How long does your annual take?
rv10rob(at)gmail.com
PostPosted: Fri May 01, 2015 7:24 pm    Post subject: How long does your annual take? Reply with quote
I'm curious how long (on average) everyone spends on their annual (or condition inspection, for the pedantic).  I"m not including maintenance or upgrade deferred to annual time--just the inspection and tests.  I'm probably at a good day and a half, which extends to two full days if you include the oil change and a few other items.  Seems like a really long time, so curious if that's typical.
-Rob
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
Kelly McMullen
PostPosted: Fri May 01, 2015 7:48 pm    Post subject: How long does your annual take? Reply with quote
Well,
Not having done one on the 10 yet....
Before I got my A&P, used to do owner assisted annuals on a Cessna 170 in about 8 hours.
When I bought a Mooney, I would spend about 2 days, sign off 100 hour and take to IA, open everything back up for him to inspect, put it back together for total of about 6 hours where nothing was done but look inside inspection panels, check compression, timing and gear swing. Once I got my IA I did the annuals in maybe a day and half, but spread out a bit more because I wasn't paying anyone's labor and I had the time.
I expect the 10 will be 12-15 hours to do the first few. No gear to do much with besides nose gear tensions. But more to open up and inspect/maintain in terms of the tunnel, wheel pants and fairings, as well as more avionics.
Just spent an hour today showing an RV-8 owner how to update firmware and navdata on his new Skyview system.
I must be getting close to finishing...spending almost as much time fixing stuff and installing new stuff. One of my lift struts broke yesterday. Not confidence inspiring, since it was just holding the door open.
On Fri, May 1, 2015 at 8:20 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]I'm curious how long (on average) everyone spends on their annual (or condition inspection, for the pedantic).  I"m not including maintenance or upgrade deferred to annual time--just the inspection and tests.  I'm probably at a good day and a half, which extends to two full days if you include the oil change and a few other items.  Seems like a really long time, so curious if that's typical.
-Rob
Rob Kochman
Woodinville, WA
tp://forums.matronics.com
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Dave Saylor
PostPosted: Fri May 01, 2015 9:19 pm    Post subject: How long does your annual take? Reply with quote
Rob,
To pull all the fairings, open the tunnel, tailcone, wingtips, pull the interior, grease the wheel bearings, all the service stuff, etc, I'd say two days is pretty good.  I just finished the eighth one on mine and it took longer than that, but I had a few repair items, too:  nose gear SB and changed the engine dampers, changed a caliper oring, replaced the EFIS battery.  All that was about 30 hours.
--Dave
-Rob
Rob Kochman
Woodinville, WA
--Dave
KWVI
n223rv(at)wolflakeairport
PostPosted: Fri May 01, 2015 9:22 pm    Post subject: How long does your annual take? Reply with quote
When I do mine, it takes a good weekend plus a few nights.... That includes removal of all panels, oil change, etc....
Two days is a little short in my experience.....
On May 1, 2015, at 11:20 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
-Rob
Rob Kochman
Woodinville, WA
List"">http://www.matronics.com/Navigator?RV10-List
jesse(at)saintaviation.co
PostPosted: Sat May 02, 2015 3:37 am    Post subject: How long does your annual take? Reply with quote
I've done probably 30 condition inspections on -10's. If I have an extra set of hands or two, I can do it in a solid day. Alone, it takes two days. As others have said, a good bit of time is spent just removing panels and fairings. The worst part of the job is greasing the wheel bearings, which takes a lot of time and is usually a very messy job.
The -10 takes more time, probably, than a Cherokee 235 I just did. The Cherokee just doesn't have that many inspection panels, so there are a lot of areas you can't inspect well. On the -10, for a thorough inspection, you need to remove about 1,000 screws, it seems like. Just removing the fairings and putting them back on is half the inspection time, probably.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Sent from my iPad
-Rob
Rob Kochman
Woodinville, WA
rene(at)felker.com
PostPosted: Sat May 02, 2015 6:32 am    Post subject: How long does your annual take? Reply with quote
By myself, I might get it done in 16 hours.  But it is hard to measure since I always have something to do on my to do list and while I have all the fairings off I clean and wax them, etc.  And of course, you are doing this at an airport, so everybody visits when they see your car………one of the more enjoyable aspects of “working” at the airport.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Friday, May 01, 2015 9:21 PM
To: rv10-list
Subject: How long does your annual take?
-Rob
Rob Kochman
Woodinville, WA
Rocketman1988
PostPosted: Sat May 02, 2015 10:44 am    Post subject: Re: How long does your annual take? Reply with quote
This is an interesting thread to get a general idea.
I would say, though, that it takes as long as it needs to. When you are satisfied that everything is done to your liking, then it is done. It isn't a race...
