woxofswa
Posted: Mon Feb 18, 2013 8:03 pm Post subject: Baffling tips |
Here's a couple of baffling tips worth what they cost.
Those dad gum steel pop rivets are the most strenuous project of all. I grunted more on those bad boys than installing the main gear legs.
I finally got smart and breaker bar'd my hand squeezer.
Also, I found that if I drilled the holes for those rivets at 31 instead of 30 (drill size), they secured better and didn't pull ever pull through.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
jfrjr(at)roadrunner.com Guest
Posted: Mon Feb 18, 2013 9:29 pm Post subject: Baffling tips |
A pneumatic squeezer (even the cheap Harbor Freight one) makes those baffle rivets way easy. JAY ROWE
---- woxofswa <woxof(at)aol.com> wrote:
Also, I found that if I drilled the holes for those rivets at 31 instead of 30 (drill size), they secured better and didn't pull through as much.
Myron Nelson
Mesa, AZ
Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress.
http://forums.matronics.com/viewtopic.php?p=394543#394543
woxofswa
Posted: Mon Feb 18, 2013 10:03 pm Post subject: Re: Baffling tips |
| jfrjr(at)roadrunner.com wrote: | A pneumatic squeezer (even the cheap Harbor Freight one) makes those baffle rivets way easy. JAY ROWE
---- woxofswa <woxof> wrote:
I have one that works great for aluminum rivets but wouldn't budge those steel ones.
Mesa, AZ
Flew May 10 2014 |
Posted: Tue Feb 19, 2013 4:29 am Post subject: Baffling tips |
I used soft AN4 rivets and 1/8" aluminum washers. Looks really nice, holds great, and super easy to drill out if needed....
-Mike Kraus
RV-4 sold
RV-10 flying
KitFox SS7 Radial building
On Feb 18, 2013, at 11:03 PM, "woxofswa" <woxof(at)aol.com> wrote:
Myron Nelson
Mesa, AZ
656.66 KB |
3465 Time(s) |
woxofswa
Posted: Sat Feb 23, 2013 5:56 pm Post subject: Re: Baffling tips |
jfrjr,
You were right and I was wrong. My squeezer had sat for a bit and wasn't properly primed. Once I dialed it in, it pulled those rivets with no trouble.
Mesa, AZ
Flew May 10 2014 |
