N642K
Posted: Mon Aug 06, 2012 5:51 pm Post subject: Engine RPM and propeller speed |
I have a digital tach on my M-14B powered CJ. If it indicates engine crank RPM, are the displayed RPM limits corrected for the difference between crank and prop speed?
Thanks in advance.
Dabear(at)devere.us Guest
Posted: Mon Aug 06, 2012 6:41 pm Post subject: Engine RPM and propeller speed |
What is the tach and what are reading off of?
Bear
N642K
Posted: Mon Aug 06, 2012 7:22 pm Post subject: Re: Engine RPM and propeller speed |
This is a Horizon Tachometer. This from their website:
The P-1000 functions as two fully independent digital tachometers that monitor the signals received from the primary circuits of the aircraft’s magnetos. The internal right and left tachometers independently determine engine RPM, which is then average and displayed for the pilot. The superior reliability of the tachometer design is due to the use of two separate magneto signals to generate two identical RPM readings.
wlannon(at)shaw.ca Guest
Posted: Mon Aug 06, 2012 7:25 pm Post subject: Engine RPM and propeller speed |
You are reading crankshaft RPM.
Walt
Posted: Mon Aug 06, 2012 7:44 pm Post subject: Engine RPM and propeller speed |
Suspect you are reading the pulses off your P lead but don't know the type of tach and how it is wired Bear. So you should be reading the crank revolutions.
Doc
Sent from my iPad
Bear
Posted: Tue Aug 07, 2012 7:05 am Post subject: Engine RPM and propeller speed |
Posted: Tue Aug 07, 2012 7:16 am Post subject: Engine RPM and propeller speed |
This is a great instrument and works very well. That said, it works by connecting to the P leads of both mags. Every person that has done this install themselves (that I know) has usually ended up with increased radio noise from P lead EM radiation. Be very mindful of this and use the very best in shielded wiring and installation procedures to avoid radio EMI issues with this device.
Mark Bitterlich
N642K
Posted: Tue Aug 07, 2012 11:05 am Post subject: Re: Engine RPM and propeller speed |
I agree, it's a great instrument. But my question is about the difference between engine and prop speeds and the limits on the tachometer. Are those limits corrected for the difference?
Posted: Tue Aug 07, 2012 11:29 am Post subject: Engine RPM and propeller speed |
Mike,
The Horizon tach ranges can be set to ANY specification you want by the
manufacturer before delivery. IE: If the max engine RPM is 2900, the
tach red light can be programmed to come on at red line. The other
parameters, like 82% (2378 RPM) can also be pre programmed.
The original Russian tach, even though it reads in %, was engine RPM,
not prop RPM. The prop RPM is determined by the nose case gear ratio.
In the case of the M14P, it is .658. So in other words, no matter what
the engine RPM is, the prop always runs at 2/3 the speed of the
engine. All you do is phone Horizon and tell them what parameters you
want programmed into the tach and they will program it before delivery.
You will determine the limits on the Tach by the programming.
Dennis
A. Dennis Savarese
334-285-6263
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
N642K
Posted: Tue Aug 07, 2012 11:42 am Post subject: Re: Engine RPM and propeller speed |
Thanks Dennis. Once again you come thru with the answer. I guess I need to look up the limits of the V530 and double check what is already programmed on my Horizon tach.
Posted: Tue Aug 07, 2012 11:57 am Post subject: Engine RPM and propeller speed |
The V530 limits are your engine RPM limits, which according to the
manual is 2950 RPM. I prefer to use 2900 though.
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
Posted: Wed Aug 08, 2012 8:06 am Post subject: Engine RPM and propeller speed |
Hi Dennis;
I probably am wrong but I seem to recall from the manual that the operating
T.O. RPM limit for the M14P was 2901 and the overspeed limit was 2950.
It appears that "N642K" may still not understand that the tachometer has
nothing to do with the propellor.
Cheers;
Walt
N642K
Posted: Wed Aug 08, 2012 8:40 am Post subject: Re: Engine RPM and propeller speed |
Thanks Walt but I get it
Posted: Wed Aug 08, 2012 9:03 am Post subject: Engine RPM and propeller speed |
Hi Walt,
From the M14P maintenance manual, here are the specs pertinent to this
conversation.
Take-off rating is 2900 RPM +-1 (99%). "Given in brackets are nominal
values of the crankshaft speed of rotation in percent against the unified
tachometer (99.4 % corresponds to 2900 r/min of the crankshaft)".
I have no idea where they come up with 99.4% corresponds to 2900 r/min.
There are numerous misprints in the manual caused by translation. I'd
stick with 99%=2900 period.
1.2. SPECIFICATIONS
1.2.1. Engine
Designation................................................................................
