		kelmonroe(at)comcast.net Guest
				 Posted: Sat Mar 15, 2014 4:30 pm    Post subject: Canopy |
				I have installed canopy glass in 2 CJ's.  The  glass came from Desser Tire.  Has anyone installed canopy glass from  LP Aero Plastics?
  Thanks Kelley
		wlannon(at)shaw.ca Guest
				 Posted: Sat Mar 15, 2014 5:35 pm    Post subject: Canopy |
				Hi Kelley;
  I have installed the LP glass -  twice on CJ’s.   Very good  product.
  Was not aware that Desser handled plexiglas.
  Walt
  Sent: Saturday, March 15, 2014 5:29 PM
  Subject: Canopy
  Thanks Kelley
 href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
		byronmfox(at)gmail.com Guest
				 Posted: Sat Mar 15, 2014 5:45 pm    Post subject: Canopy |
				We have an LP Malcomb hood on our CJ. Very pleased with it.
 Blitz Fox415-307-2405
 On Mar 15, 2014, at 6:34 PM, "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
 [quote]        Hi Kelley;
  Walt
  Subject: Canopy
  Thanks Kelley
		N13472(at)aol.com Guest
				 Posted: Sat Mar 15, 2014 6:11 pm    Post subject: Canopy |
				Walt, Desser now owns Cee bailey
 Tom Elliott
 CJ-6A NX63727
 777 Quartz Ave
 PMB 7004
 Sandy Valley NV
 89019
 Cell 541-297-5497
 N13472(at)AOL.COM
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Walter Lannon
 Sent: Saturday, March 15, 2014 6:35 PM
 To: yak-list(at)matronics.com
 Subject: Re: Canopy
 Hi Kelley;
 Walt
 Subject: Canopy
 Thanks Kelley
 0123456789012
 Checked by AVG - www.avg.com
 Version: 2014.0.4336 / 03/15/14
		airmanv2
  Joined: 01 Dec 2013 Posts: 49 Location: France - Normandy
				 Posted: Sat Mar 15, 2014 11:56 pm    Post subject: Re: Canopy |
				Hello,
 Have you a tuto to explain how to remove the front moving canopy?
 I have a little problem to fix on the center one  and i can't have access .
 Bruno
  _________________ Fly safe |
				 Posted: Sun Mar 16, 2014 8:55 am    Post subject: Canopy |
				Desser now owns C. Baileys.
 Dennis
  Sent: Saturday, March 15, 2014 8:34 PM
  Subject: Re: Canopy
           Hi Kelley;
  Walt
  Subject: Canopy
  Thanks Kelley
 http://www.matrolow" target="_blank" href="http://forums.matronics.com/">http://forums.=   --> [b]
				 Posted: Sun Mar 16, 2014 9:28 am    Post subject: Canopy |
				Hi;
 I will assume you are referring to the CJ6 canopy and not the Yak 52,etc.
 They MAY be the same but I don't really know.
 So, to remove the front slider on the CJ6:
 There are 3 bearings on each side riding in the tracks.   Those bearings
 will remain in the track with the canopy removed.
  	  | Quote: | 	 		  From inside the cockpit locate a hole on each side of the slider track area
 (bottom) closer to the aft end.   Holes approx. 8-9 mm (5/16-11/32") in dia.
 These are screwdriver access holes to the head of the bearing retaining
 screws.
 There is a special wrench to remove the oval shaped nut from each screw.  I
 would assume Doug Sapp will have that.  You need it.
 You also need a blade type screwdriver either brand new or in perfect
 condition with the following features:
 Blade width approx. 7 to 8 mm, blade thickness  0.5 to 0.75 mm (0.020 to
 0.030 ins.) at screw contact.  If you can't find one this thin carefully
 grind one to fit.
  	  | Quote: | 	 		  From here it is a two man operation.
 One in the cockpit to line up each bearing screw to the access hole and hold
 the head with the screwdriver while the nut is removed.
 With all 6 nuts & washers removed,  one man on each side to, ONE SIDE AT A
 TIME,  spring the canopy frame clear of the bearing bolts and remove.
 Walt
		airmanv2
				 Posted: Sun Mar 23, 2014 1:47 pm    Post subject: Re: Canopy |
				Hi Walt,
 I've done it today,
 thank you for help
 Bruno
