EXP 2 Bus workaround
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Oct 19, 2013 5:10 pm    Post subject: EXP 2 Bus workaround Reply with quote
At 04:01 PM 10/14/2013, you wrote:
On Oct 14, 2013, at 12:16 PM, Ken wrote:
>You are in the ballpark Fred but it's probably safe to round down
>to 20 amps for a no alternator battery life calculation.
Ken...thank you for your "3rd party validation"...at this stage of
the game, I'd rather be conservative, and I'm looking forward to
Bob's assessment.
I think I'm down to the last missing data point.
How do you switch between ECU modules? Do you have
a wiring diagram of this feature you can sketch or scan
to share?
Fred Klein
PostPosted: Sat Oct 19, 2013 6:14 pm    Post subject: EXP 2 Bus workaround Reply with quote
On Oct 19, 2013, at 6:09 PM, Robert L. Nuckolls, III wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
You are in the ballpark Fred but it's probably safe to round down to 20 amps for a no alternator battery life calculation.
Ken...thank you for your "3rd party validation"...at this stage of the game, I'd rather be conservative, and I'm looking forward to Bob's assessment.
to share?
Bob...the guts of the ECU is in a box mounted on the cockpit side of the firewall...is is connected to a small control console mounted on the panel via a D Sub cable. This small control panel includes a switch which toggles between the "A" motherboard and its back up, the "B" motherboard. In the D Sub connector, there are separate power inputs for A and B. I have no wiring diagram explaining this feature. Here is a photo of the panel mounted control console...the toggle switch obscures the "A".
Check it out in the lower right of the panel...then view close up:
[img]cid:059315AC-C223-4B8F-A1CF-7CEDF095E024[/img]
[img]cid:DC3EDB49-7B5F-4EE0-ADD2-61DB66B8EEC1[/img]
 Filesize:  46.19 KB
 Viewed:  9911 Time(s)
 Filesize:  54.63 KB
PostPosted: Sat Oct 19, 2013 7:56 pm    Post subject: EXP 2 Bus workaround Reply with quote
Check it out in the lower right of the panel...then view close up:\
I guess I missed that in the original set of
photos. Do these separate inputs need to be
switched . . . or is ECU power control accomplished
from the little panel?
Fred Klein
PostPosted: Sat Oct 19, 2013 8:28 pm    Post subject: EXP 2 Bus workaround Reply with quote
We will need a switch or circuit breaker between the battery and the ECU...ditto for the fuel injectors, coils, and fuel pumps.
klehman(at)albedo.net
PostPosted: Sun Oct 20, 2013 12:02 pm    Post subject: EXP 2 Bus workaround Reply with quote
If this question was for Ken...
On my one off z14 architecture 4 cylinder soob, I run two ecu's all the
time, one off each little battery. Two sets of injectors. Whichever set
of injectors is fed +12 volts flows fuel. If both are on by mistake the
engine loses some power but continues to run but a bit rough. I'm happy
with two switches for this. I don't need or want one either/or switch
although initially I was thinking that two mechanically interconnected
switches might be OK.
Similar with ignition. Whichever set of DIS coils is fed +12 volts feeds
the single plugs through MSD and homemade (polarity issue) HV coil
joiners. Both can be left on indefinitely or for landing and take off
but I only use one at a time.
In steady state cruise 18amps runs my airplane. That includes running
the VHF radio, transponder, intercom, engine monitor, gps, and maybe an
amp (or less) to the battery. If I did not have two alternators I'd size
the battery for about 15 amps for alternator failed operation. Injectors
are about 12 ohms and run 80% duty at full power and in my case about
50% duty in cruise. Ignition is about 5 amps at full power but a little
less in cruise. Similarly the injectors draw a little bit more at full
power but in total only maybe an amp or less difference between full
power and cruise for the complete system.
My system would certainly be overkill for most folks but it has some
unique advantages in terms of simple emergency procedures,
troubleshooting, and redundancy. With recycled parts, the dollar and
weight cost was trivial if not the labor. 530 flight hours on the Murphy
Rebel as of this morning.
Ken
On 19/10/2013 9:09 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> assessment.
to share?
