading reference", this has been interpreted by the Washington FSDO office as a wet compass. They did not wish to justify that policy, but since I wanted them to sign off my plane I decided not to push the point (and I got the sign off last Wednesday!).
Carl
robin(at)PaintTheWeb.com
PostPosted: Fri May 25, 2012 10:34 am    Post subject: GRT Panel Layout Reply with quote
Carl,
Congratulations on your sign off.
Do you consider the dedicated back up battery for the Dynon to be part of what you describe as a " single power distribution scheme"? I have a triple battery system. Primary & backup for all electronics and then the dedicated back up battery for my D100. Seems like enough redundancy?
Robin
Tim Olson
PostPosted: Fri May 25, 2012 10:40 am    Post subject: GRT Panel Layout Reply with quote
In reading Jesse's follow up post, I think he and I approach it
basically the same. Having lightning strike data is awesome.
You then know you have a very convective and strong cell or line.
So, I avoid where the strikes are, and use that as part of
my plan as I weave around. Also, tops. If the tops are
calling 20K' or so, I know they're going to be big. I don't
want to fly through that, even if it's not red and I'm on
an IFR plan. To me, bumps are never fun. Also, even when you're
only looking at 10,000' tops, when you fly through them you
often hit a bump as you enter and get bumped around inside...but
if you stay out of the visible cloud, you get a smoother ride.
As you talk about fog, I think that is really the better IFR
conditions. The downside is that fog is often to the ground.
Where I live, we often get PERFECT IFR type conditions for fun.
500'-2000' ceilings of stratus layers, where you can get on
top. That's the kind of IFR I don't mind. I don't want
to mess with IFR if it's convective. Under it isn't fun,
but I'll go under if the tops aren't high. But if they're
higher buildups, I use my WX equipment to get me AROUND the
weather. I wouldn't file IFR if I can go VFR easily,
because then I can deviate all I want without requests.
I'd be happy to go VFR Flight Following or IFR, but only
if they're happy to give me the leeway to make course changes
every 10-20 miles so I can weave around. Convective buildups
just aren't good for flying in...and by using that as my
concept in a plan, it really helps keep you out of trouble
somewhat. The times it bites is if the widely scattered
clouds turn into broken, and you have a harder time maintaining
ground contact...when that sneaks up on you, you're better
off having been or being on an IFR plan already so you
can plug along...but plan on making deviations.
As far as 20nm being too conservative, I would not be able to
say that is true. I think the 20nm recommendation is a
healthy safety margin and think it's good to promote it
as such. The fact is though, that it can really depend.
If you're talking buildups that aren't precipitating,
you can basically just fly right by them. If they're
precipitating, then you have to pay close attention.
Are there lighting strikes? What are the tops? What
colors do you see....Red? Pink? These are indicators
of it being pretty nasty inside. Those are best to
avoid by as much as you can. 20nm though is sometimes
not workable if there are lots of small separate cells,
so you either have to land, deviate, or come up with
some other plan. For me, part of the key is what
you will be flying directly underneath. They want you
to keep 20nm away because stuff comes out of those
clouds. Lightning can reach out a little ways as Jesse
said. Hail can lift up and fall out around it too.
But, if you are able to keep perfectly blue skies above
your head, 20nm can be more than you need. This isn't
saying the recommendation isn't good. It just may be
that you can do closer without too much concern.
Check out this really awful screenshot:
http://www.myrv10.com/N104CD/Trips/2011_East_Coast/RV20110611160341.html
Notice all the areas where there is NOTHING, but suddenly
an intense yellow area with red...some were really
strong. But, they were all over heck...and in my way.
Well, IFR, I would have probably packed it in for the
day and landed. But, since it was daylight and I was
VFR, and could see out the window fine, I got to play
ball.
Here is a picture out the window:
http://www.myrv10.com/N104CD/Trips/2011_East_Coast/RV20110611163547.html
Notice the overhang on the cloud cell. But, I'm in clear skies.