M-14P
Cooling system
Air-type
Engine starting system
............................................................. Air-type
Engine continuous operation time:
At take-off rating
.............................……..………….................. Up to 5 min
At maximum permissible speed, of rotation .......... ...................
Up to 1 min
At other ratings ..................................
..................................... Not limited
Iverted engine operation:
Ratings ...........................................
.........................................Nominal
Continuous operation time .........................
............................. Up to 2 min
Total time within service life
..................................................... Up to 18 %
_/Maximum permissible speed of rotation ...............
.................. 2950 (101 %) r/min/_
Acceleration (pickup) from 760 r/min (idle) to take-off
rating on stationary airplane ..............
...................................... Up to 3 s
Maximum permissible crankshaft speed drop when
changing over to one-magneto operation at nominal
rating II and cruise rating I (low-pitch airscrew) ..
..................... 85 r/min (3 %)
Number and arrangement of cylinders .................
................... 9, radial, single-row
Cylinder numbering ..................................
............................... Counter clockwise if viewed from
rear cover side, top cylinder is Ho. 1
Cylinder bore
105 mm
Piston stroke:
Cylinder No. 4 ....................................
...................................... 130 mm
Cylinders Nos 3 and 5
.............................................................. 130.15 mm
Cylinders Nos 2 and 6 .............................
................................ 130.23 mm
Cylinders Nos 8 and 9 .............................
................................ 130.39 mm
Cylinders Nos 1 and 7 .............................
................................ 131.25 mm
Total displacement ..................................
................................ 10.161 1
Compression ratio ...................................
................................ 6.3±0.1
Direction of rotation of crankshaft and airscrew shaft ...............LH
Engine dry mass ..................................... 214 kg+2%
NOTE: Engine dry mass does not include mass of the generator,
compressor, fine
filter with pipelines, engine frame ring, exhaust manifold parts,
tachometer generator.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 8/8/2012 11:04 AM, Walter Lannon wrote:
Hi Dennis;
operating T.O. RPM limit for the M14P was 2901 and the overspeed limit
was 2950.
has nothing to do with the propellor.
Cheers;
Walt
markdavis(at)wbsnet.org Guest
Posted: Wed Aug 08, 2012 11:16 am Post subject: Engine RPM and propeller speed |
His confusion may be from the fact that he has an M-14B with an M-14P nose
case and standard Russian paddle blade prop on it, so the engine for all
practical purposes is the same as an M-14P regarding RPM limitations.
Engine RPM is engine RPM regardless of the nose case gear ratio.
Mark Davis
N44YK (w/M-14P, but also a spare M-14B in hangar with an M-14P nose case on
it.)
brian(at)lloyd.com Guest
Posted: Wed Aug 08, 2012 1:07 pm Post subject: Engine RPM and propeller speed |
On Wed, Aug 8, 2012 at 12:13 PM, Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)> wrote:
| Quote: | --> Yak-List message posted by: "Mark Davis" <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)>
His confusion may be from the fact that he has an M-14B with an M-14P nose case and standard Russian paddle blade prop on it, so the engine for all practical purposes is the same as an M-14P regarding RPM limitations. Engine RPM is engine RPM regardless of the nose case gear ratio.
And any tach that uses the impulses on the p-leads is using crankshaft RPM (probably a better name than "engine RPM") and not prop or output shaft RPM.
FWIW: p-lead pulses per crank rotation = number-of-cylinders/2
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
Posted: Wed Aug 08, 2012 1:51 pm Post subject: Engine RPM and propeller speed |
And...who's on first? To really confuse... a M-14 DHPF with an M-14 P nose case?!! Along with a few other minor but significant changes to allow for the prop governor accessory drive.
Doc
Posted: Wed Aug 08, 2012 7:21 pm Post subject: Engine RPM and propeller speed |
Hi Dennis;
Thanks for the info.
I agree, 2900 RPM (99%) period is a good number. I would not set up the
governor for the max. allowable of 2950 but would regard that as an
accidental overspeed limit.
Walt
Posted: Thu Aug 09, 2012 3:44 am Post subject: Engine RPM and propeller speed |
Totally agree with you Walt.
Dennis
A. Dennis Savarese
334-285-6263
www.yak-52.com
Skype - Yakguy1
On 8/8/2012 10:19 PM, Walter Lannon wrote:
Hi Dennis;
the governor for the max. allowable of 2950 but would regard that as
an accidental overspeed limit.
Walt
GeorgeCoy
Posted: Thu Aug 09, 2012 5:28 am Post subject: Engine RPM and propeller speed |
And then there was the guy with a homebuilt (name and type to remain
anonymous) who used a prop tach to set up his tachometer. Had the prop
turning at 2950 RPM . About 60 hrs later he was informed of his mistake. As
far as I know now 9 years later and over 500 hrs it is still running
fine...
