donjohnston
Posted: Thu Mar 06, 2014 7:07 pm Post subject: 24v aux power port? |
I've been looking for an auxiliary power port (courtesy port). All the ones I see are advertised for use in 12v electrical systems. But I'm 24v.
For example:
http://www.amazon.com/Accessory-Outlet-Lighter-Marine-Motorcycle/dp/B005GSFK6U
But these are passive devices, right? As long as I keep the current within the correct values, shouldn't it work with no problems?
-Don
rickofudall
Posted: Thu Mar 06, 2014 8:01 pm Post subject: 24v aux power port? |
It's just a couple of contacts. As long as you keep the amps from melting them, why would voltage matter?
Rick Girard
On Thu, Mar 6, 2014 at 9:07 PM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
ceengland7(at)gmail.com Guest
Posted: Thu Mar 06, 2014 8:27 pm Post subject: 24v aux power port? |
Risk of a passenger trying to power a 12 V device on the 24 V supply?
[quote] On Mar 6, 2014, at 10:00 PM, Richard Girard <aslsa.rng(at)gmail.com> wrote:
Rick Girard
> On Thu, Mar 6, 2014 at 9:07 PM, donjohnston <don(at)velocity-xl.com> wrote:
> For example:
> -Don
> http://forums.matronics.com/viewtopic.php?p=419895#419895
> -List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
loboflyer(at)gmail.com Guest
Posted: Thu Mar 06, 2014 8:34 pm Post subject: 24v aux power port? |
Using a lighter socket on a 24V system is possible, but invites disaster. I did a quick survey around the house and while most of the lighter socket plugs I found work with 24Vdc, it would be my luck that I'd find one that didn't, the hard way (for example, my ham radio HT which takes 16.8V max). Have you considered using a 24-12V DC-DC converter wired up behind the socket, or do you need 24V for accessories?
-Jeff-
On Thu, Mar 6, 2014 at 8:07 PM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
[quote]--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
For example:
-Don
le, List Admin.
donjohnston
Joined: 28 Mar 2008 Posts: 1948 Location: Riley TWP Michigan
rickofudall
Posted: Fri Mar 07, 2014 6:30 am Post subject: 24v aux power port? |
Label it clearly, make sure it's isolated from any other circuit, and control what your passengers bring into the aircraft.
Rick
On Thu, Mar 6, 2014 at 10:26 PM, Charlie E <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | Risk of a passenger trying to power a 12 V device on the 24 V supply?
On Mar 6, 2014, at 10:00 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
| Quote: | It's just a couple of contacts. As long as you keep the amps from melting them, why would voltage matter?
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
donjohnston
Posted: Fri Mar 07, 2014 8:46 am Post subject: Re: 24v aux power port? |
Kind of hard to plug my Garmin 396 into that.
Posted: Fri Mar 07, 2014 4:39 pm Post subject: 24v aux power port? |
To answer your original question, the lighter jack you mentioned should work with 24V. Typically voltage ratings are either (1) for safety reasons, where it is easy to stick a finger in and get a shock, or (2) for dielectric withstanding/arcing. 12 to 24V isn't enough to trigger either restriction. While alternatives have been suggested, fuse it properly and you'll be fine.
-Jeff-
On Fri, Mar 7, 2014 at 9:46 AM, donjohnston <don(at)velocity-xl.com (don(at)velocity-xl.com)> wrote:
user9253 wrote:
> How about installing two DC power outlets, one for 24 volts and one for 12 volts? One like this can be used for 24 volts without the danger of a 12 volt device being plugged into it. http://www.mouser.com/ProductDetail/Switchcraft/712A/?qs=sGAEpiMZZMv1TUPJeFpwbvDLoO7VplWmGzPCelncVas%3d
http://forums.matronics.com/viewtopic.php?p=419922#419922
le, List Admin.
donjohnston
