rvdave
Posted: Sun Feb 09, 2014 6:43 pm Post subject: Winter Milestone |
After last year of seeing mediocre progress on my 10 build and seeing and hearing the advancements others have made, it's a little ironic that I would see a milestone (to me) during the coldest months of the year -around 0 degF --huddling around the 100K btu portable heater. I've had my fuselage mounted on a low rolling square tube frame bolted to the wing spar and supporting the tail for the last two years working on interior things, overhead console, carbon fiber panel, electrical stuff--keeping it low for as long as I could to make it easier for access to inside things. Enough of that, I needed to see progress so bring out the gear legs---drilled and mounted. Grease main bearings & mount wheels--done. Install nose gear, grease bearing, mount nose wheel---done. Remove parasitic square tubed frame--done. It's standing on its own now! Slide over engine hoist, lift engine & bolt to engine mount--done. Break out baffle kit & begin install-- now in progress...
All in the last two weeks---for me a milestone. Had to share
_________________ Dave Ford
Cadillac, MI |
Kelly McMullen
Posted: Sun Feb 09, 2014 6:56 pm Post subject: Winter Milestone |
Well, you can't get too far on those baffles until you have the engine cowling done so that you can accurately trim the baffles to the cowling.
On Sun, Feb 9, 2014 at 7:43 PM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=418438#418438
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Posted: Sun Feb 09, 2014 6:57 pm Post subject: Winter Milestone |
And I KNOW how eager you are to do some more fiberglass......
On Sun, Feb 9, 2014 at 7:56 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
| Quote: | Well, you can't get too far on those baffles until you have the engine cowling done so that you can accurately trim the baffles to the cowling.
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
le, List Admin.
KCHD |
flying-nut(at)cfl.rr.com Guest
Posted: Sun Feb 09, 2014 7:09 pm Post subject: Winter Milestone |
Thanks for sharing. I hate it when I have guys stop by and say 'looks
the same as the last time I saw it'. Depressing! It's a lot of little
things that take up so much time and show so little progress.
Linn BTDT
On 2/9/2014 9:43 PM, rvdave wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
Checked by AVG - www.avg.com
jack(at)bedfordlandings.c Guest
Posted: Mon Feb 10, 2014 4:12 am Post subject: Winter Milestone |
Try having your RV-10 project in a bunch of crates while you build a new
home. It's been 2 yers since I've seen the wings and tail of my -10, but
the house is finished (more or less) now and I'm about to break into the
crates and resume work on the RV-10 once again.
By the way, the house is actually a fly-in Bed & Breakfast, located adjacent
to the runway at Smith Mountain lake Airport (W91), near Roanoke, Virginia.
Check out our website at www.bedfordlandings.com and come stay a night or
two with us.
Jack Phillips
40610 - wings
Smith Mountain Lake, Virginia
Posted: Mon Feb 10, 2014 4:16 am Post subject: Winter Milestone |
Hey Dave, I'm sitting here feeling good with you. Getting up off the
floor and up to full height is a major for sure! Strapping on that
beast of a Lycosaur is even better.
The '10 was my first but as a repeat offender.... is your 'six suddenly
getting smaller? I know my Maule was getting slower.
I remember the winter 2008 when I finally had all the big pieces ordered
and built up. The fuselage was still on it's rollers but I spent a day
just moving all the pieces around the hangar and taking pictures. It
started looking like a bunch of pieces that WOULD fly sometime soon.
The big January pick me up!
The glass work on the cowling was a piece of cake compared to the doors
and cabin work. The part you might want to skip is fitting the pants
but I'm sure you know better.
Thanks for sharing.
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
cooprv7(at)yahoo.com Guest
Posted: Mon Feb 10, 2014 6:09 am Post subject: Winter Milestone |
Congrats Dave,
Very few people (if any) are able to press through a project as significant as building an airplane without at least some pauses. There is nothing more motivating than seeing progress! Well done and keep up the momentum, I guarantee it’s worth it in the end.
Marcus
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
Kellym
Posted: Mon Feb 10, 2014 6:40 am Post subject: Winter Milestone |
I agree that the cowling is easier than the doors and canopy.
