dlm34077(at)gmail.com Guest
Posted: Fri May 29, 2015 4:55 am Post subject: symmetrical panel and backup |
If you are seriously interested in backup for IFR in IMC, you need two
different EFIS systems and an autopilot with internal solid state gyros and
backup batteries. My solution is Chelton primary with FAA level A software;
GRT Sport/software (mini is now available) for backup and a Trutrak AP that
will also fly the aircraft albeit not extremely precisely. I have three 680s
on board although the last was added on the firewall more for weight and
balance purposes. In essence I have three systems all capable of keeping the
shiny side up. The AP can accept LNAV/VNAV commands from the Chelton, LNAV
commands from the GRT and fly the aircraft independently depending on a
source selection switch for the AP.
My two cents
http://www.avast.com
Kelly McMullen
Posted: Fri May 29, 2015 6:30 am Post subject: symmetrical panel and backup |
There are several "mini-EFIS" available today that were not on the market 7-8 yrs ago. Even if you select the same brand as the main EFIS, the operating software is different. You have to decide whether you want same logic or being able to know the ins and outs of two different brand philosophies, and whether you want more Tees in your pitot static system to leak, or a GPS derived attitude, altitude and airspeed as backup.
It appears the autopilot market has evolved to where the leading EFIS have integrated autopilots, and backup batteries for each screen. Having a separate autopilot generally adds several grand in cost. However, most autopilots, whether separate or integrated will fail if they don't have electrons to power them, as most use electric servos. One does have to decide whether to wear 2 belts and 1 or two suspenders to have enough backup.
On Fri, May 29, 2015 at 5:51 AM, DLM <dlm34077(at)gmail.com (dlm34077(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "DLM" <dlm34077(at)gmail.com (dlm34077(at)gmail.com)>
My two cents
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
wgreenley
Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
Posted: Fri May 29, 2015 6:46 am Post subject: symmetrical panel and backup |
Trying to figure out how to keep backups in perspective. While building my 10 I am still flying my ’56 Cessna 172. Flew home yesterday IFR. One engine, one alternator, one main ships battery. Two radios, one powering a VOR/ILS/LOC head, and one a VOR. Had a tablet GPS on the yoke, and a backup tablet in the bag, no auto pilot. I know pilots that have been flying like this for years, even before the portable GPS’s. Does it seem that we get a little carried away with backups? I am still trying to decide on a panel, but leaning towards two G3X’s, and a mini-B each with batteries, autopilot controlled by the G3X’s. No round dials. This seems like so much more backup than I have now, even still with one ships battery and alternator.
Bill Greenley
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Friday, May 29, 2015 10:27 AM
Subject: Re: symmetrical panel and backup
My two cents
FORUMS -
b Site -
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Fri May 29, 2015 6:54 am Post subject: symmetrical panel and backup |
I do have a TCW IBBS backup battery that will power the MFD (which will drop into reversionary mode), engine monitor, one of the adahrs (along with the mag and temp probe), and the autopilot panel. The AP servos are NOT powered by the backup battery, but the autopilot panel will give me a flight director, so I will become the "meat servo". The MFD is also an XM enabled unit, so I'll even still have weather and some good tunes incase I get bored during the emergency! The backup battery will only be needed after the primary alternator, secondary 30 amp alternator, and the main ships battery fail.
Additionally, if there is a CANBUS failure, the adahrs are both connected with a secondary RS232 connection to the PFD and MFD, helping me to keep the shiny side up.
I have thought a LOT about systems redundancy. As an IT Systems Admin, it's part of my day job. I've designed as many of the systems to have redundancy, sometimes even dual and triple redundancy, as practical. The last big piece is going to be having a completely different brand backup PFD. Like I said before, I'm leaning towards a battery operated, GPS derived, self contained unit like a Dynon D1, as it isn't dependent on ANY of the other systems in the plane, like power or pitot/static.
On Fri, May 29, 2015 at 9:26 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]There are several "mini-EFIS" available today that were not on the market 7-8 yrs ago. Even if you select the same brand as the main EFIS, the operating software is different. You have to decide whether you want same logic or being able to know the ins and outs of two different brand philosophies, and whether you want more Tees in your pitot static system to leak, or a GPS derived attitude, altitude and airspeed as backup.
| Quote: | --> RV10-List message posted by: "DLM" <dlm34077(at)gmail.com (dlm34077(at)gmail.com)>
My two cents
FORUMS -
b Site -
tp://forums.matronics.com
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
rene(at)felker.com Guest
Posted: Fri May 29, 2015 7:01 am Post subject: symmetrical panel and backup |
I agree that the landscape has changed since I made my panel decision 8 years ago. Then my backup was a Blue Mountain….when it crapped out I went to a third GRT screen…….then replaced that with a GRT sport. Different enough to solve the same technology problem, but yet runs just like my other GRT system and thus no learning curve or retraining time caused by two unique systems.