My goal at that time was to A) keep ground contact by flying
in the valleys between anything big. B) Keep OUT from that
overhanging cloud. As long as I could keep a couple miles
out under perfect blue skies, it was a good ride. I didn't
want any hail falling on me, and I didn't see any lightning.
I was closer than 20 miles, but wasn't close enough that
we would be affected by the cloud.
Now going further along the trip, here's another screenshot near
that area.
http://www.myrv10.com/N104CD/Trips/2011_East_Coast/RV20110611164520.html
Here's the view out the window:
http://www.myrv10.com/N104CD/Trips/2011_East_Coast/RV20110611164500.html
You can see that the gap between the cells may have been 20 miles
or so, but there was nothing overhanging the cell, and it was
visibly clear above me, and I was far enough from the cells that
we had no effect. This was closer than I'd have wanted, and
you know darn well I was watching very very close keeping
track of the ground, the weather on the OTHER side of the gap
(could something build up and block me from continuing?), and
what the conditions were. This wasn't a time for IFR, and I'd
have been causing ATC a pain in the butt with VFR flight following.
But as long as I was in clear skies, no overhead clouds, and
it was a smooth ride, it was easily doable. For someone
not used to flying around that stuff, might be best to ease
into it...but we get that all the time up here.
To show you a picture of a day that will make you pull your hair
out, check this one out:
http://www.myrv10.com/N104CD/flights/20090819/RV20090814160153.html
It came from this write-up, btw:
http://www.myrv10.com/N104CD/flights/20090819/index.html
The funny thing is, by staying VFR and knowing exactly
what you were flying in, it was doable. Again, if you're not
from an area that has these conditions, it's worth easing
into it. But, the trip actually went well.
From a different trip, this pic shows something easy to go through:
http://www.myrv10.com/N104CD/flights/20080901/SD200809012686.html
So it all depends on a lot of factors, really. There are times
when 20nm will be a very good yardstick. Each situation is
different.
Although I don't have a spinning gyro, if you fly IFR,
I would say that would be your BEST way to go for a backup.
Would be nice to be lightning proof and p-static proof,
and everything else. So, while I don't have that in
my plane, I do think that's the best way to go. Having another
EFIS as a backup really is an inferior backup...and anyone
that believes otherwise is just being defensive and not
owning up to reality. I don't have a spinning gyro in
my plane, so yes, with that statement made, it's deficient.
That's not a slam on y'all, either. I'm just saying that
if you're flying IFR, it's BEST to have a spinning gyro backup.
There are downsides to it too, especially from a maintenance
perspective...but it would be the best choice. Something
that can't get taken out by lightning, doesn't use software,
and can keep you upright with no electricity.
Anyway, weather is a pretty interesting subject to talk about,
because opinions vary, even looking at the same cloud.
My major concern is I want smooth air, no hail, no lightning,
and to get where I'm going.
conservative?
Dave Saylor
831-750-0284 CL
On Fri, May 25, 2012 at 9:40 AM, Jesse Saint<jesse(at)saintaviation.com> wrote:
> Jesse Saint
> I-TEC, Inc.
> www.itecusa.org
> www.mavericklsa.com
> C: 352-427-0285
> O: 352-465-4545
> F: 815-377-3694
> Sent from my iPhone
>> Tim
Mauledriver(at)nc.rr.com
PostPosted: Fri May 25, 2012 10:44 am    Post subject: GRT Panel Layout Reply with quote
I'm no expert but living in the SE, convection, cumulus, and T-storms
are almost daily occurences in the summer somewhere along your trip.
Twenty miles just won't let you get anywhere in this part of the country.
Here in the SE, getting up as high as you can w/o O2 will usually allow
you to fly among the tops. Even if they aren't raining or lightening
(yet), it's best to stay out of them unless you can clearly see what's
going on the other side and if don't mind being bumped around.
Controllers issue deviations freely... especially where and when you
need them most, e.g. JAX center in FL.
For short flights, it's often equally effective to stay below cloud base
and just fly around the rain shafts. But this depends on having a clear
look at the buildups on top of the rain shafts. If it's overcast and
convective (imbedded storms), that just doesn't work whether you stay
below or fly in the clouds. Even with Nexrad, there's no reason to be
flying around or underneath imbedded convective storms in my opinion.
