Aircraft Tow
flysrv10(at)gmail.com
PostPosted: Fri Feb 08, 2013 12:35 pm    Post subject: Aircraft Tow Reply with quote
hi albert,
the article is gone. do you have more pics and perhaps motor spec and
source for purchase?
On Fri, Feb 27, 2009 at 1:34 AM, Albert Gardner <ibspud(at)roadrunner.com> wrote:
I finished my tow machine and here is a picture. I have about $150 in it-I
didn't have to buy a gear head motor, the wheel is from Harbor Freight at
$9, the 2 batteries from Wal-Mart (the motor is a 24V so I have 2 speeds)
but I kept buying the 1" square tube from Lowes and it was expensive. 2
problems: the space between the wheel pant and the tow wheel is too small so
I have to extend the arms about 3" and I need to add a light so I can hook
up in the dark. I'm thinking about a seat also so I can ride it around. I
got the idea from a Kitplanes article a few years back.
Albert Gardner
N991RV
Yuma, AZ
Rob Kermanj
flying-nut(at)cfl.rr.com
PostPosted: Fri Feb 08, 2013 1:35 pm    Post subject: Aircraft Tow Reply with quote
I've seen homebuilt tows powered by cheap battery-operated drills after
folks find it cheaper to buy a whole new drill w/battery and charger
than it is to buy a replacement battery. They remote the variable speed
switch up near the handle.
Linn
On 2/8/2013 3:34 PM, Rob Kermanj wrote:
hi albert,
> Albert Gardner
> N991RV
> Yuma, AZ
PostPosted: Fri Feb 08, 2013 2:03 pm    Post subject: Aircraft Tow Reply with quote
Thanks.
On Feb 8, 2013, at 4:34 PM, Linn wrote:
I've seen homebuilt tows powered by cheap battery-operated drills after folks find it cheaper to buy a whole new drill w/battery and charger than it is to buy a replacement battery. They remote the variable speed switch up near the handle.
Linn
> hi albert,
>> Albert Gardner
>> N991RV
>> Yuma, AZ
Rob Kermanj
Lenny Iszak
PostPosted: Sat Feb 09, 2013 6:48 am    Post subject: Re: Aircraft Tow Reply with quote
Rob,
Here's the article.
Lenny
flysrv10(at)gmail.com wrote:
hi albert,
Albert Gardner
N991RV
Yuma, AZ
Rob Kermanj
0405-5354.pdf
 Filename:  0405-5354.pdf
 Filesize:  125.25 KB
 Downloaded:  405 Time(s)
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
PostPosted: Sat Feb 09, 2013 8:08 am    Post subject: Aircraft Tow Reply with quote
Thank you Lenny. Got it.
On Feb 9, 2013, at 9:48 AM, Lenny Iszak <lenard(at)rapiddecision.com> wrote:
Rob,
Here's the article.
Lenny
> hi albert,
>> Albert Gardner
>> N991RV
>> Yuma, AZ
> Rob Kermanj
Lenny
#40803
http://forums.matronics.com/viewtopic.php?p=393910#393910
http://forums.matronics.com//files/0405_5354_158.pdf
Albert Gardner
PostPosted: Sat Feb 09, 2013 4:53 pm    Post subject: Aircraft Tow Reply with quote
Rob, just got back last nite and saw your email. I see someone else sent
you a copy of the article but here are my pics. The motor I used was a 24
vdc from a friend so I don't know of a source for 12VDC gear head motors. I
supposed you could try the cordless drill route. I put some small 12vdc
lites up on the tips where it grabs the plane. Works very good (much better
than the pilot did) and I'm very happy. I originally had the clamping ends
too low and had to raise them so that you can push down on the handles to
increase friction on the tire. Also, I got my over-the-center clamp just a
little too close to the front wheel pant.
Albert
 Filesize:  99.51 KB
 Viewed:  4178 Time(s)
 Filesize:  92.34 KB
 Filesize:  113.62 KB
 Filesize:  77.98 KB
 Filesize:  202.53 KB
 Filesize:  197.13 KB
 Filesize:  207.39 KB
RV-9A N872RV
RV-10 N991RV
PostPosted: Sat Feb 09, 2013 7:13 pm    Post subject: Aircraft Tow Reply with quote
Thanks for the pictures. Gives me a good idea of where to start. Found some 24 v geared motors for scooters. Not sure if they will do. I like your motor configuration.
Rob Kermanj
On Feb 9, 2013, at 7:52 PM, "Albert Gardner" <ibspud(at)roadrunner.com> wrote:
[quote] Rob, just got back last nite and saw your email. I see someone else sent
Albert