I also have three 2.5” steam gauges. With that I should be able to get out of the soup even if everything else goes tango uniform.
I have two batteries, but that was more to move the CG forward than the actual need for a second battery.
Rene'
801-721-6080
Sent: Friday, May 29, 2015 8:27 AM
My two cents
FORUMS -
b Site -
Tim Olson
Posted: Fri May 29, 2015 7:28 am Post subject: symmetrical panel and backup |
I think the answer is both Yes and No to your question:
"Does it seem that we get a little carried away with backups? "
There is one big difference with having old avionics
and new. With the old, you could, for instance, lose
your attitude indicator, but still keep the wings fairly
level with the turn coordinator. Things weren't so very
integrated. With EFIS's, it would be much easier to lose
a component and lost all or most of your data. If
your screen goes dark, you're now "lost". And, I would
venture to say that many or most pilots on a good day
won't be diligent enough to have things like a VOR
tuned in on a radio, while they are just flying using
their GPS. I once lost GPS (in my old plane) while
X/C on a sunny day, VFR, no clouds, but at the time
my only sure knowledge was that I was somewhere in
Tennessee, East of Memphis....because honestly hadn't
really been paying close attention to exactly where I was.
Being VFR it certainly wasn't an emergency, but suddenly
I was faced with "Where they heck exactly am I, so that
I can start replanning my route via something other
than "direct"? It gets your attention how reliant
you are on your primary tools.
Now, that doesn't necessarily mean you have to go all
out on backups. But I wouldn't want to be without
any, if you have an EFIS system.
Even for IFR flight though, I'm *mostly* comfortable
with the idea of more minimal backups. First, it's
of utmost importance to be able to keep the plane
upright, and headed in a consistent direction, even
if you don't know that direction exactly.
If you can do that, you're far better off.
Next, having an independent Nav/COM and indicator
that you can use to tune a VOR, would be a nice thing.
An ipad, if it isn't a GPS issue, could be a VERY nice
thing. But I don't think you need a ton more than that.
The fact is, you're best off at that point, laying
it all on the table and calling ATC and letting them
know you have an issue, and ask for their help.
With them giving you vectors, you can accomplish
a whole lot on minimal backups. It may not be
enough to get you to the runway in the lowest conditions,
but it may help a lot. But having an iPad with a
good EFB and enough backup equipment could get you through
most approaches I would believe....provided you have
enough primary gauges to keep the plane headed the
right direction.
One thing to keep in mind too...sometimes your backups
can be found in unusual places. I put in 3 round
gauges in my RV10, but now realized for the RV-14 that
2 of them are available on my engine monitor, which is
standalone. (Airspeed and Altitude and even VSI)
So, I really mostly need a good Attitude display.
The biggest problem I have with IFR is people who would say,
"I want to fly IFR but not 'HARD' IFR, only use it to
get through ceilings." As far as I'm concerned, getting
the rating and USING it, means staying proficient enough
that you should be able to perform all normal approaches
for your aircraft. Ceilings change, conditions change, and
if you're going to launch anywhere that takes you out of
sight of terra firma, you should be fully prepared to do
whatever it takes to bring you safely back. Having the
proper attitude about that, and staying proficient,
will be very important.
I did have an awesome fun IFR flight this weekend. It
would have been a pain without my EFIS. I think I could
have done it, but it would have been a much bigger
chore. I need to do a couple more practice approaches
soon, so I'll try them without the EFIS this time and
see if I can do it.
I did post a video of that flight if you're interested.
https://www.youtube.com/watch?v=ZFmZJVXUTd0
On 5/29/2015 9:41 AM, William Greenley wrote:
| Quote: | Trying to figure out how to keep backups in perspective. While building
Bill Greenley
Rocketman1988
Posted: Fri May 29, 2015 8:30 am Post subject: Re: symmetrical panel and backup |
Very well said.
