		N642K
				 Posted: Mon Aug 06, 2012 5:51 pm    Post subject: Engine RPM and propeller speed |
				I have a digital tach on my M-14B powered CJ.  If it indicates engine crank RPM, are the displayed RPM limits corrected for the difference between crank and prop speed?
 Thanks in advance.
		Dabear(at)devere.us Guest
				 Posted: Mon Aug 06, 2012 6:41 pm    Post subject: Engine RPM and propeller speed |
				What is the tach and what are reading off of?
 Bear
		N642K
				 Posted: Mon Aug 06, 2012 7:22 pm    Post subject: Re: Engine RPM and propeller speed |
				This is a Horizon Tachometer.  This from their website:
 The P-1000 functions as two fully independent digital tachometers that monitor the signals received from the primary circuits of the aircraft’s magnetos. The internal right and left tachometers independently determine engine RPM, which is then average and displayed for the pilot. The superior reliability of the tachometer design is due to the use of two separate magneto signals to generate two identical RPM readings.
		wlannon(at)shaw.ca Guest
				 Posted: Mon Aug 06, 2012 7:25 pm    Post subject: Engine RPM and propeller speed |
				You are reading crankshaft RPM.
 Walt
				 Posted: Mon Aug 06, 2012 7:44 pm    Post subject: Engine RPM and propeller speed |
				Suspect you are reading the pulses off your P lead but don't know the type of tach and how it is wired Bear. So you should be reading the crank revolutions.
 Doc
 Sent from my iPad
  Bear
				 Posted: Tue Aug 07, 2012 7:05 am    Post subject: Engine RPM and propeller speed |
				 Posted: Tue Aug 07, 2012 7:16 am    Post subject: Engine RPM and propeller speed |
				This is a great instrument and works very well.  That said, it works by connecting to the P leads of both mags.  Every person that has done this install  themselves (that I know) has usually ended up with increased radio noise from P lead EM radiation.  Be very mindful of this and use the very best in shielded wiring and installation procedures to avoid radio EMI issues with this device.
 Mark Bitterlich
		N642K
				 Posted: Tue Aug 07, 2012 11:05 am    Post subject: Re: Engine RPM and propeller speed |
				I agree, it's a great instrument.  But my question is about the difference between engine and prop speeds and the limits on the tachometer.  Are those limits corrected for the difference?
				 Posted: Tue Aug 07, 2012 11:29 am    Post subject: Engine RPM and propeller speed |
				Mike,
 The Horizon tach ranges can be set to ANY specification you want by the
 manufacturer before delivery.  IE: If the max engine RPM is 2900, the
 tach red light can be programmed to come on at red line.  The other
 parameters, like 82% (2378 RPM) can also be pre programmed.
 The original Russian tach, even though it reads in %, was engine RPM,
 not prop RPM.  The prop RPM is determined by the nose case gear ratio.
 In the case of the M14P, it is .658.  So in other words, no matter what
 the engine RPM is, the prop always runs at 2/3 the speed of the
 engine.   All you do is phone Horizon and tell them what parameters you
 want programmed into the tach and they will program it before delivery.
 You will determine the limits on the Tach by the programming.
 Dennis
 A. Dennis Savarese
 334-285-6263
 334-546-8182 (mobile)
 www.yak-52.com
 Skype - Yakguy1
		N642K
				 Posted: Tue Aug 07, 2012 11:42 am    Post subject: Re: Engine RPM and propeller speed |
				Thanks Dennis.  Once again you come thru with the answer.  I guess I need to look up the limits of the V530 and double check what is already programmed on my Horizon tach.
				 Posted: Tue Aug 07, 2012 11:57 am    Post subject: Engine RPM and propeller speed |
				The V530 limits are your engine RPM limits, which according to the
 manual is 2950 RPM.  I prefer to use 2900 though.
 A. Dennis Savarese
 334-285-6263
 www.yak-52.com
 Skype - Yakguy1
				 Posted: Wed Aug 08, 2012 8:06 am    Post subject: Engine RPM and propeller speed |
				Hi Dennis;
 I probably am wrong but I seem to recall from the manual that the operating
 T.O. RPM limit for the M14P was 2901 and the overspeed limit was 2950.
 It appears that "N642K" may still not understand that the tachometer has
 nothing to do with the propellor.
 Cheers;
 Walt
		N642K
				 Posted: Wed Aug 08, 2012 8:40 am    Post subject: Re: Engine RPM and propeller speed |
				Thanks Walt but I get it
				 Posted: Wed Aug 08, 2012 9:03 am    Post subject: Engine RPM and propeller speed |
				Hi Walt,
  From the M14P maintenance manual, here are the specs pertinent to this
 conversation.
 Take-off rating is 2900 RPM +-1 (99%). "Given in brackets are nominal
 values of the crankshaft speed of rotation in percent against the unified
 tachometer (99.4 % corresponds to 2900 r/min of the crankshaft)".
 I have no idea where they come up with 99.4% corresponds to 2900 r/min.
 There are numerous misprints in the manual caused by translation. I'd
 stick with 99%=2900 period.
 1.2. SPECIFICATIONS
 1.2.1. Engine
 Designation................................................................................
 M-14P
 Cooling system
 Air-type
 Engine starting system
 ............................................................. Air-type
 Engine continuous operation time:
 At take-off rating
 .............................……..………….................. Up to 5 min
 At maximum permissible speed, of rotation .......... ...................
