Kellym
Posted: Sun Feb 03, 2013 12:14 pm Post subject: [SUSPECTED SPAM] Re: Re: injector tuning |
You might want to reduce the time you soak them. Hoppe's is a good, but
aggressive cleaner than can attack the metal. Overnight is probably too
long, 30-60 min. is plenty. While some advocate annual cleaning, I would
base it on actual engine EGT results. As long as the balance remains the
same, I would leave them alone. The injector lines are fragile, subject
to an AD, etc. If it isn't broke, don't fix it. In over 750 hours &12
years of flying my Mooney, I have cleaned injectors 2 or 3 times.
On 2/3/2013 11:19 AM, Don McDonald wrote:
| Quote: | Really simple... a trip to Walmart, buy Hoppe's gun cleaner. get a
SMALL muffin tray, label them 1-6, put each nozzle in there
overnight... done deal.... I tried to do it every other year, but
suggest every year for frequent flier's like myself.
Don
--- On *Sun, 2/3/13, Marcus Cooper /<cooprv7(at)yahoo.com>/* wrote:
Subject: Re: Re: injector tuning
Date: Sunday, February 3, 2013, 12:00 PM
You bring up a good point Don that I don't know the answer to.
How does one clean the injectors and how often should this be done?
Marcus
On Feb 3, 2013, at 10:00 AM, Don McDonald
<building_partner(at)yahoo.com
</mc/compose?to=building_partner(at)yahoo.com>> wrote:
When discussing this it would have been nice to know the *actual
numbers* you came up with. GPH for each cyl when reaching LOP.
Having those would have made this thread a little shorter.
Just an FYI....Although my experience may be different than some,
what I can tell you is that there sure seem to be a few variables
out there.... altitude, MP, RPM, wind direction, BP, and maybe
most important, how long it's been since your last injector
cleaning. When the previously mentioned change, the LOP numbers
may also change.
Don McDonald
--- On *Sat, 2/2/13, Bob Turner /<bobturner(at)alum.rpi.edu
Subject: Re: injector tuning
</mc/compose?to=rv10-list(at)matronics.com>
Date: Saturday, February 2, 2013, 10:29 PM
<bobturner(at)alum.rpi.edu>
Okay, I've got dyslexia. I should have said my worst two
outliers peak first, not last.
So again, why does AFP prefer to go smaller on four rather
than larger on two? Is there any concern with not reducing
fuel flow at full power?
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=393483#393483
http://www.matronics.com/Navigator?RV10-List -->
http://www.matronics.com/co=================
<http://forums.matronics.com/>
*http://www.matro====================
Checked by AVG - www.avg.com
KCHD |
Kellym
Posted: Sun Feb 03, 2013 12:18 pm Post subject: [SUSPECTED SPAM] Re: Re: injector tuning |
Be sure to use two wrenches, one on the injector and one on the nut on
line, be gentle. Only needs 50-60 in/lb when reinstalling the injector.
Too tight can cause cracks in cyl head. As mentioned, use care moving
the line to extract injector. Best to loosen clamp and the other end of
the line so you don't have to do any bending.
Kelly
On 2/3/2013 12:12 PM, Don McDonald wrote:
| Quote: | REALLY simple, even Robin could do it... maybe Pascal to! I don't
have any pics... but once you look at the system, you'll have no
problem figuring it out.
Don
Date: Sunday, February 3, 2013, 12:40 PM
Thanks to both the responses. I happen to have gun cleaner,not
sure if I can talk my wife out of the muffin pans though
Any tricks to removing and reinstalling the injectors.
Considering all the work I've done on the 4 airplanes I've built
and maintained I'm amazed I never tackled this particular project.
Thanks again,
Marcus
On Feb 3, 2013, at 1:19 PM, Don McDonald
a SMALL muffin tray, label them 1-6, put each nozzle in there
Don
done?
Marcus
*actual numbers* you came up with. GPH for each cyl when
reaching LOP. Having those would have made this thread a
little shorter.
some, what I can tell you is that there sure seem to be a few
variables out there.... altitude, MP, RPM, wind direction, BP,
and maybe most important, how long it's been since your last
injector cleaning. When the previously mentioned change, the
LOP numbers may also change.
Don McDonald
Bob Turner
RV-10 QB
<http://www.matronics.com/Na=>*
*http://www.matronics.com/Navigator?RV10-ofollow" target="_blank" href="http://www.matronics.com/contribution">h
KCHD |