Fred Klein
PostPosted: Mon Oct 21, 2013 11:55 am    Post subject: EXP 2 Bus workaround Reply with quote
All,
I would first of all like to thank all posters who have expanded my understanding of the issues I face as I proceed w/ the wiring of my aircraft...you have already helped me immeasurably to get to the revised (proposed) circuit diagram below.
(I'm quite aware that "numbers" are still missing...but my preference is to get my mind wrapped around the conceptual basis for things before sizing wires.)
With full knowledge of my ignorance of all things electric but with only scant knowledge of the challenges which lay ahead, some time ago I purchased an EXP 2 Bus, thinking that having one would simplify many issues and offset some of the novelty inherent with my auto engine conversion, a MPEFIed derivative of a EA81 Subaru built by RAM Performance Aero Engines which is liquid cooled. Aircraft is a Europa XS monowheel, a fiber glass airframe, which is typically powered w/ a 912S or 914.
I've been struggling to layout a circuit diagram which combines the EXP 2 BUS configured for an external solenoid with the dual battery / single alternator diagram Z-19 in the "AeroElectric Connection".
I have made a number of decisions which have committed me to the digital world including:
- an engine w/ electronic ignition, fuel injection, and an ECU (EC3, Real World Systems) which came w/ the engine,
- a digital EMS (EM3, Real World Systems) which "talks" w/ the ECU,
- a digital EFIS (Skyview) including moving map, digital terrain, Transponder, COM, and Intercom.
By selecting an auto engine conversion, I have committed to:
- one alternator, belt driven,
- one coolant pump, belt driven,
- single spark plug in each cylinder.
Additionally, in order to provide redundancy, the engine and control system includes:
- dual batteries, presently planned to be Odyssey 680's,
- two independent high pressure fuel pumps, each w/ their own filter,
- independent back up battery for Skyview,
- independent back up battery for stand-alone GPS, Garmin 396,
- redundant motherboards (A and B) for the ECU which are toggled from the panel.
OK...about the EXP BUS...I've now read many reports (including the VAF threads) which point out its shortcomings...but having spent $550 for it and its companion Indicator Module, and given my inexperience and lack of knowledge of things electrical, I still believe it has a place in my panel, so I hope any critique of what I'm up to doesn't focus on simply getting rid of it...it sure seems to have value to this electrical neophyte.
The EXP 2 Bus installation instructions can be downloaded at:
http://support.anywheremap.com/pdfs/EXP2-C.pdf
My approach to creating this circuit diagram has been an effort to meld together the EXP Bus w/ the Z-19RB circuit diagram in the AeroElectric Connection for "Dual Battery, Single Alternator, Electronic Controlled Fuel Injection Engine w/ Rear Mounted Batteries"...(a copy of which can be downloaded from:
[url=http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/] http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/[/url]
I could use spare circuits in EXP BUS for the ECU, coils, fuel injectors, and the fuel pumps, but I like the idea of being able to turn off the master and keep the fan turning...therefore I have these components powered via an Engine Bus.
I have space on my panel (just above the EXP BUS, and below the Skyview flat screen) for a row of 6 - switches which are presently planned to be:
- rocker or toggle between Fuel Pump #1 and Fuel Pump #2,
- Endurance Bus Alternate feed, on/off
- Battery #2, on/off
- ECU, on/off
- Fuel Injectors, on/off
- Coils, on/off
I also have space on my panel (between the COM/Intercom and the ECU controller) for a row or two of CBs or fuses.
Attached are pixs of my instrument panel in its present state, and a proposed circuit diagram. The intention of the circuit diagram is to show:
- 2 batteries wired as one to allow staggered battery replacement to ensure one of the two is relatively new and in excellent condition,
- EXP Bus to function as the main power distribution bus, powered from Contactor #1 which is controlled by a master switch,
- Starter powered from Contactor #2 so that in-flight re-start is possible w/ master off,
- Engine Bus (always hot) wired directly to the "battery side" of Contactor #2
Note: For purposes of maintaining proper C of G, batteries and contactors will be aft of the cabin.
I'd be extraordinarily grateful for any comments, and particularly those which point out errors or weakness in the diagram or the conceptual framework which the diagram is intended to address.
Fred
 Filesize:  46.19 KB
 Viewed:  9900 Time(s)
 Filesize:  77.81 KB
 Filesize:  1.81 MB
PostPosted: Mon Oct 21, 2013 3:45 pm    Post subject: EXP 2 Bus workaround Reply with quote
At 02:46 PM 10/21/2013, you wrote:
All,
I have pondered your project while plowing the asphalt between
here an Wichita for two round trips . . . and made some notes.