I also agree that the "hard" IFR thing is misused. You really need to be proficient in any IFR situation. Also, your BEST friend in IFR is ATC. You should NEVER be afraid or embarrassed to use them.
Listening to everyone's opinion on what you HAVE to have to safely fly IFR really makes me chuckle. Have you guys looked at the ancient panels and systems in the airliners that carry you across the country and all over the world?
They just updated the database in my work jet...using a single sided floppy disk...it took almost a half an hour...
A plumber friend once told me something. He said, "The more complicated the plumbing is, the easier it is to stop it up." I think at some point, that statement applies here...
flyboy(at)gmail.com Guest
Posted: Fri May 29, 2015 9:01 am Post subject: symmetrical panel and backup |
Those old airliners may be ancient, but they're also very redundant. All the transport category aircraft I've ever flown have at least three fully independent sources of attitude information, at least two completely separate pitot-static systems with two air data computers, three altimeters, three air speed indicators... Sure, they may have no glass screens, and I flew plenty of turboprops across the country full of passengers using nothing but VOR/DME for navigation (often without an operable autopilot), but they were all designed so no single system failure on any of those planes would prove to be a major event.
I don't think I need the same level of redundancy in my RV-10, but I really do want something like the GRT mini (or even 3 round dials) in case the primary systems glitch. And I've seen enough bugs in the software and electronics of airliners (which are built and tested to much higher standards than whatever I'll be putting in my RV-10) to make me want options.
I know people do it all the time, but I'm just not comfortable flying IMC where the failure of a single vacuum pump can leave me shooting an approach with a turn coordinator and a whiskey compass. Sure, I trained for it; I would probably survive, but part of the reason for building my own plane is so that I can affordably have a little more redundancy than that.
Tim Olson
Posted: Fri May 29, 2015 10:47 am Post subject: symmetrical panel and backup |
The one thing I'd note is that when planning an EFIS system, yes,
there are times when it may be nice to have more than one
manufacturer in the panel for those primary gauges.
But, don't fall victim to going too far with that.
I would spend as much as you need to get your primary system
fully up to par and integrated. Then just add the 2nd system
as a more stand-alone device. The issue you will run into
sometimes is panel space. Don't sacrifice too much of your
panel space of what you want for the primary just to give it
to backups. And don't do something like pick one EFIS brand
for one side and one for the other side. You'll never be
as happy with how it all integrates. This isn't saying you
SHOULDN'T have backups or varied vendors, but just saying
not to short your primary for the purpose of having a bigger
backup. You can have all the backup you need without
all that much space taken up.
On 5/29/2015 11:59 AM, Berck E. Nash wrote:
| Quote: | Those old airliners may be ancient, but they're also very redundant.
me want options.
that.
Posted: Fri May 29, 2015 11:10 am Post subject: symmetrical panel and backup |
Tim: All good points, and no way I would split primary EFIS displays across vendors. The 3-screen 10" G3X touch system really does, I think, start to push the issue of it being possible to have the backup you want and the primary displays that you want. The 3 screen G3X just isn't going to leave enough room for something like the GRT-mini as a backup, which leaves me struggling a bit with the tradeoffs. I think the 3 screens are probably worth it for the primary use case, as a GRT-mini just takes up space without providing anything useful as long as the primary works. A 3rd G3X is going to be enormously useful every day, but I'm just not sure what to do as a backup in that case, short of deciding that 3 G3X's are probably good enough. And they probably are, but I keep going back to what happened to the F-22 when I envision software failures: http://www.dailytech.com/Lockheeds+F22+Raptor+Gets+Zapped+by+International+Date+Line/article6225.htm
Looking around at modern spam cans (Cessna 350, Mooney Acclaim, SR-22) , they all seem to be going with the 3 round gauges as backups...
On Fri, May 29, 2015 at 12:44 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
me want options.
that.
FORUMS -
b Site -
Posted: Fri May 29, 2015 11:35 am Post subject: symmetrical panel and backup |
Looking over this thread it seems to me that it might be worthwhile defining
the objectives before looking at solution sets.
For a flat screen approach I want:
- Devices that integrate for capability
- Devices that do not rely on any single input
- Two displays in the event that one dies, each from an independent power
feed
- Each display can perform any function
- Two independent ADAHRS modules (or similar capability)
- Enough redundancy in power to the panel that a single failure will not
turn everything dark (e.g. no Avionics Master switch, no single master relay
to the battery or multiple batteries feeding a common buss, etc.)