However, just wondering if I am the only one where the cowl molding just
is not right.
While the inner nose behind spinner fits just fine, the outer nose,
outside the openings, the lower half extends 1/8 to 1/4" further forward
than the upper cowl.
Since this is some of the thickest part of the glass, it isn't a matter
of flexing or trimming. While I will fix it, I'm not happy that the fit
wasn't better right out of the mold. It is the pink version of the
cowling, and I've got the rest of it fitting fine. Oh well, at least
hangar temps are getting back to where needed (mid 70s to 80s) for
mixing epoxy, etc. Apologies to those stuck in cold country.
Kelly
On 2/10/2014 5:15 AM, Bill Watson wrote:
suddenly getting smaller? I know my Maule was getting slower.
ordered and built up. The fuselage was still on it's rollers but I
spent a day just moving all the pieces around the hangar and taking
pictures. It started looking like a bunch of pieces that WOULD fly
sometime soon. The big January pick me up!
doors and cabin work. The part you might want to skip is fitting the
pants but I'm sure you know better.
Thanks for sharing.
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
KCHD |
davidsoutpost(at)comcast. Guest
Posted: Mon Feb 10, 2014 7:58 am Post subject: Winter Milestone |
I have the pink cowlings and they match up really well. IIRC, I had to do some grinding and trimming on the lower cowling nose area mating flange and also the upper cowling where it overlaps the flange. There was a lot of excess epoxy bumps in that area and once they were removed, sanded flat and trimmed, I had a nice fit. I was very pleased with all of the fiberglass parts supplied by Van's except for the strut fairing cuffs.
Sent: Monday, February 10, 2014 9:39:53 AM
Subject: Re: Winter Milestone
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com>
is not right.
Kelly
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com>
Thanks for sharing.
> --> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com>
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
&g; -Matt Dralle, List Admin.========
partner14
Posted: Mon Feb 10, 2014 9:58 am Post subject: Winter Milestone |
Thanks.... now I have to go take a nap.... just reading all your accomplishments totally wiped me out.... Congrats.... it'll all be worth it.... to end up with the best traveling machine there is.
Don McDonald
On Monday, February 10, 2014 10:12 AM, David Clifford <davidsoutpost(at)comcast.net> wrote:
is not right.
Kelly
Thanks for sharing.
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
[quote]http://www.matrolow" target="_blank" href="http://forums.matronics.com/">http://forums.= --> [b]
40636 |
Bob Turner
Posted: Mon Feb 10, 2014 11:34 am Post subject: Re: Winter Milestone |
My pink cowling is not cosmetically perfect, in the area you mentioned. But I had a worse problem: the composite sandwich reinforcement around the aft end was too far aft. (Vans questioned my measurement of the prop location; I replied that there was no measurement, I had the prop installed). I had to cut away some of that sandwich, lay in a flat area for the piano hinge, and then re-strengthen the cowl in the area where I had removed the composite layer. For me this was far and away the worst QC problem I encountered.
_________________ Bob Turner
RV-10 QB |
johngoodman
Posted: Mon Feb 10, 2014 12:22 pm Post subject: Re: Winter Milestone |
| jack(at)bedfordlandings.c wrote: | Try having your RV-10 project in a bunch of crates while you build a new
two with us.
Jack Phillips
40610 - wings
Jack,
Great looking place, and it's halfway between Atlanta and Newark - a trip I plan on making a lot. Just might drop in one evening.
John
_________________ #40572 Phase One complete in 2011 |
Kelly McMullen
Posted: Mon Feb 10, 2014 12:42 pm Post subject: Winter Milestone |
Hmm, they must have fixed that. I chose to go with Skybolt fasteners, which some folks had to do a similar reduction of the foam sandwich area to have room for the mounting strip for receptacles. Mine fit without modifiying the rear of the cowl at all, beyond the normal trimming.
On Mon, Feb 10, 2014 at 12:34 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
| Quote: | --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=418472#418472
le, List Admin.
