		DAquaNut(at)aol.com Guest
				 Posted: Sun Jul 02, 2006 2:23 pm    Post subject: Lubricating control cables |
        Group,
    I am doing my 25 hour maintenance as in the Rotax manual. On page  10-2 line 14 ,under the maintenance schedule it says to lubricate the  control cables. Is this referring to the choke and throttle cables, or the  flying surface cables???  It has a #3 , beside it,  which says  according to manufacturers instruction. It is not clear to me what they are  suggesting to be oiled. What is the easiest way to lubricate the throttle and  choke cables as that is what I think they must mean?
                Ed
		Max Stanford
				 Posted: Sun Jul 02, 2006 5:20 pm    Post subject: Re: Lubricating control cables |
				Just think about it for 2 seconds.  Is your engine manufacturer going to make a recommendation of how often to inspect your flying surface cables, especially being that they have no idea what type of plane it will be installed in ?
 This one is a no brainer.
		Possum
				 Posted: Sun Jul 02, 2006 5:55 pm    Post subject: Lubricating control cables |
				At 06:22 PM 7/2/2006, you wrote:
        Group,
    I am doing my 25 hour maintenance as in the Rotax manual. On page 10-2 line 14 ,under the maintenance schedule it says to lubricate the control cables. Is this referring to the choke and throttle cables, or the flying surface cables???  It has a #3 , beside it,  which says according to manufacturers instruction. It is not clear to me what they are suggesting to be oiled. What is the easiest way to lubricate the throttle and choke cables as that is what I think they must mean?             |
    You can lubricate your choke and throttle cables without taking them off the carbs.
   Part # 7435
   CABLE LUBER SYSTEM - $17.95
   "Prevent cable freezing and extend cable life by lubricating cable with the
   "Cable Luber" system. Special precision machined lube block allows ease
   of lubrication between cable and housing without removing the cable.
   Just attach the Cable Luber to either end of the cable and insert nozzle
   from aerosol can. Specially designed seals in block force lube down
   inside cable housing. A must for the serious mechanic. Cable Life Aerosol
   lubricates and rustproofs moving parts even at temperatures far below -50
   degrees.
   Buy it at a Motorcycle shop
				 Posted: Sun Jul 02, 2006 8:04 pm    Post subject: Lubricating control cables |
				In a message dated 7/2/2006 8:56:36 P.M. Central Standard Time,  possums(at)mindspring.com writes:
   	  | Quote: | 	 		          You can lubricate your choke and throttle cables      without taking them off the carbs.
      Part # 7435
      degrees.
                 Possom, | 	                 Thanks for the very helpful info without the useless slam.  That is how the  list was designed to work, and it is in spite of certain individuals. Those of  us who have been around a while know who to listen to.
                    Thanks again,
                      Ed Diebel    (Firefly #62)
		kolbmark3
  Joined: 10 Jan 2006 Posts: 40 Location: Mt Clemens, MI
				 Posted: Mon Jul 03, 2006 3:34 am    Post subject: Lubricating control cables |
				Matt
  What happened here?
  "Just think about it for 2 seconds.  Is your engine manufacturer going  to make a recommendation of how often to inspect your flying surface cables,  especially being that they have no idea what type of plane it will be installed  in ?
 This one is a no brainer."
  "Effective immediately, "Max Stafford" has been banned from posting to the  Matronics Lists.
 Matronics Email List Administrator"
  This guy is still attacking the list although in less obnoxious  ways.
  Jim
  [quote]   ---
  _________________ Jim
Mark III
Mt. Clemens, MI |
		Thom Riddle
				 Posted: Mon Jul 03, 2006 8:25 am    Post subject: Lubricating control cables |
				Okay, Max. I've thought about it for two seconds.... 1.... 2.... You
 are still and arse orifice.
  _________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
		lcottrell
				 Posted: Mon Jul 03, 2006 4:38 pm    Post subject: Lubricating control cables |
				OK, I give up! I have the mad max blocked on my email, but I do believe that
 Matt "banned" him from the lists???? So what's up with that? statute of
 limitations run out?
 Larry, Oregon