There are a boatload of ways to achieve the above objectives, some more
complex (and costly) than others. To Tim's point however, start off with
what you want for normal operations then see what it can/can't do for any
single failure mode that you can think of for the whole system. For the
things you find unacceptable design in a back up. The rest are managed.
I have two 10" displays, an analog airspeed and altimeter, two ADAHRS
modules, a second radio and two selectable ways to power each device. A
loss of any single component will support continued, but perhaps reduced
capability IFR flight. Example of a managed risk is if the Garmin 650 craps
out (as it already has) then I lose my certified IFR WAAS GPS and NAV. I'd
be relying on the EFIS standalone GPS system so not legal for IFR but
perfectly fine for getting me on the ground - after I do the required report
to ATC.
Carl
Tim Olson
Posted: Fri May 29, 2015 12:07 pm Post subject: symmetrical panel and backup |
Yeah, you added some good info. I'll expound on a couple more points.
First, and this may seem like an attack but it's not, and it may
seem like I'm biased because I'm a "don't have" guy, but I'm not.
But... I'm just not in the camp that thinks bigger glass is better.
At a certain point it just takes up more space. I have 3 screens
and they give PLENTY of visibility, for the pilot, to all 3
of them, and they are maybe what, 1/3 the size of the big 10" ones?
Much easier to fit in the panel that way and much easier to have
*effective* backups. And by that I mean not where you have to
have a backup instrument down by your fuel valve to be able to
fit one in. I think Garmin had it right with the original
G3X screens, personally. Those would be easy to fit into any
RV10 panel and have 3 screens.
But one very important addition I think is that if you are going for
a real complete backup solution, don't forget some of the details.
On my flight this last week, I had to do VTF for the ILS, and I
not only had my NAV1 used by my EFIS for displaying the ILS on the
EFIS, but I set NAV2 up as well, since it had been a while that
I did a real ILS (not for practice) and especially in low conditions.
I wanted that cross check with my Nav2. But what made it even
POSSIBLE is that I had a CDI in my panel. I know almost nobody
that seems to install a CDI anymore. But, it was a welcome
instrument on that approach. If you want to have a Nav2 and have
it be useable, you need at least a device that can display that
info. In my RV-14 panel I just didn't have the room, so I
won't have a CDI. That's Ok, I also won't have a NAV2. But that
really changes my abilities in some situations. When I was picking
through my approaches I could do, looking between 2 airports I
was going to be near, there was only one ILS, and I don't
remember for sure this detail but I don't think that there were
ANY other approaches at either airport that could bring you
lower than 300 or 400'. Ceilings were just below 300. GPS is
great, but at many airports you may not get the low approach
capability that you'd have with an ILS. So equip as appropriate.
Now in a backup situation, in my RV-14, if I lost my NAV,
I'd have been stuck and had to go somewhere else...and with 300'
ceilings there isn't much available. Time to hike it to another
airport maybe 30-45 minutes away.
Anyway, EFIS's are great, but don't overlook the other devices is
my main point. A Dynon/GRT/Blue Mountain/Whatever may be a good
backup to a point. But it may not give you everything. Or, if you
have 2 NAV radios, it may be that you want a mini-efis that can
display the CDI on it too. Just so many things to think about.
I was personally *considering* using a ipad with the Levil AHRS
as a backup instrument in the RV-14...but the caveat is that if
I depart on any flight where I may need it, I would have it
ready and running the whole flight. I'm not sure sure it's
a great backup for a whole panel, but it's all I had real good
space for other than what round gauges supply. And for that
matter, it's probably all I'd need. The comment about most
production planes using round gauges is a good one. They
go with those because they are a backup...and don't need to
be full featured. But your flight style will change if you
should be using them.
On 5/29/2015 2:32 PM, Carl Froehlich wrote:
feed
to ATC.
Carl
Posted: Fri May 29, 2015 1:14 pm Post subject: symmetrical panel and backup |
On Fri, May 29, 2015 at 2:03 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
But... I'm just not in the camp that thinks bigger glass is better. |
Interesting point. I'd just assumed from looking at them at OSH, that flying behind giant screens would be a much more pleasant experience. But I've zero personal experience flying with large screens, so I don't know. Have you flown anything with big screens? The small garmins have always looked way too cluttered to me, and some bigger screens seems to make that better. Personally, the only glass I've spent any time behind is the collins pro line 4 in the CRJ, which has laughably small CRT displays by today's standards. I never thought they seemed small, but there were 6 of them (you can really only see the 2 in front of you and the 2 in the center), and collins doesn't have the same cluttered look that Garmin does. If I'd been forced to have the engine instruments share with the MFD, I do think the screens would be way too small.
