		rv10rob(at)gmail.com Guest
				 Posted: Fri May 01, 2015 7:24 pm    Post subject: How long does your annual take? |
				I'm curious how long (on average) everyone spends on their annual (or condition inspection, for the pedantic).  I"m not including maintenance or upgrade deferred to annual time--just the inspection and tests.  I'm probably at a good day and a half, which extends to two full days if you include the oil change and a few other items.  Seems like a really long time, so curious if that's typical.
 -Rob
 Rob Kochman
 RV-10 Flying since March 2011
  Woodinville, WA
  http://kochman.net/N819K
		Kelly McMullen
				 Posted: Fri May 01, 2015 7:48 pm    Post subject: How long does your annual take? |
				Well,
 Not having done one on the 10 yet....
 Before I got my A&P, used to do owner assisted annuals on a Cessna 170 in about 8 hours.
 When I bought a Mooney, I would spend about 2 days, sign off 100 hour and take to IA, open everything back up for him to inspect, put it back together for total of about 6 hours where nothing was done but look inside inspection panels, check compression, timing and gear swing. Once I got my IA I did the annuals in maybe a day and half, but spread out a bit more because I wasn't paying anyone's labor and I had the time.
 I expect the 10 will be 12-15 hours to do the first few. No gear to do much with besides nose gear tensions. But more to open up and inspect/maintain in terms of the tunnel, wheel pants and fairings, as well as more avionics.
 Just spent an hour today showing an RV-8 owner how to update firmware and navdata on his new Skyview system.
 I must be getting close to finishing...spending almost as much time fixing stuff and installing new stuff. One of my lift struts broke yesterday. Not confidence inspiring, since it was just holding the door open.
 On Fri, May 1, 2015 at 8:20 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
 [quote]I'm curious how long (on average) everyone spends on their annual (or condition inspection, for the pedantic).  I"m not including maintenance or upgrade deferred to annual time--just the inspection and tests.  I'm probably at a good day and a half, which extends to two full days if you include the oil change and a few other items.  Seems like a really long time, so curious if that's typical.
 -Rob
 Rob Kochman
  Woodinville, WA
 tp://forums.matronics.com
  | 	  [b]
A&P/IA, EAA Tech Counselor
KCHD |
		Dave Saylor
				 Posted: Fri May 01, 2015 9:19 pm    Post subject: How long does your annual take? |
				Rob,
 To pull all the fairings, open the tunnel, tailcone, wingtips, pull the interior, grease the wheel bearings, all the service stuff, etc, I'd say two days is pretty good.  I just finished the eighth one on mine and it took longer than that, but I had a few repair items, too:  nose gear SB and changed the engine dampers, changed a caliper oring, replaced the EFIS battery.  All that was about 30 hours.
 --Dave
 -Rob
 Rob Kochman
  Woodinville, WA
  | 	  [b]
  _________________ --Dave
KWVI |
		n223rv(at)wolflakeairport Guest
				 Posted: Fri May 01, 2015 9:22 pm    Post subject: How long does your annual take? |
				When I do mine, it takes a good weekend plus a few nights....  That includes removal of all panels, oil change, etc....
 Two days is a little short in my experience.....
 On May 1, 2015, at 11:20 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
 -Rob
 Rob Kochman
  Woodinville, WA
 List"">http://www.matronics.com/Navigator?RV10-List
				 Posted: Sat May 02, 2015 3:37 am    Post subject: How long does your annual take? |
				I've done probably 30 condition inspections on -10's. If I have an extra set of hands or two, I can do it in a solid day. Alone, it takes two days. As others have said, a good bit of time is spent just removing panels and fairings. The worst part of the job is greasing the wheel bearings, which takes a lot of time and is usually a very messy job.
 The -10 takes more time, probably, than a Cherokee 235 I just did. The Cherokee just doesn't have that many inspection panels, so there are a lot of areas you can't inspect well. On the -10, for a thorough inspection, you need to remove about 1,000 screws, it seems like. Just removing the fairings and putting them back on is half the inspection time, probably.
 Jesse Saint
 Saint Aviation, Inc.
 352-427-0285
 Sent from my iPad
 -Rob
 Rob Kochman
  Woodinville, WA
		rene(at)felker.com Guest
				 Posted: Sat May 02, 2015 6:32 am    Post subject: How long does your annual take? |
				By myself, I might get it done in 16 hours.  But it is hard to measure since I always have something to do on my to do list and while I have all the fairings off I clean and wax them, etc.  And of course, you are doing this at an airport, so everybody visits when they see your car………one of the more enjoyable aspects of “working” at the airport.
 Rene'
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
 Sent: Friday, May 01, 2015 9:21 PM
 To: rv10-list
 Subject: How long does your annual take?
 -Rob
 Rob Kochman
 Woodinville, WA
  	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  01234567
		Rocketman1988
				 Posted: Sat May 02, 2015 10:44 am    Post subject: Re: How long does your annual take? |
				This is an interesting thread to get a general idea.
 I would say, though, that it takes as long as it needs to.  When you are satisfied that everything is done to your liking, then it is done.  It isn't a race...