I would say no one purposely goes into a convective storm anymore
including the airlines. But there's a lot of very informed flying
around them these days. I guess the big guys all have radar and Nexrad
and most of us little guys have Nexrad (and before that Cheap Bastard).
It works very well... especially if you stay visual.
Coming home last week I was flying between big buildups north of
Charlotte at 11k. Staying visual forced me towards a waypoint that all
the traffic in the KCLT seemed to be crossing at 11k. Sure enough, it
was on a commonly used STAR. I listened to plane after plane ask for
deviations as they came into the waypoint, but then they'd cross it and
proceed in. I was forced to ask for the same treatment but the
controllers didn't want me crossing the arrival point along with the
airliners, especially at a 90degree angle to the other traffic. I told
them I could stay 3 miles away from it and still get thru the break in
the buildups and that seemed to work for them. Funny thing is that I
never saw another plane during the passage (and my ADS-B was only
showing some of the storm and no traffic at that moment). But I ended
up flying less than a mile away from the buildups as I squeezed thru.
There were occassional flashes and it was clearly raining below them but
they were slow builders with almost no movement and it turned out fine.
For me, the key is staying visual on convective days but I will fly
close to buildups depending on how stuff looks. Sometimes you get
surprised a bit as I did out in AZ recently. Things are bigger,
higher, and faster out there and I still need to calibrate my eyeballs a
bit better for western conditions.
Bill "a thunderstorm is just a grown up thermal having a tantrum" Watson
conservative?
dlm34077(at)q.com
PostPosted: Fri May 25, 2012 10:48 am    Post subject: GRT Panel Layout Reply with quote
I too have a wet compass; my IFR solution is a Chelton systen EFIS as
primary; a GRT Sport as backup which is powered by either the primary or
esential busses and a Trutrak Digiflite AP (on the primary buss) with its
own internal solid state gyros. Any of three systems can be used to keep te
dirty side down. The AP source can be selected by rotary switch so that the
Cheltons, the GRT or the AP provide flight control.
dlm34077(at)q.com
PostPosted: Fri May 25, 2012 11:07 am    Post subject: GRT Panel Layout Reply with quote
Back when I flew hard IFR, the thing that was most helpful was the Strikefinder. Those were the days when some federal judge "found" that digital and analog technologies were patent infringing. With some effort one was installed and the aircraft was flown where the lightning strikes were not. Smooth ride even though the rain was so heavy that water came in the doors. The delay in the Sat WX processing seems to cause some confusion about where not to fly. Looking forward to ADS-B install and FAA installation completion. I will still be wary the delay. Fog is not a problem; usually smooth ride but LIFR conditions.
PostPosted: Fri May 25, 2012 11:36 am    Post subject: GRT Panel Layout Reply with quote
I have two Odyssey PC-625 batteries and one 60amp Plane Power alternator. I
am not using the Dynon back up battery as it is redundant in my install.
There are several ways to design a power distribution to guard against a
single failure taking out the whole panel. When doing this, one should
consider not just the individual component reliability, but overall system
reliability. There was a article a few years back in one of the magazines
about a twin engine plane having total electrical failure at night. This
was a standard spam can with two alternators and two batteries. The failure
was a common connection that failed (high resistance contact). A simple
example of this concept is the use of an "Avionics Master" switch. It fails
and you have no panel no matter how many batteries and alternators you have.
For those interested I can send you what I did in Power Point slides off
line.
Carl
PostPosted: Fri May 25, 2012 11:41 am    Post subject: GRT Panel Layout Reply with quote
I don't think the concerns are so much running out of power as they
are having some kind of other major electrical spasm take out several
screens at once. Lightning and static come to mind, but maybe there's
something else.
In 1000 hours we've had one gyro failure of the Dynon, one internal
power supply failure that blanked the AFS EFIS, an knob failure that
hobbled the AFS, three failures of a 696 that required return to the
factory, and an intermittent failure of our 530W that needed return to
the factory. All these happened at different times and didn't affect
one another. That is, any of these failures wouldn't have been
catastrophic in IMC. But with so many different kinds of failures,
all with plenty of power on board, it just kind of seems like a matter
of time until the blank screens overlap.