I want a plane that's comfortable to fly from either seat, as I'm likely to spend a lot of time with two pilots up front. (I'm also going to be doing instrument instruction with my build partner, and I'm somewhat greedy about wanting my own display over in the right seat.) I'd been thinking that a single 10" display in front of each pilot would be plenty, but the part that bothers me about that is a screen in front of the seat you're not sitting in is just too far away if one goes dark. Which means, do you switch seats, or crane your neck? A center screen would solve that problem.
The G3X Touch is also available with 7" screens, and 3 of those would certainly be good enough, and leave plenty of room for backups.... but 3 bigger screens seems even better.
I've still got well over a year before I have to start filling a panel (just starting on the fuel tanks now), but in the meantime I'm anxiously looking at what's out there.
Bob Turner
Posted: Fri May 29, 2015 2:36 pm Post subject: Re: symmetrical panel and backup |
My setup has a GRT 6.5" screen centered on tbe left seat, then the avionics, then a second 6.5" screen, so this last one is offset to the left for someone in the right seat. Easy for the left seat to use. I did it this way so the engine instruments, normally on screen 2, are in the same place as on the 182 I flew for many years, so it seems natural to me.
I have given instrument instruction, in actual, in someone else's -10, who had a similar set up. I had no problem looking across to the pilot's PFD; everything was quite readable.
re Tim and CDIs: I quite agree. I routinely do not use the GRT's primary PFD page. Instead, I split it with an electronic HSI. On an ILS the main CDI is showing localizer deviation, while an RMI needle shows the SL30's multiplexed VOR, for cross fixes, missed approach, whatever you need on a no-gps approach. If everything goes bad and I'm reduced to my battery powered D-6 and a hand held Sporty's VOR (so old that it just shows digital to/from bearings) I've found (under the hood) that this works quite well. The trick is to almost close your eyes and imagine the bearing as a needle on an ADF, and fly the approach as if it were an NDB. Of course, that presumes that you can fly NDB approaches!
_________________ Bob Turner
RV-10 QB |
Posted: Fri May 29, 2015 3:02 pm Post subject: symmetrical panel and backup |
What is a NDB? What is a ADF needle?
OK, I am trying to act young....but I am not..
I have never really used the HIS, maybe I should give it a try. I am flying
young eagles tomorrow at another airport tomorrow so I will have some
transit time to play around.
I got some formation and Acro demo/instruction in a friends RV-7 joining on
my partner flying the 10. He used the HSI view, but to be honest my head
was outside the airplane 99% of the time. What a great experience, I have
never done real formation before.
Rene'
801-721-6080
Rocketman1988
Posted: Sat May 30, 2015 7:39 am Post subject: Re: symmetrical panel and backup |
"... don't think I need the same level of redundancy in my RV-10, but I really do want something like the GRT mini..."
Exactly. I am current;y looking at an AFS EFIS with the GRT Mini backup. Seems like a good compromise. If the weather is so bad that I need triple redundant systems, then I will probably just delay a bit...or go on the airlines...
Kellym
Posted: Sat May 30, 2015 12:55 pm Post subject: symmetrical panel and backup |
What you choose for backup may be dependent on whether your pitot/static
lines run to ADAHRS in rear of plane (dynon Skyview) or if it is at the
instrument panel. The GRT mini requires hook up to those lines, and you
get benefit of actual airspeed and altitude. Dynon D1/D2 needs no
hookup, but only gives you GPS derived ground speed and GPS track and
GPS altitude.
All better than nothing, but not quite as good as barometric and pitot
derived numbers.
Huge change in redundancy from when I was flying in non-radar areas with
venturi powered gyros and electric turn coordinator, with single
nav/com/ils and single ADF.
That gave some blood pressure rise when the venturis iced up. Key word
is when, not if. Fortunately the old AN gyros would operate down to less
than 1" of vacuum, so you got warning when the vacuum started trending
below 4"
All with one alternator and one battery for electrons.
On 5/30/2015 8:39 AM, Rocketman1988 wrote:
http://forums.matronics.com/viewtopic.php?p=442808#442808
KCHD |
