		donjohnston
				 Posted: Tue Sep 17, 2013 6:15 am    Post subject: Inline connections needed? (with little space) |
				I find myself stuck (again) and cant' decide on how to proceed.
 I'm working on wiring an overhead switch panel with about 10 switches. The space is rather tight. Because of that, I had to use some switches with really small bodies to fit in the area behind the panel. The only connection types are solder lugs.
 So now I've got to decide on how to wire them. I could solder the wires to the switches and run the wires directly to the mags, starter, master, etc.
 Or I could put in male/female faston connectors or knife connectors.
 I feel like hard wiring a switch directly to the controlled device is a bad idea since trying to solder a new switch in that position doesn't look like any fun.
 But what's the likelyhood of a switch failure? If it's not likely, then maybe it's not a bad idea. One of my thoughts during this build has been ease of service. But there's a point of diminishing returns that has to be considered.
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rickofudall
				 Posted: Tue Sep 17, 2013 3:01 pm    Post subject: Inline connections needed? (with little space) |
				Or you could use the machined pins for the DB 25 and mate them directly with some shrink tubing over them and go without using the body of the connector.
 Rick Girard
 On Tue, Sep 17, 2013 at 12:10 PM, Bob McCallum <robert.mccallum2(at)sympatico.ca (robert.mccallum2(at)sympatico.ca)> wrote:
  	  | Quote: | 	 		      Don't forget Bob's idea for making DB series connectors smaller if space is that much of an issue. This idea applies to the 25 pin as well as the 9. There is also the high density series which puts more pins in a smaller body size.
 http://www.aeroelectric.com/articles/macservo/macservo.html
 Bob McC
 &g========================>
 ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
 tp://forums.matronics.com
 Zulu Delta
 Mk IIIC
 Thanks, Homer GBYM
    - Groucho Marx
		donjohnston
				 Posted: Tue Sep 17, 2013 3:21 pm    Post subject: Re: Inline connections needed? (with little space) |
				 	  | rickofudall wrote: | 	 		  Or you could use the machined pins for the DB 25 and mate them directly with some shrink tubing over them and go without using the body of the connector.
 Rick Girard
 I have room for a DB-25 behind the switches.