I'll be publishing my recommendations (as if it were my airplane)
in the next day or so. We'll be able to integrate the EXP-Bus with
some degree of grace.
I can find no reason to run two batteries in your project. The
disparity of endurance demands between the e-bus and engine-bus
leaves watt-seconds left over on the e-bus . . . which means
your panel is still lit after the engine quits.
My proposal will used the existing 'master' switch in the
legacy task. The avionics master will be come the e-bus
alternate feed. We'll create an engine bus very much like
the e-bus with a diode feed from the main bus for normal ops
and and a fat alternate feed from the battery like the
e-bus.
This means you can trade second battery and contactor weight
in for a larger main battery that will make your planning
and maintenance for Plan-B contingencies much simpler, longer
endurance and more reliable.
Tell me about your fuel pumps. What controls or limits their
pressure? By the way, what is the operating pressure for
the system?
Still wondering about A/B ECU boards. Can you leave them
powered up and simply select between A and B from the
control panel. Does an ECU NOT selected draw the same
current as the one presently selected?
Fred Klein
PostPosted: Mon Oct 21, 2013 8:59 pm    Post subject: EXP 2 Bus workaround Reply with quote
Bob...
I'm really surprised to here you say that...I've really bought into your rationale for having 2 batteries of equal size so they can be rotated out one at a time, raising the probability that one is always (relatively) new...as for my endurance bus, I'd love to add my COM to it. I think your rationale as I read it in the Connection is especially appropriate for an engine which can't rely upon mags.
'I'll get answers for your other questions tomorrow...
Thanks for your insights into my installation,
Fred
PostPosted: Tue Oct 22, 2013 6:04 am    Post subject: EXP 2 Bus workaround Reply with quote
Bob...
I understand. It would help to review the history
of the two-battery concept:
The simplest, most reliable batteries are those which
receive periodic critical attention, like pre-flight
checks for fuel, oil, tire tread, controls, etc. The
battery is this smooth plastic box hidden away out
of sight and offers no observable data on it's
state of charge or ability to even take a charge.
Obviously, we cannot pre-flight a battery with the
same level of confidence as pulling out the dipstick
to check oil.
But we do know that batteries tend to fail gracefully,
sorta like the degradation of compression with the
service time on an engine or tread wear with numbers
of landings on tires. It is sufficient to check
your compression every annual (~50 hrs for average
light aircraft) or get out the tread wear gauge when
the tires are "looking a bit skinny".
Delving into the inner secrets of a battery is a
process with more complexity and requiring more tools
than peeking into a fuel tank or wiggling the stick
to make sure controls are intact and free.
The first driver for considering dual batteries was
to eliminate or at least shift the cost of ownership
for periodic polygraph testing of the battery. The
idea was simply cycle a new battery into a pair
of batteries every annual. The rationale for that
philosophy was based on the owner/operator's willingness
and dedication to the task of tracking the battery's
condition.
If you take the total cost of owning your airplane
and divide by hours flown, you come up with some
number. Rotating a new battery into the top of a pair
each annual will add (cost-of-battery/hours-flown)
to that other number. For many, the $time$ spent
on doing a battery change-out was more attractive
than taxation of $time$ to do the periodic battery
polygraph.
A second benefit of the dual battery architecture
was that it clearly divided endurance calculations,
planing and management into to camps. (1) engine
and (2) everything else that influenced battery-only
flying time. When I introduced the
e-bus concept 20+ years ago, it was no big deal to
craft a Plan-B wherein electrical system endurance
exceeded fuel endurance.
The people-paid-to-worry about airplanes tell us
that for the most part, 30 minutes of battery-only
endurance is enough. Perhaps so for the wizened ATP
pilot with 10,000 hours and a host of successfully
managed tense days in the cockpit. But for John Q
fliver-flyer with 600 hours, no intensive training
in airborne systems management and only flies
50-100 hours a year . . . it's another matter
entirely.
Hence my personal design goals for seeking ways
to assemble, maintain and operate systems with
considerably more than 30 minutes of battery-only
performance . . . preferably some number than
exceeds duration of fuel aboard.
