airmanv2
Joined: 01 Dec 2013 Posts: 49 Location: France - Normandy
Posted: Sun Jul 06, 2014 11:47 pm Post subject: UK CJ6 mods' |
hello,
The workshop "Vintage Aero" at Pent Farm had installed for me the automotive plug provided by Dennis Savarese. To do that they had to request for a mod at the CAA-UK. It was the first Automotive Kit plug installed on a uk registered CJ6.
Work is done and engine run fine. Very good job.
My questions are: if i have an engine problem and need a new one to replace it , it will be quite impossible to find a Housai 285HP with low time or just overhaul.
It will be probably more easy and not more expensive to replace it by a M14 360HP. (engine+Prop+exhaust) ?
Is some body know if there is an M14 engine on the other UK registered CJ6?
If the exchange was made in UK, did a Mod was requested to the CAA-UK? Kind regards
Bruno
_________________ Fly safe |
Harv
Posted: Mon Jul 07, 2014 1:32 am Post subject: Re: UK CJ6 mods' |
Bruno
Good work with the plug kit, that's a first for UK Changs, though I'm not sure how much improvement it will make over a good stock system. Maybe cleaner starts but and less fouling, but not more hp.
There are no MP14 powered CJ6's on the UK register (fairly confident of that) so would be interested to see how you get on if you plan to convert. Does your engine need an overhaul?
Whats the benefit of fitting the stock mp14 engine?
Rgs
Harv
cjpilot710(at)aol.com Guest
Posted: Mon Jul 07, 2014 4:42 am Post subject: UK CJ6 mods' |
Bruno & Harv,
For us guys here in the US the auto plugs and the harness are MUCH better. Auto plugs are a whole lot cheaper and easier to find. They make no different in horse power. I've found that they can foul up but no more than the regular ones.
I had a 260hp HS-6 when first got my CJ. My rate of climb was 833 ft/m. I put in the M14 and it went to 2,500 ft/m. Cruise went up about 7 kts but of course she was burning more. The real advantage is rate of climb and a lot more vertical in acro.
I really don't envy you UK guys and the restrictive rules you have over there.
Jim "Pappy" Goolsby
In a message dated 7/7/2014 5:33:28 A.M. Eastern Daylight Time, martin.harvey(at)kbr.com writes:
| Quote: | --> Yak-List message posted by: "Harv" <martin.harvey(at)kbr.com>
Bruno
Rgs
Harv
http://forums.matronics.com/viewtopic.php?p=426230#426230
jay-dub
Posted: Tue Jul 08, 2014 12:05 pm Post subject: Re: UK CJ6 mods' |
I reckon you have two hopes of getting the M14P approved for the CJ-6 in the UK. No hope and Bob Hope .... and Bob's dead.
_________________ CJ owner |
jblake207(at)comcast.net Guest
Posted: Tue Jul 08, 2014 1:26 pm Post subject: UK CJ6 mods' |
Now that's funny! JB
To: "Yak-List" <yak-list(at)matronics.com>
Sent: Tuesday, July 8, 2014 3:05:38 PM
Subject: Re: UK CJ6 mods'
--> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com>
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=426320#426320
; -Mat===============
richard.goode(at)russiana Guest
Posted: Tue Jul 08, 2014 11:17 pm Post subject: UK CJ6 mods' |
Having fought these bureaucratic issues with different aviation authorities
I would say that your pessimism is not totally merited.
UK aviation law is controlled by the Air Navigation Order, and in the end
this is the only legislation that counts. In essence it says "If a
non-type-certificated aircraft is airworthy then the CAA shall (which
legally means must, in my view) give the aircraft a Permit to Fly". A UK
"Permit" is effectively the equivalent of the US "experimental" category.
However, what is curious is that one then needs a look in the BCARs, which
are effectively our CAA's interpretation of the law, and in which they do
not define "airworthy" in any obvious way, such as saying that the aircraft
has been built in certain numbers; has been approved by certain authorities;
has been flown by a CAA test pilot or whatever. Instead they say an aircraft
is airworthy if (and only if it falls into one of a number of categories
such as a home-built of an approved sort; a recognised "classic" aircraft
and if it is "ex-military". It is the latter category that allows us to fly
Yaks and CJs, since we were able to demonstrate to the CAA that these
aircraft were clearly operated by their respective air forces.
Knowing how the authorities work, I would suggest that there is a certain
chance that a CJ-6 powered by M 14 P is no longer considered as an original
ex-military aircraft, but this gives scope for negotiation and discussion.
More importantly, there is obviously the ability to go back to the basic
legislation, and to demonstrate "airworthiness" in a more obvious and
practical fashion.
So I would say that all is not lost, and that is worth fighting. I have
taken this issue up previously with UK CAA, and individuals there have
privately admitted to me that their interpretation of the ANO is a curious
one, and that they can see the potential for someone to challenge this,
demanding a more practical definition of "airworthy". And if you can prove
that an aircraft is airworthy, then it must be given a permit!
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
jan.mevis(at)informavia.b Guest
Posted: Tue Jul 08, 2014 11:43 pm Post subject: UK CJ6 mods' |
So one proof might be that a CJ-6 with an M14P is considered to be
airworthy by another CAA?
Unless airworthiness "stops" at the border of a country (that's what the
Dutch CAA says today).
Anyway, struggling with aviation authorities remains difficult and time
consuming, everywhere.
We never would have had the aviation that we know today, with the
mentality and the attitude of today's civil servants.
BR,
Jan
On 09/07/14 09:16, "Richard Goode" <richard.goode(at)russianaeros.com> wrote:
authorities
aircraft
authorities;
aircraft
fly
original
practical fashion.
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Harv