AirMike
PostPosted: Sun May 03, 2015 1:53 pm    Post subject: How long does your annual take? Reply with quote
I usually figure three full days (24 hrs), but I am old - fat - and slow. Really though I try to do a very thorough job. I do the wheel bearings every other year. I also clean and polish everything when it is apart. I have the A&P 2x check my engine work - this is really important to me as they look at this stuff all the time. This year he caught a nut on the alternator missing. There is almost always a squak that needs extra time, example are fuel leaks, cranky electronics, static check, wheel pant damage, worn out tires, new brake linings, buggered/stuck screw, etc.
See you OSH '18
Q/B - sold.
Mike Whisky
PostPosted: Mon May 04, 2015 3:27 am    Post subject: Re: How long does your annual take? Reply with quote
My first 100h check took almost four days but included some fixes and the nose gear SB. Removing and installing all the panels exterior and interior eats time. I plan for three days.
Mike
RV-10 builder (flying)
#511
PostPosted: Mon May 04, 2015 12:53 pm    Post subject: How long does your annual take? Reply with quote
Thanks, everyone... glad it's not just me. I think the right long-term
solution is for my kids to grow up to the point they can turn a screwdriver
Kellym
PostPosted: Mon May 04, 2015 1:07 pm    Post subject: How long does your annual take? Reply with quote
A power screwdriver with adjustable torque works wonders. Just be sure
to break free each screw 1/8 of turn or so before applying power.
long-term solution is for my kids to grow up to the point they can
turn a screwdriver.
On Sat, May 2, 2015 at 7:29 AM, Rene <rene(at)felker.com
Rene'
801-721-6080 <tel:801-721-6080>
<mailto:owner-rv10-list-server(at)matronics.com>
<mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of *Rob
Kochman
*Sent:* Friday, May 01, 2015 9:21 PM
*To:* rv10-list
*Subject:* How long does your annual take?
that's typical.
-Rob
Rob Kochman
Woodinville, WA
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*http://www.matronics.com/contribution*
Rob Kochman
Woodinville, WA
Kelly McMullen
KCHD
PostPosted: Mon May 04, 2015 2:25 pm    Post subject: How long does your annual take? Reply with quote
I put my 12-year-old to work one day per week already. He's perfect for opening panels and for crawling in the tailcones for inspection, lubrication and fabrication. I've even used my 8-year-old a few times.
Jesse Saint
352-427-0285
Sent from my iPad
On May 4, 2015, at 4:50 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]Thanks, everyone... glad it's not just me.  I think the right long-term solution is for my kids to grow up to the point they can turn a screwdriver.
On Sat, May 2, 2015 at 7:29 AM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
Rene'
[url=tel:801-721-6080]801-721-6080[/url]
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kochman
To: rv10-list
-Rob
Rob Kochman
Woodinville, WA
Rob Kochman
Woodinville, WA
neal.george(at)gmail.com
PostPosted: Mon May 04, 2015 6:39 pm    Post subject: How long does your annual take? Reply with quote
Yeah... There's the key.
Break them loose by hand before applying power. If the bit slips, even once, toss it and mount a new one. Toss any screw with ANY damage to the drive recess. Then, Boelube or ACS-50 on the threads before re-assembly.
Run the screws in with the screw gun clutch set to its minimum torque and finish by hand...
Neal George
On May 4, 2015, at 4:03 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
A power screwdriver with adjustable torque works wonders. Just be sure to break free each screw 1/8 of turn or so before applying power.
> On Sat, May 2, 2015 at 7:29 AM, Rene <rene(at)felker.com <mailto:rene(at)felker.com>> wrote:
> Rene'
> *From:*owner-rv10-list-server(at)matronics.com
> Kochman
> *To:* rv10-list
> that's typical.
> -Rob
> Rob Kochman
> Woodinville, WA
> _blank">http://www.matronics.com/contribution
> Rob Kochman
> Woodinville, WA
Kellym
PostPosted: Mon May 04, 2015 6:49 pm    Post subject: How long does your annual take? Reply with quote
Agreed. Liquid BoeLube is excellent for reducing torque needed to run
screws into nut plates.
Neal George
>> Rene'
>> Kochman
>> *To:* rv10-list
>> that's typical.
>> -Rob
>> Rob Kochman
>> Woodinville, WA
>> Rob Kochman
>> Woodinville, WA
Kelly McMullen
KCHD
glastar(at)gmx.net
PostPosted: Mon May 04, 2015 11:58 pm    Post subject: How long does your annual take? Reply with quote
Jesse, seems you're using your kids like others swap wrenches from one
job to the other Smile
Cheers Werner
bwestfall
PostPosted: Tue May 05, 2015 7:22 am    Post subject: How long does your annual take? Reply with quote
And he's well stocked for years to come!! Smile
-Ben