What do you guys thinks about staying level with mechanical airspeed,
altitude, compass, and TC? Without an attitude indicator? I don't
recall having too hard a time with that during IFR training, and I'm
far from SuperPilot.
Dave Saylor
831-750-0284 CL
On Fri, May 25, 2012 at 11:11 AM, Carl Froehlich
Carl
Strasnuts
PostPosted: Fri May 25, 2012 11:46 am    Post subject: GRT Panel Layout Reply with quote
Well said.
Satellite weather is great for big picture and preflight planning. Picking your way through is done with on board radar and a strike finder/stormscope,which of course we don't have in a ten unless someone has installed one. Not many of us in a ten should be picking our way through I guess.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
jchang10
PostPosted: Fri May 25, 2012 11:59 am    Post subject: GRT Panel Layout Reply with quote
Great write-up Tim with pictures and all! I can't imagine anyone
purposefully flying into those kinds of build-ups, at least not twice,
anyway.
Out here in CA, can you believe lots of people have never ever seen a
heavy thunderstorm or even seen or heard lightning before? It is such a
rare event here, it is kind of amusing.
Jae
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
#40533 RV-10
dlm34077(at)q.com
PostPosted: Fri May 25, 2012 1:04 pm    Post subject: GRT Panel Layout Reply with quote
Another possible solution. If its really bad and you are going, you can sometimes follow the airlines since they have the equipment. I was setting in the aircraft at the Cessna factory one stormy night and contacted ICT approach to go to KICT to spend the night instead of flying to KTUL. As I talked with the controller I heard him vectoring a B727 toward KTUL at 6000msl. I said. Can I have one of those? Sure! Cleared as filed! I followed the track of the Boeing to KTUL.
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Bill Watson
Sent: Friday, May 25, 2012 11:43 AM
Subject: Re: Re: GRT Panel Layout
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com>
I'm no expert but living in the SE, convection, cumulus, and T-storms are almost daily occurences in the summer somewhere along your trip.
Here in the SE, getting up as high as you can w/o O2 will usually allow you to fly among the tops. Even if they aren't raining or lightening (yet), it's best to stay out of them unless you can clearly see what's going on the other side and if don't mind being bumped around.
Controllers issue deviations freely... especially where and when you need them most, e.g. JAX center in FL.
For short flights, it's often equally effective to stay below cloud base and just fly around the rain shafts. But this depends on having a clear look at the buildups on top of the rain shafts. If it's overcast and convective (imbedded storms), that just doesn't work whether you stay below or fly in the clouds. Even with Nexrad, there's no reason to be flying around or underneath imbedded convective storms in my opinion.
I would say no one purposely goes into a convective storm anymore including the airlines. But there's a lot of very informed flying around them these days. I guess the big guys all have radar and Nexrad and most of us little guys have Nexrad (and before that Cheap Bastard).
Coming home last week I was flying between big buildups north of Charlotte at 11k. Staying visual forced me towards a waypoint that all the traffic in the KCLT seemed to be crossing at 11k. Sure enough, it was on a commonly used STAR. I listened to plane after plane ask for deviations as they came into the waypoint, but then they'd cross it and proceed in. I was forced to ask for the same treatment but the controllers didn't want me crossing the arrival point along with the airliners, especially at a 90degree angle to the other traffic. I told them I could stay 3 miles away from it and still get thru the break in the buildups and that seemed to work for them. Funny thing is that I never saw another plane during the passage (and my ADS-B was only showing some of the storm and no traffic at that moment). But I ended up flying less than a mile away from the buildups as I squeezed thru.
There were occassional flashes and it was clearly raining below them but they were slow builders with almost no movement and it turned out fine.
For me, the key is staying visual on convective days but I will fly close to buildups depending on how stuff looks. Sometimes you get
higher, and faster out there and I still need to calibrate my eyeballs a bit better for western conditions.