So, in 4-5 hours of pondering your system here
on the List and on the road, I've divided your
battery only requirements into two piles. (1)
no-options loads like keeping the fires behind
the prop lit and (2) lighting up things on
the panel that are most useful for continued
cruising flight until a CONVENIENT, or better
yet, airport of intended destination is in
sight.
As a renter of certified airplanes, my personal plan-B
planning, maintenance and operation is necessarily
limited to stuff I carry in my flight bag. In other
words, from J3 to A36 Bonanza, I have no control
over the airplane so I plan to get where I want
to go wether the panel is lit up or not.
Now, you've got an engine that we THINK takes
about 10A to run. Getting one hour of endurance
requires a single battery having about 20 a.h.
capacity (when new) at the 20 hour rate. We know
that failure to benefit from ALL of a battery's
potential energy is a function of the battery's internal
resistance. So the proportion of energy tossed
off internally at any given discharge rate is
less if the battery is up-sized.
Another consideration for your airplane is
the value of partitioning system power into
two tasks (1) truly essential - keeping the
engine running and (2) optional - things on
the panel.
Okay, how does the Plan-B picture change if
your airplane is fitting with one, larger battery.
Several ways: First there is more incentive to
KNOW the state of your battery's health. This
means $time$ required for the periodic electrograph
as a preventative maintenance policy on the
airplane. But if you ran nothing but the
engine during no-alternator-ops, then the larger
single battery maximizes your endurance numbers
into something far more comfortable than that
30-minute thingy the paid-to-worry crowd is
so comfortable with . . . but then, NONE of
those folks are going to fly YOUR airplane.
Next, with one battery, you have the option
of turning OFF things that influence your
endurance capabilities . . . especially if
those capabilities are backed up by Plan-B1
hardware in the flight bag. So if your desired
destination is only an hour away, leave all
that stuff on. But you have the option of getting
2 hours plus endurance too.
Finally, this line of reasoning offers a much
simpler array of switches for which in-flight
decisions must be made. It offers a relatively
clean way to integrate the EXP-Bus into to
final design.
So armed with knowledge of battery condition,
time to fly to an airport of convenience then
you can simply choose what things on the panel
will be lit up or shut down. Maybe you can
go max-dark and fly hand-held until time
for descent and approach whereupon you turn
things back on. In this mode of flight, the
only thing other than engine specific loads
would be a voltmeter.
Based on this recent line of reasoning, I'm
wondering if elegance level Z-19 is really
as cool as I thought when the drawing was
crafted some years ago. It is perhaps and
example of the "too soon we get old, too late
we get smart" syndrome. But if that question
in going to get answered, I doubt that it
will happen more expeditiously than here
on the List . . . and you (along with your
airplane) may be the impetus for the effort.
Fred Klein
PostPosted: Tue Oct 22, 2013 7:50 am    Post subject: EXP 2 Bus workaround Reply with quote
I appreciate your circumspection in taking another look at your twin battery rationale as you stated it in the Connection. And I wrestle with what I see as inherent contradictions in our quest for both fail-safe redundancy and simplicity...i.e., the more redundancy, the more complexity...fail-safe redundancy - good...increased complexity - not so much.
A client of mine who certifies electrical and electronic systems for the big boys...I can't state his company's role or authority in the proper terminology...absolutely bemoans the aircraft industry's approach to solving problems in complex systems by adding another layer of complexity.
Fred
PostPosted: Tue Oct 22, 2013 9:10 am    Post subject: EXP 2 Bus workaround Reply with quote
At 10:49 AM 10/22/2013, you wrote:
--> AeroElectric-List message posted by: Fred Klein <fklein(at)orcasonline.com>
I think the seeds of the dual-battery tree
were planted by Lightspeed's early-on recommendations
for a second, diode maintained battery to insure
one source of power to a second ignition system.
Sounds like a man who understands FMEA, MTBF
and the value of simplicity in the practical world
of human frailties.
Unfortunately, a lot of public ignorance of
risks exploited by Hollywood and driven by
individuals-paid-to-worry . . .
[img]cid:.0[/img][/b]
Your friend sounds like a good resource to review
ideas in this . . . what do I call it . . .
critical review of what may have been an under-developed
idea. Not necessarily a BAD idea but not the elegant
solution.