		AirMike
				 Posted: Sun May 03, 2015 1:53 pm    Post subject: How long does your annual take? |
				I usually figure three full days (24 hrs), but I am old - fat - and slow. Really though I try to do a very thorough job. I do the wheel bearings every other year. I also clean and polish everything when it is apart. I have the A&P 2x check my engine work - this is really important to me as they look at this stuff all the time. This year he caught a nut on the alternator missing. There is almost always a squak that needs extra time, example are fuel leaks, cranky electronics, static check, wheel pant damage, worn out tires, new brake linings, buggered/stuck screw, etc.
  _________________ See you OSH '18
Q/B - sold. |
		Mike Whisky
				 Posted: Mon May 04, 2015 3:27 am    Post subject: Re: How long does your annual take? |
				My first 100h check took almost four days but included some fixes and the nose gear SB. Removing and installing all the panels exterior and interior eats time. I plan for three days.
 Mike
  _________________ RV-10 builder (flying)
#511 |
				 Posted: Mon May 04, 2015 12:53 pm    Post subject: How long does your annual take? |
				Thanks, everyone... glad it's not just me.  I think the right long-term
 solution is for my kids to grow up to the point they can turn a screwdriver
		Kellym
				 Posted: Mon May 04, 2015 1:07 pm    Post subject: How long does your annual take? |
				A power screwdriver with adjustable torque works wonders. Just be sure
 to break free each screw 1/8 of turn or so before applying power.
 On 5/4/2015 1:50 PM, Rob Kochman wrote:
  	  | Quote: | 	 		   Thanks, everyone... glad it's not just me.  I think the right
  long-term solution is for my kids to grow up to the point they can
  turn a screwdriver.
  On Sat, May 2, 2015 at 7:29 AM, Rene <rene(at)felker.com
      Rene'
      801-721-6080 <tel:801-721-6080>
      <mailto:owner-rv10-list-server(at)matronics.com>
      <mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of *Rob
      Kochman
      *Sent:* Friday, May 01, 2015 9:21 PM
      *To:* rv10-list
      *Subject:* How long does your annual take?
      that's typical.
      -Rob
      Rob Kochman
      Woodinville, WA
      *http://www.matronics.com/Navigator?RV10-List*
      *http://forums.matronics.com*
      *http://www.matronics.com/contribution*
  Rob Kochman
  Woodinville, WA
KCHD |
				 Posted: Mon May 04, 2015 2:25 pm    Post subject: How long does your annual take? |
				I put my 12-year-old to work one day per week already. He's perfect for opening panels and for crawling in the tailcones for inspection, lubrication and fabrication. I've even used my 8-year-old a few times.
 Jesse Saint
 352-427-0285
 Sent from my iPad
 On May 4, 2015, at 4:50 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
 [quote]Thanks, everyone... glad it's not just me. I think the right long-term solution is for my kids to grow up to the point they can turn a screwdriver.
 On Sat, May 2, 2015 at 7:29 AM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
 Rene'
 [url=tel:801-721-6080]801-721-6080[/url]
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob Kochman
 To: rv10-list
 -Rob
 Rob Kochman
 Woodinville, WA
 01234567
   8
 Rob Kochman
  Woodinville, WA
   9
		neal.george(at)gmail.com Guest
				 Posted: Mon May 04, 2015 6:39 pm    Post subject: How long does your annual take? |
				Yeah... There's the key.
 Break them loose by hand before applying power.  If the bit slips, even once, toss it and mount a new one. Toss any screw with ANY damage to the drive recess.  Then, Boelube or ACS-50 on the threads before re-assembly.
 Run the screws in with the screw gun clutch set to its minimum torque and finish by hand...
 Neal George
  	  | Quote: | 	 		   On May 4, 2015, at 4:03 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
  A power screwdriver with adjustable torque works wonders. Just be sure to break free each screw 1/8 of turn or so before applying power.
 > On Sat, May 2, 2015 at 7:29 AM, Rene <rene(at)felker.com <mailto:rene(at)felker.com>> wrote:
 >    Rene'
 >    *From:*owner-rv10-list-server(at)matronics.com
 >    Kochman
 >    *To:* rv10-list
 >    that's typical.
 >    -Rob
 >    Rob Kochman
 >    Woodinville, WA
 >    _blank">http://www.matronics.com/contribution
 > Rob Kochman
 > Woodinville, WA
		Kellym
				 Posted: Mon May 04, 2015 6:49 pm    Post subject: How long does your annual take? |
				Agreed. Liquid BoeLube is excellent for reducing torque needed to run
 screws into nut plates.
 On 5/4/2015 7:35 PM, Neal George wrote:
  Neal George
 >>     Rene'
 >>     Kochman
 >>     *To:* rv10-list
 >>     that's typical.
 >>     -Rob
 >>     Rob Kochman
 >>     Woodinville, WA
 >> Rob Kochman
 >> Woodinville, WA
KCHD |
		glastar(at)gmx.net Guest
				 Posted: Mon May 04, 2015 11:58 pm    Post subject: How long does your annual take? |
				Jesse, seems you're using your kids like others swap wrenches from one
 job to the other
 Cheers Werner
 On 05.05.2015 00:21, Jesse Saint wrote:
  	  | Quote: | 	 		   I put my 12-year-old to work one day per week already. He's perfect for
		bwestfall
  Joined: 22 Oct 2008 Posts: 131 Location: Portland, OR