--> RV10-List message posted by: Dave
--> Saylor<dave.saylor.aircrafters(at)gmail.com>
Navigator much much href="http://www.matronics.com/Navigator?RV10-List">http://www.matronicp; the Web href="http://forums.matronics.com">http://forums.matronics.com
_p; generous bsp;   href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
PostPosted: Fri May 25, 2012 3:21 pm    Post subject: GRT Panel Layout Reply with quote
I feel the same way about most of what Tim said except one thing. If I'm going more than 50nm or so, I file IFR. It's probably because of where I live, with Orlando, Tampa, Jacksonville, Atlanta, etc airspace involved in most of my flights, as well as military airspaces everywhere. I find it easier to start IFR and ask for deviations than to go VFR and risk getting caught in IMC. I often hear ATC pointing out areas of moderate to extreme precipitation and giving me 10-20 degrees left or right of course long before I ask for them. When I ask for them they almost always give them. I also sometimes have to play the card, "I'll just cancel and go VFR" to get them to give me the needed deviation. It seems they would much rather shuffle things a little bit with a known quantity than to have VFR traffic that may turn any direction at any time. I will not fly into big CB clouds, but if I know I'm going to only be in it and bumping for 10-20 seconds, I'll stay on course. Otherwise I would be zig-zagging like crazy on a typical summer day. 20nm from CB is nice, but is often not an option, as Tim mentioned.
Sorry if this was a little scatterbrained, but I just woke up from a nap after driving from Fl to Indy almost nonstop. Yes, I actually drove. The -10 is a little tight for 8, even if 7 of them are small. Who does my cousin think he is, getting married to a girl that isn't from Florida?!
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
ball.
that area.
different.
> conservative?
> Dave Saylor
> 831-750-0284 CL
>> Jesse Saint
>> I-TEC, Inc.
>> www.itecusa.org
>> www.mavericklsa.com
>> C: 352-427-0285
>> O: 352-465-4545
>> F: 815-377-3694
>> Sent from my iPhone
>>> Tim
PostPosted: Fri May 25, 2012 3:58 pm    Post subject: GRT Panel Layout Reply with quote
I have a different view, though it may be ill informed because I have
flown with neither radar or a strikefinder.
I've found what I'll call "nexrad" weather displays, whether from XM or
ADS-B, to be outstanding tools for picking my way thru storms. To be
clear, I'm not talking about flying in IMC and trying to pick my way
thru soft spots. I am talking about flying IFR but mainly staying
visual when near storms and using the slightly delayed Nexrad images,
along with altitude, to avoid storms and move towards my destination.
This works very well for me in typical spring/summer/fall conditions on
the east coast, particularly the in the south east. It doesn't really
work VFR because it's too difficult to get up over cloud base and too
risky getting trapped above an undercast.
As stated, Nexrad works best in getting the big picture but it also
works quite well in seeing any area of precipitation and can be used
quite effectively in tactical storm avoidance.
At times, Nexrad in the cockpit is superior to radar. I've listened
while the jets were trying to figure out where and how to penetrate a
line when I could see quite clearly on my G396 that an end-around would
work just fine. Radar just can't see around corners. Having said
that, I'm sure based on what I've been told that you can't beat radar in
most situations. I'm also under the impression that the jet crowd now
universally has Nexrad either in the newer panels or on a portable that
they never leave home without.
In FL where the daily buildups can be both big and numerous, the trick
is often just knowing whether to deviate left or right around the next
cloud so you don't get boxed in by 2 or 3 others on the other side.
When I was flying with the elegant pre-396 Cheap Bastard product
(involving an unholy alliance between a Palm pilot, an RF network, VOR
locations, and a rogue server somewhere) it was a revelation for both
the JAX controllers and I when I was able to correctly ask for the best
deviation in my little Maule, "How did you know that, do you have radar
in that thing?". 30 to 45 mins old Nexrad images were worth their
weight in gold when dealing with (Indy) controllers who often don't have
time for vector advice.
