kelmonroe(at)comcast.net Guest
Posted: Sat Mar 15, 2014 4:30 pm Post subject: Canopy |
I have installed canopy glass in 2 CJ's. The glass came from Desser Tire. Has anyone installed canopy glass from LP Aero Plastics?
Thanks Kelley
wlannon(at)shaw.ca Guest
Posted: Sat Mar 15, 2014 5:35 pm Post subject: Canopy |
Hi Kelley;
I have installed the LP glass - twice on CJ’s. Very good product.
Was not aware that Desser handled plexiglas.
Walt
Sent: Saturday, March 15, 2014 5:29 PM
Subject: Canopy
Thanks Kelley
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
byronmfox(at)gmail.com Guest
Posted: Sat Mar 15, 2014 5:45 pm Post subject: Canopy |
We have an LP Malcomb hood on our CJ. Very pleased with it.
Blitz Fox415-307-2405
On Mar 15, 2014, at 6:34 PM, "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
[quote] Hi Kelley;
Walt
Subject: Canopy
Thanks Kelley
N13472(at)aol.com Guest
Posted: Sat Mar 15, 2014 6:11 pm Post subject: Canopy |
Walt, Desser now owns Cee bailey
Tom Elliott
CJ-6A NX63727
777 Quartz Ave
PMB 7004
Sandy Valley NV
89019
Cell 541-297-5497
N13472(at)AOL.COM
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Walter Lannon
Sent: Saturday, March 15, 2014 6:35 PM
To: yak-list(at)matronics.com
Subject: Re: Canopy
Hi Kelley;
Walt
Subject: Canopy
Thanks Kelley
0123456789012
Checked by AVG - www.avg.com
Version: 2014.0.4336 / 03/15/14
airmanv2
Joined: 01 Dec 2013 Posts: 49 Location: France - Normandy
Posted: Sat Mar 15, 2014 11:56 pm Post subject: Re: Canopy |
Hello,
Have you a tuto to explain how to remove the front moving canopy?
I have a little problem to fix on the center one and i can't have access .
Bruno
_________________ Fly safe |
Posted: Sun Mar 16, 2014 8:55 am Post subject: Canopy |
Desser now owns C. Baileys.
Dennis
Sent: Saturday, March 15, 2014 8:34 PM
Subject: Re: Canopy
Hi Kelley;
Walt
Subject: Canopy
Thanks Kelley
http://www.matrolow" target="_blank" href="http://forums.matronics.com/">http://forums.= --> [b]
Posted: Sun Mar 16, 2014 9:28 am Post subject: Canopy |
Hi;
I will assume you are referring to the CJ6 canopy and not the Yak 52,etc.
They MAY be the same but I don't really know.
So, to remove the front slider on the CJ6:
There are 3 bearings on each side riding in the tracks. Those bearings
will remain in the track with the canopy removed.
| Quote: | From inside the cockpit locate a hole on each side of the slider track area
(bottom) closer to the aft end. Holes approx. 8-9 mm (5/16-11/32") in dia.
These are screwdriver access holes to the head of the bearing retaining
screws.
There is a special wrench to remove the oval shaped nut from each screw. I
would assume Doug Sapp will have that. You need it.
You also need a blade type screwdriver either brand new or in perfect
condition with the following features:
Blade width approx. 7 to 8 mm, blade thickness 0.5 to 0.75 mm (0.020 to
0.030 ins.) at screw contact. If you can't find one this thin carefully
grind one to fit.
| Quote: | From here it is a two man operation.
One in the cockpit to line up each bearing screw to the access hole and hold
the head with the screwdriver while the nut is removed.
With all 6 nuts & washers removed, one man on each side to, ONE SIDE AT A
TIME, spring the canopy frame clear of the bearing bolts and remove.
Walt
airmanv2
Posted: Sun Mar 23, 2014 1:47 pm Post subject: Re: Canopy |
Hi Walt,
I've done it today,
thank you for help
Bruno