KCHD |
rvdave
Posted: Mon Feb 10, 2014 6:46 pm Post subject: Re: Winter Milestone |
Now I see...cowl next, lots of trimming and sanding to fit--little by little...
| Quote: | | Well, you can't get too far on those baffles until you have the engine cowling done so that you can accurately trim the baffles to the cowling. |
Cadillac, MI |
Posted: Tue Feb 11, 2014 5:16 am Post subject: Winter Milestone |
I had the pink cowling (and the old green top). Evidence of the misfit
you describe remains evident on my finished aircraft, or at least
evidence of what I had to do to fix it. I thought the problem was mine
alone.
In retrospect, what I did was build up the inner surface with some
combination of flock/mill/chop. I don't think I added any cloth. Then I
ground away the outer surface until flush with the upper outer surface.
The 'trick' I used to do a precision grinding job was to use some sort
of fat (1/2") grinding bit mounted in a drill stop cage so I could drill
a series of holes with the exact depth that I wanted to grind away.
Then I filled those holes with black tinted filler (the black tint was
from the windshield fairing work). That enabled me to grind the surface
down with whatever tool I chose. When the black disappeared, I had
ground away the right amount of material.
I only remember all of that because it was completed post paint and
evidence is still visible underneath the spinner. Please don't look.
Bill "still enjoying playing with the composites and glass dust" Watson
On 2/10/2014 9:39 AM, Kelly McMullen wrote:
just is not right.
forward than the upper cowl.
matter of flexing or trimming. While I will fix it, I'm not happy that
the fit wasn't better right out of the mold. It is the pink version of
the cowling, and I've got the rest of it fitting fine. Oh well, at
least hangar temps are getting back to where needed (mid 70s to 80s)
for mixing epoxy, etc. Apologies to those stuck in cold country.
Kelly
> Thanks for sharing.
woxofswa
Posted: Tue Feb 11, 2014 6:43 am Post subject: Re: Winter Milestone |
The trap I fell into whilst working the forward lips was putting the cowl halves together but off of the airplane and then sanding/filing the front faces perfectly flat. You can't do that because the natural moulded-in contour state of the cowl halves, is slightly different than the installed contour which creates a pursing effect of the front lips. Perfectly planar off the airplane (easiest to work) gave me a wider gap at the sides than the top and bottom once installed. I also had to build up material behind the lip, especially on the bottom, to be able to make a nice even gap all around when installed. I hope this makes sense. Hard concept to explain.
So glad that composite work is in the rear view mirror.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014
Kelly McMullen
Posted: Tue Feb 11, 2014 6:43 am Post subject: Winter Milestone |
I'm thinking it might easier to create close to matching profile with Superfill, then put a couple layers of glass over that for outer strength, without grinding away much of the existing. A few ounces heavier, but no question of strength.
On Tue, Feb 11, 2014 at 6:15 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
| Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
I had the pink cowling (and the old green top). Evidence of the misfit you describe remains evident on my finished aircraft, or at least evidence of what I had to do to fix it. I thought the problem was mine alone.
In retrospect, what I did was build up the inner surface with some combination of flock/mill/chop. I don't think I added any cloth. Then I ground away the outer surface until flush with the upper outer surface.
I only remember all of that because it was completed post paint and evidence is still visible underneath the spinner. Please don't look.
le, List Admin.
KCHD |
Posted: Tue Feb 11, 2014 8:41 am Post subject: Winter Milestone |
That sounds like a better approach.
I can't recall accurately but my guess is that I had already fit the cowling to the fuselage and the top half gap at the prop was what I wanted and the bottom turned out to be bit too tight. Probably a result of spending more time getting the top half gap right and lazy about getting underneath to insure a good fit on the bottom. By the time I noticed the discrepancy it was too late.
On 2/11/2014 9:42 AM, Kelly McMullen wrote:
[quote] I'm thinking it might easier to create close to matching profile with Superfill, then put a couple layers of glass over that for outer strength, without grinding away much of the existing. A few ounces heavier, but no question of strength.
le, List Admin.
02/11/14 [b]