Where Nexrad-only may not work well is when closing in on a
destination. If the storms and the clouds go right down to <1000 AGL
like they often do in FL, you may not be able to stay visual while
getting to the airport. A 10 minute old Nexrad image is not the best
tool to penetrate with. Best to go somewhere else and wait it out. If
you can get under it in the clear, then you can use the Nexrad and your
eyeballs to assess the situation and hopefully get to the destination.
If you stay out of the buildups, then it seems to me only 2 things can
really ruin your day; lightning and hail. I know what hail can look
like and I try not to ever see that sight again. Lightning I don't
understand but I feel safer in the air than standing around on the airport.
After several steps forward (Cheap Bastard, XM on the 396, XM on the
GRT) I feel like I've taken a step backwards with ADS-B on the GRT.
When it's there, it's as good as the XM on the GRT. But it's not always
there (out west) and is frustratingly sporadic at the darndest times
(Asheville NC during storms).
Anyway, that's my experience so far,
Bill Watson
Tim Olson
PostPosted: Fri May 25, 2012 5:28 pm    Post subject: GRT Panel Layout Reply with quote
I've been trying to make that point over and over, but most people
can't see past the $dollar signs$. ADS-B is AWESOME to add to
a panel for traffic. (Bested of course by active traffic) It's
also fantastic to have for WX for "free". But, I would not want
it as my ONLY WX. For the RV-10, which is a serious X/C machine,
you want more serious WX if you travel X/C a lot. You will
NOT get coverage everywhere, even when it's fully rolled out.
You will also NOT get coverage down low in some spots. There
will be areas in the US where you need to be >5000'AGL to get
coverage, or more. That means you can't sit on the ramp in
a large percentage of airports and see if that storm bearing
down on you is close, or what it's doing. That means that
you often will have to launch into iffy skies, only knowing
what you either A) have on your ipad right now, or B) saw
in the FBO when you were there (if they were open).
For me, that's a deal breaker. It's worth the $30-50/mo to
get my WSI Wx as my primary WX. It's also well worth it to
have it on my PRIMARY instruments. ADS-B WX would be a great
addition for an iPad, or for your secondary EFIS if you have
one. May as well outfit with it with the price as low as it
is. But it is not, and never will be, a substitute for
satellite based weather products.
Tim Olson - RV-10 N104CD
PostPosted: Fri May 25, 2012 7:49 pm    Post subject: GRT Panel Layout Reply with quote
I too am a bit blinded by the $$. Will have to re-think this.
Yesterday I ran over to a close by airport (30 miles) to do a radio
swap. Had to avoid strong rain showers coming and going. Didn't have
ADSb weather going over until in the pattern. Was told there is an ADSb
antenna on the airport. Had weather on the ground and traffffic on
takeoff. Maintained it all the way home. I'm going to have to learn
more about how this stuff works and doesn't work. It should perform
better than that.
Bill "ADS-B is not so awesome but traffic and nexrad is" Watson
Bob Turner
PostPosted: Fri May 25, 2012 8:42 pm    Post subject: Re: GRT Panel Layout Reply with quote
For the VFR vs IFR (but in VMC) debate, don't forget the third option: file IFR and if the controller won't allow your requested deviation, ask for VFR on top at 500' above your altitude, assuming you are in VMC. Controller will be happy because he's relieved of separation responsibility; you'll be happy because you're still in the system, so if the weather goes below VFR just call them up to get back to a "real" IFR clearance. This also works to avoid routing you don't want. Of course you need VMC.
As to the partial panel question: yes I think it can be done, but:
In this emergency have you also lost pitch trim? (no power?). Flying pp without pitch trim is a handful. I think you'd have to fly the approach at unusually high speed, whatever indicated speed the plane was trimmed for when power was lost.
Also, Murphy's law dictates that this failure will happen in turbulence, where the TC will be rocking back and forth, you'll need to average by eye. I think the basic roll stability of the -10 is just sufficient for this, I wouldn't want to be forced to do it in an RV-7.
Does anyone know the current draw of a typical turn coordinator? Is it feasible to run it off a small backup battery for, say, two hours?
Bob Turner
RV-10 QB
Page 2 of 3