I'll try to get a drawing crafted to clarify my
thoughts in a form suitable for fielding review by
thoughtful observers.
 Filesize:  187.14 KB
 Viewed:  9883 Time(s)
Fred Klein
PostPosted: Wed Oct 23, 2013 10:05 am    Post subject: EXP 2 Bus workaround Reply with quote
ECU manual states:
There are separate power inputs for the A and B controllers. If your electrical system has a back up power bus you can connect the B controller to it. Otherwise tie both A and B power inputs together.
Tracy Crook just emailed:
Yes, both controllers draw current when either one is selected, Also, BOTH power inputs must be supplied with 12 volts when in operation.
Total Current draw is less than 1/2 amp.
If we proceed w/ an Engine Bus w/ alternate feed, it appears to me that both A and B would best be tied together.
Fred
Fred Klein
PostPosted: Wed Oct 23, 2013 10:14 am    Post subject: EXP 2 Bus workaround Reply with quote
Bob...you asked about my fuel pumps and pressures...
The fuel pressure at idle is 38 psi; at wot it rises to 43 psi.
The pressure is controlled by a regulator which sits on what my guy calls a "fuel log" which sets on the tops of the cylinders...I can provide photo if necessary.
Fred
Fred Klein
PostPosted: Wed Oct 23, 2013 10:51 am    Post subject: EXP 2 Bus workaround Reply with quote
Bob...this latest iteration of diagram is my effort, striving for elegance, to incorporate your suggestions which I present as follows:
- Wire the engine bus via a diode feed from the 2, 11amp AUX circuits on the EXP Bus; provide an alternate feed from the battery via an "Engine Bus Alternate Feed Relay".
- Wire the endurance bus via a diode feed from a 7 amp circuit on the EXP Bus; provide an alternate feed from the engine bus via an "Endurance Bus Alternate Feed Relay".
- Regarding the re-wiring and re-labeling of some of the EXP Bus rockers, I've deviated from your suggestions after considering the following rationale and thinking about having a simple organization if things go south:
Let the row of EXP Bus rockers serve for normal ops; i.e., power up the ECU, the fuel injectors, and the coils using the 3 rockers furthest to the left, currently labeled
"I GN", "AUX", and "Clrnc Del"...(for my anticipated ops, clearance delivery will be rarely used).
Let the space above the EXP Bus be for switches used during emergencies; i.e., switch from fuel pump #1 to fuel pump #2; switch engine bus to alternate feed, and endurance bus to alternate feed (both feeds direct to battery, if EXP Bus or alternator go out.
- One battery and master contactor are shown, but I'm inclined to leave open for now the option for dual batteries and rotating out one of them periodically.
All comments most appreciated.
Fred
[img]cid:13F273D5-460E-42FE-917A-347EBD3AD8C6[/img]
[img]cid:51CD48EE-C6FF-4A77-987C-12CE77891CEA[/img]
 Filesize:  69.6 KB
 Viewed:  9873 Time(s)
 Filesize:  46.19 KB
PostPosted: Wed Oct 23, 2013 3:42 pm    Post subject: EXP 2 Bus workaround Reply with quote
Okay, getting closer.
(1) Recommend you take the engine bus normal feedpath directly
from the main bus through the diode. A normal Engine ON/OFF
switch in this path seems to make sense see (6).
(2) add 30A maxi fuse in series with Engine Bus Alternate
Feed path and being engine power forward on 10AWG wire.
(3) Take E-Bus alternate feed directly from the battery on
it's own 7A fuse and 14AWG wire . . . 10A fuse if determined
necessary later.
(4) Go to solid state relays for e-bus and E-bus alternate
feeds, either Eric's or ours.
(5) Run #2 fuel pump from main bus through polyfuse and
EXP Bus switch.
(6) I see no value in having separate switches for
injectors, coils, normal pump or ECU feed. One switch
in normal feed path for normal engine ops, one switch
to control alternate feed path. When and why would you
ever operate one of these switches independently of
the others. Two ways to power engine . . . normal and
alternate.
(7) Suggest separate fuses for each injector and coil
assuming engine produces some useable power with any
one fuse open.
(Cool Starter can control from main bus.
(9) Turn existing avionics bus into e-bus, convert
old avionics master into alternate feed path control
switch. Normal feed path comes from main bus through
diode.
