		airmanv2
  Joined: 01 Dec 2013 Posts: 49 Location: France - Normandy
				 Posted: Sun Jul 06, 2014 11:47 pm    Post subject: UK CJ6 mods' |
				hello,
 The workshop "Vintage Aero" at Pent Farm had installed for me the automotive plug provided by Dennis Savarese. To do that they had to request for a mod at the CAA-UK. It was the first Automotive Kit plug installed on a uk registered CJ6.
 Work is done and engine run fine. Very good job.
 My questions are: if i have an engine problem and need a new one to replace it , it will be quite impossible to find a Housai 285HP with low time or just overhaul.
 It will be probably more easy and not more expensive  to replace it by a M14 360HP. (engine+Prop+exhaust) ?
 Is some body know if there is an M14 engine on the other UK registered CJ6?
 If the exchange was made in UK, did a Mod  was requested to the CAA-UK? Kind regards
 Bruno
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Fly safe |
		Harv
				 Posted: Mon Jul 07, 2014 1:32 am    Post subject: Re: UK CJ6 mods' |
				Bruno
 Good work with the plug kit, that's a first for UK Changs, though I'm not sure how much improvement it will make over a good stock system. Maybe cleaner starts but and less fouling, but not more hp.
 There are no MP14 powered CJ6's on the UK register (fairly confident of that) so would be interested to see how you get on if you plan to convert. Does your engine need an overhaul?
 Whats the benefit of fitting the stock mp14 engine?
 Rgs
 Harv
		cjpilot710(at)aol.com Guest
				 Posted: Mon Jul 07, 2014 4:42 am    Post subject: UK CJ6 mods' |
				Bruno & Harv,
  For us guys here in the US the auto plugs and the harness are MUCH  better.  Auto plugs are a whole lot cheaper and easier to find.  They  make no different in horse power.  I've found that they can foul up but no  more than the regular ones.
  I had a 260hp HS-6 when first got my CJ.  My rate of climb was 833  ft/m.  I put in the M14 and it went to 2,500 ft/m.  Cruise went up  about 7 kts but of course she was burning more.  The real advantage is rate  of climb and a lot more vertical in acro.
  I really don't envy you UK guys and the restrictive rules you have over  there.
  Jim "Pappy" Goolsby
   In a message dated 7/7/2014 5:33:28 A.M. Eastern Daylight Time,  martin.harvey(at)kbr.com writes:
   	  | Quote: | 	 		  -->    Yak-List message posted by: "Harv"    <martin.harvey(at)kbr.com>
 Bruno
 Rgs
 Harv
 Read    this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=426230#426230
		jay-dub
				 Posted: Tue Jul 08, 2014 12:05 pm    Post subject: Re: UK CJ6 mods' |
				I reckon you have two hopes of getting the M14P approved for the CJ-6 in the UK. No hope and Bob Hope .... and Bob's dead.
  _________________ CJ owner |
		jblake207(at)comcast.net Guest
				 Posted: Tue Jul 08, 2014 1:26 pm    Post subject: UK CJ6 mods' |
				Now that's funny!  JB
 To: "Yak-List" <yak-list(at)matronics.com>
 Sent: Tuesday, July 8, 2014 3:05:38 PM
 Subject: Re: UK CJ6 mods'
 --> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com>
 CJ and Yak-52 owner
 http://forums.matronics.com/viewtopic.php?p=426320#426320
  ;                    -Mat===============
		richard.goode(at)russiana Guest
				 Posted: Tue Jul 08, 2014 11:17 pm    Post subject: UK CJ6 mods' |
				Having fought these bureaucratic issues with different aviation authorities
 I would say that your pessimism is not totally merited.
 UK aviation law is controlled by the Air Navigation Order, and in the end
 this is the only legislation that counts. In essence it says "If a
 non-type-certificated aircraft is airworthy then the CAA shall (which
 legally means must, in my view) give the aircraft a Permit to Fly". A UK
 "Permit" is effectively the equivalent of the US "experimental" category.
 However, what is curious is that one then needs a look in the BCARs, which
 are effectively our CAA's interpretation of the law, and in which they do
 not define "airworthy" in any obvious way, such as saying that the aircraft
 has been built in certain numbers; has been approved by certain authorities;
 has been flown by a CAA test pilot or whatever. Instead they say an aircraft
 is airworthy if (and only if it falls into one of a number of categories
 such as a home-built of an approved sort; a recognised "classic" aircraft
 and if it is "ex-military". It is the latter category that allows us to fly
 Yaks and CJs, since we were able to demonstrate to the CAA that these
 aircraft were clearly operated by their respective air forces.
 Knowing how the authorities work, I would suggest that there is a certain
 chance that a CJ-6 powered by M 14 P is no longer considered as an original
 ex-military aircraft, but this gives scope for negotiation and discussion.
 More importantly, there is obviously the ability to go back to the basic
 legislation, and to demonstrate "airworthiness" in a more obvious and
 practical fashion.
 So I would say that all is not lost, and that is worth fighting. I have
 taken this issue up previously with UK CAA, and individuals there have
 privately admitted to me that their interpretation of the ANO is a curious
 one, and that they can see the potential for someone to challenge this,
 demanding a more practical definition of "airworthy". And if you can prove
 that an aircraft is airworthy, then it must be given a permit!
 Richard Goode Aerobatics
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
 Tel:  +44 (0) 1544 340120
 Fax: +44 (0) 1544 340129
 www.russianaeros.com
		jan.mevis(at)informavia.b Guest
				 Posted: Tue Jul 08, 2014 11:43 pm    Post subject: UK CJ6 mods' |
				So one proof might be that a CJ-6 with an M14P is considered to be
 airworthy by another CAA?
 Unless airworthiness "stops" at the border of a country (that's what the
 Dutch CAA says today).
 Anyway, struggling with aviation authorities remains difficult and time
 consuming, everywhere.
 We never would have had the aviation that we know today, with the
 mentality and the attitude of today's civil servants.
 BR,
 Jan
 On 09/07/14 09:16, "Richard Goode" <richard.goode(at)russianaeros.com> wrote:
 authorities
 aircraft
 authorities;
 aircraft
 fly
 original
 practical fashion.
 Rhodds Farm
 Lyonshall
 Hereford
 HR5 3LW
		Harv