 Up to 1 min
 At other ratings ..................................
 ..................................... Not limited
 Iverted engine operation:
 Ratings ...........................................
 .........................................Nominal
 Continuous operation time .........................
 ............................. Up to 2 min
 Total time within service life
 ..................................................... Up to 18 %
 _/Maximum permissible speed of rotation ...............
 .................. 2950 (101 %) r/min/_
 Acceleration (pickup) from 760 r/min (idle) to take-off
 rating on stationary airplane ..............
 ...................................... Up to 3 s
 Maximum permissible crankshaft speed drop when
 changing over to one-magneto operation at nominal
 rating II and cruise rating I (low-pitch airscrew) ..
 ..................... 85 r/min (3 %)
 Number and arrangement of cylinders .................
 ................... 9, radial, single-row
 Cylinder numbering ..................................
 ............................... Counter clockwise if viewed from
 rear cover side, top cylinder is Ho. 1
 Cylinder bore
 105 mm
 Piston stroke:
 Cylinder No. 4 ....................................
 ...................................... 130 mm
 Cylinders Nos 3 and 5
 .............................................................. 130.15 mm
 Cylinders Nos 2 and 6 .............................
 ................................ 130.23 mm
 Cylinders Nos 8 and 9 .............................
 ................................ 130.39 mm
 Cylinders Nos 1 and 7 .............................
 ................................ 131.25 mm
 Total displacement ..................................
 ................................ 10.161 1
 Compression ratio ...................................
 ................................ 6.3±0.1
 Direction of rotation of crankshaft and airscrew shaft ...............LH
 Engine dry mass ..................................... 214 kg+2%
 NOTE: Engine dry mass does not include mass of the generator,
 compressor, fine
 filter with pipelines, engine frame ring, exhaust manifold parts,
 tachometer generator.
 Dennis
 A. Dennis Savarese
 334-285-6263
 www.yak-52.com
 Skype - Yakguy1
 On 8/8/2012 11:04 AM, Walter Lannon wrote:
  Hi Dennis;
  operating T.O. RPM limit for the M14P was 2901 and the overspeed limit
  was 2950.
  has nothing to do with the propellor.
  Cheers;
  Walt
		markdavis(at)wbsnet.org Guest
				 Posted: Wed Aug 08, 2012 11:16 am    Post subject: Engine RPM and propeller speed |
				His confusion may be from the fact that he has an M-14B with an M-14P nose
 case and standard Russian paddle blade prop on it, so the engine for all
 practical purposes is the same as an M-14P regarding RPM limitations.
 Engine RPM is engine RPM regardless of the nose case gear ratio.
 Mark Davis
 N44YK (w/M-14P, but also a spare M-14B in hangar with an M-14P nose case on
 it.)
		brian(at)lloyd.com Guest
				 Posted: Wed Aug 08, 2012 1:07 pm    Post subject: Engine RPM and propeller speed |
				On Wed, Aug 8, 2012 at 12:13 PM, Mark Davis <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)> wrote:
  	  | Quote: | 	 		   --> Yak-List message posted by: "Mark Davis" <markdavis(at)wbsnet.org (markdavis(at)wbsnet.org)>
  His confusion may be from the fact that he has an M-14B with an M-14P nose case and standard Russian paddle blade prop on it, so the engine for all practical purposes is the same as an M-14P regarding RPM limitations. Engine RPM is engine RPM regardless of the nose case gear ratio.
 And any tach that uses the impulses on the p-leads is using crankshaft RPM (probably a better name than "engine RPM") and not prop or output shaft RPM.
 FWIW: p-lead pulses per crank rotation = number-of-cylinders/2
 Brian Lloyd, WB6RQN/J79BPL
 3191 Western Dr.
 Cameron Park, CA 95682
 brian(at)lloyd.com (brian(at)lloyd.com)
 +1.767.617.1365 (Dominica)
 +1.916.877.5067 (USA)
				 Posted: Wed Aug 08, 2012 1:51 pm    Post subject: Engine RPM and propeller speed |
				And...who's on first? To really confuse... a M-14 DHPF with an M-14 P nose case?!! Along with a few other minor but significant changes to allow for the prop governor accessory drive.
 Doc
				 Posted: Wed Aug 08, 2012 7:21 pm    Post subject: Engine RPM and propeller speed |
				Hi  Dennis;
 Thanks for the info.
 I agree, 2900 RPM (99%) period is a good number.   I would not set up the
 governor for the max. allowable of 2950 but would regard that as an
 accidental overspeed limit.
 Walt
				 Posted: Thu Aug 09, 2012 3:44 am    Post subject: Engine RPM and propeller speed |
				Totally agree with you Walt.
 Dennis
 A. Dennis Savarese
 334-285-6263
 www.yak-52.com
 Skype - Yakguy1
 On 8/8/2012 10:19 PM, Walter Lannon wrote:
  Hi Dennis;
  the governor for the max. allowable of 2950 but would regard that as
  an accidental overspeed limit.
  Walt
		GeorgeCoy
				 Posted: Thu Aug 09, 2012 5:28 am    Post subject: Engine RPM and propeller speed |
				And then there was the guy with a homebuilt (name and type to remain
 anonymous) who used a prop tach to set up his tachometer. Had the prop
 turning at 2950 RPM . About 60 hrs later he was informed of his mistake. As
 far as I know now 9 years later and over 500 hrs it is still  running
 fine...