(10) You speak to "room for breakers/fuses on panel"
suggest these be out of sight, of reach.
Fred Klein
PostPosted: Wed Oct 23, 2013 7:36 pm    Post subject: EXP 2 Bus workaround Reply with quote
On Oct 23, 2013, at 5:03 PM, Bill Bradburry wrote:
What is the switch “Clrnc Del” used for in the normal install? Is this a second avionics master to use to get a clearance prior to starting the engine??
Bill...I suppose you could call it that...the Clearance Delivery is on a "keep alive" 3 amp circuit w/ its own on/off switch intended for communication w/ tower w/o turning on your whole panel prior to engine start up...Fred
PostPosted: Thu Oct 24, 2013 10:34 am    Post subject: Re: EXP 2 Bus workaround Reply with quote
Looking at the EXP 2 Bus Installation Manual
http://support.anywheremap.net/pdfs/EXP2-C.pdf
Page 15 has a simplified schematic. In the lower right hand corner are 2 diodes, D10 and D12, that can power the engine. The diodes are powered by two separate circuits: the MAIN BUS and the BACKUP BUS which can get its power directly from the battery through J31.
The problem is trying to convert the avionics bus into an endurance bus. There does not appear to be an avionics mechanical relay. It looks like a solid state relay with an ON-OFF input and a START DISABLE input. Without having the board in hand, it is hard to say how to bypass this device with a diode. Another problem is how to feed the avionics bus with a second power input from an E-bus relay.
Notice in the upper right hand corner is diode D3. What is that for? When would current ever want to flow in the opposite direction? The only thing that I can think of is that it is a misguided attempt to prevent voltage spikes from the master contactor coil. But any induced current will flow with the diode, not in the opposite direction. Am I overlooking something?
Joe
Joe Gores
Fred Klein
PostPosted: Thu Oct 24, 2013 2:10 pm    Post subject: EXP 2 Bus workaround Reply with quote
Joe...see indents below within your text...Fred
The "simplified schematic" on p. 15 shows the optional back up battery diodes; this is a factory mod which I do not have. My EXP is better described by the schematic on p. 13 (Typical install w/ Ext. Solenoid...factory supplied jumper replaces the Master Relay K1)...however, the AUX1 and AUX2 circuits are mislabled and are 11 amps, not 7 amps as shown.
I am loath to alter the innards of the EXP, other than perhaps re-lable and re-purpose a couple of the rocker switches and wiring them accordingly. My latest proposed circuit diagram shows a separate E-bus fed thru a diode from a 7 amp circuit off the EXP Avionics bus, with an alternate feed thru a relay from the engine bus. I'm content to allow the Avionics Bus to remain as is, noting that both GPS and Skyview do not move to the E-bus as they both have stand alone back up batteries. It's no accident that this thread is named "workaround".
These things I cannot commentt on...
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=411341#411341
PostPosted: Fri Oct 25, 2013 5:32 am    Post subject: EXP 2 Bus workaround Reply with quote
Attached are the preliminary sketches for my current
thoughts on an architecture for single battery, single
alternator, electrically dependent engine. This line of
thinking is being developed as an preferred alternative
to Z-19.
This architecture has roots in Z-11 Three-Bus structure
with the addition of a Motive Power Bus (engine). With
the term E-bus already in legacy use, the MP-Bus terminology
offers a stand-out label that avoids confusion.
The major difference is the addition of the MP-bus having
normal feedpath from the main bus, alternate feedpath from
the battery . . . same as the E-Bus except BOTH pathways
have panel mounted switches. The e-bus is always hot any
time the main bus is hot, but the MP-Bus as power to the
engine needs to be controlled through both pathways.
I'm thinking that the EXP-bus can be folded into this
architecture by conversion of battery switch to DC master
and take alternator field through second pole. Convert
the 'avionice master' Engine A. Use switch between the
big red rockers as e-bus alternate feed. Switch to right
of Engine A is Engine B.
Old avionics bus becomes e-bus. Add fuse-block with
sufficient slots to accommodate MP-Bus loads.
Solid state relays in the alternate feed paths is
an option. Nothing wrong with the legacy automotive
plastic cube relays here but the DO draw about 100
mA each. Two relays in the battery only mode consumes
as much energy as another accessory . . . solid state
relays will consume a milliamp or so. That's a decision
that is not germane to current identification of loads
and shuffling them to the right bus.
Fred, if you would make a list of how the various
electrical loads would be distributed along these four
busses, I can move forward with a refinement of the
idea specific to your airplane. Don't worry about circuit
protection or wire sizing . . . just a list of everything
that gets a protected feeder and which bus you would
attach it to.
The next phase of the EXP-Bus workaround involves a
head-count of protected load-taps from existing e-bua
and main bus structures on the EXP-Bus assembly . . .
and distributing those load-taps amongst proposed
electro-whizzies. The MP-Bus is easy since it's an
external addition and not limited as to numbers of
load taps.
The relative risk factors for this architecture are
driven by the same factors that have been part-and-parcel
of owning and operating an airplane of any genre' whether
OBAM or TC.
KNOW YOUR BATTERY and it's EXPECTED DUTIES to meet
DESIGN GOALS for battery only operations. Then maintain
that capability as religiously as you change oil, tires
or use safety wire on prop bolts.
The two-battery band-aid is, perhaps, not as great
a risk mitigation as we once thought. This has been
a good exercise in the sifting of bits and pieces.
Critical review solicited and welcomed.
Z-08_Full.pdf
 Filename:  Z-08_Full.pdf
 Filesize:  335.26 KB
 Downloaded:  342 Time(s)
Z-08_Excerpt.pdf
 Filename:  Z-08_Excerpt.pdf
 Filesize:  204.02 KB
 Downloaded:  309 Time(s)
Fred Klein
PostPosted: Fri Oct 25, 2013 4:36 pm    Post subject: EXP 2 Bus workaround Reply with quote
Bob, thank you for your analysis and recommendations...they greatly enhance my learning experience here...please see my indents below...I have additional comments (later) on your posted circuit diagram of this morning...Fred
I don't understand how I might "take the engine bus normal feedpath directly
from the main bus through the diode." It seems to imply to me that I poke around on the circuit board and find a place to attach a wire. I thought my proposal to tap the existing two 11 amp AUX circuits with a fast-on spade or two would be a rather elegant way to use what's available. (See my comments on your item (6) below.)
OK...straightforward enough...
necessary later.
I can do that; this adds another wire forward from rear battery to bus...What's the advantage of doing this rather than using a short wire to the Engine (MP) bus, as long as the total E-bus + MP bus loads can be handled by the EXP Bus circuit from which power is being drawn? Normally (I believe the) E-bus alternate feed will ONLY be activated in conjunction w/ the Engine (MP) bus alternate feed (sized accordingly) is activated.
OK
EXP Bus switch.
Let's talk about the 2 fuel pumps for a MPEFI engine. Unlike w/ carb engines, the 2nd pump is not used as a boost pump. I'm advised that w/ a MPEFI engine, one never wants to run more than ONE pump at a time due to excessive pressure in the system.
This is why I've been showing 2 switches in series...the first switch powers up a single fuel pump...whether that is pump #1 or pump #2 depends on the second switch. The reason for two fuel pumps is to ensure fuel flow in the event of either a pump failure or a clogged filter. These events can occur regardless of where the elec power is coming from. I say it's essential that BOTH pumps can be energized either thru the EXP Bus or the Engine (MP) bus alternate feed.
I believe your point (5) misconstrues the purpose of dual pumps in a MPEFI engine. What am I missing?
alternate.
On reflection, I understand (finally)...a single switch it is.
one fuse open.
This sounds like a novel idea...I'm wondering if anyone's ever done this before?.. how much increased complexity is entailed?...and whether or not historical rates of injector and coil failures suggest that this would be prudent?
True...and...w/ my particular combination of engine, reduction ratio, propeller, and aircraft performance envelope, although I THINK that with engine out, prop would windmill sufficient to restart engine, if Master switch was OFF, I'd like to be able to spin the starter...that was the INTENT of what the diagram shows...What do you think?...I'm unsure as to whether or not the wiring diagram allows for that to happen.
diode.
I'm completely in the dark as to my understanding of what physical changes must be made to the EXP Bus to accomplish this.
That would be possible of course, though if CBs are used, questionable. I'm presuming that you want them out of sight to reduce workload in an emergency, and to avoid possibly exacerbating conditions by resetting popped CBs...is that so?
Page 3 of 6
