DAquaNut(at)aol.com Guest
Posted: Sun Jul 02, 2006 2:23 pm Post subject: Lubricating control cables |
Group,
I am doing my 25 hour maintenance as in the Rotax manual. On page 10-2 line 14 ,under the maintenance schedule it says to lubricate the control cables. Is this referring to the choke and throttle cables, or the flying surface cables??? It has a #3 , beside it, which says according to manufacturers instruction. It is not clear to me what they are suggesting to be oiled. What is the easiest way to lubricate the throttle and choke cables as that is what I think they must mean?
Ed
Max Stanford
Posted: Sun Jul 02, 2006 5:20 pm Post subject: Re: Lubricating control cables |
Just think about it for 2 seconds. Is your engine manufacturer going to make a recommendation of how often to inspect your flying surface cables, especially being that they have no idea what type of plane it will be installed in ?
This one is a no brainer.
Possum
Posted: Sun Jul 02, 2006 5:55 pm Post subject: Lubricating control cables |
At 06:22 PM 7/2/2006, you wrote:
Group,
I am doing my 25 hour maintenance as in the Rotax manual. On page 10-2 line 14 ,under the maintenance schedule it says to lubricate the control cables. Is this referring to the choke and throttle cables, or the flying surface cables??? It has a #3 , beside it, which says according to manufacturers instruction. It is not clear to me what they are suggesting to be oiled. What is the easiest way to lubricate the throttle and choke cables as that is what I think they must mean? |
You can lubricate your choke and throttle cables without taking them off the carbs.
Part # 7435
CABLE LUBER SYSTEM - $17.95
"Prevent cable freezing and extend cable life by lubricating cable with the
"Cable Luber" system. Special precision machined lube block allows ease
of lubrication between cable and housing without removing the cable.
Just attach the Cable Luber to either end of the cable and insert nozzle
from aerosol can. Specially designed seals in block force lube down
inside cable housing. A must for the serious mechanic. Cable Life Aerosol
lubricates and rustproofs moving parts even at temperatures far below -50
degrees.
Buy it at a Motorcycle shop
Posted: Sun Jul 02, 2006 8:04 pm Post subject: Lubricating control cables |
In a message dated 7/2/2006 8:56:36 P.M. Central Standard Time, possums(at)mindspring.com writes:
| Quote: | You can lubricate your choke and throttle cables without taking them off the carbs.
Part # 7435
degrees.
Possom, | Thanks for the very helpful info without the useless slam. That is how the list was designed to work, and it is in spite of certain individuals. Those of us who have been around a while know who to listen to.
Thanks again,
Ed Diebel (Firefly #62)
kolbmark3
Joined: 10 Jan 2006 Posts: 40 Location: Mt Clemens, MI
Posted: Mon Jul 03, 2006 3:34 am Post subject: Lubricating control cables |
Matt
What happened here?
"Just think about it for 2 seconds. Is your engine manufacturer going to make a recommendation of how often to inspect your flying surface cables, especially being that they have no idea what type of plane it will be installed in ?
This one is a no brainer."
"Effective immediately, "Max Stafford" has been banned from posting to the Matronics Lists.
Matronics Email List Administrator"
This guy is still attacking the list although in less obnoxious ways.
Jim
_________________ Jim
Mark III
Mt. Clemens, MI |
Thom Riddle
Posted: Mon Jul 03, 2006 8:25 am Post subject: Lubricating control cables |
Okay, Max. I've thought about it for two seconds.... 1.... 2.... You
are still and arse orifice.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
lcottrell
Posted: Mon Jul 03, 2006 4:38 pm Post subject: Lubricating control cables |
OK, I give up! I have the mad max blocked on my email, but I do believe that
Matt "banned" him from the lists???? So what's up with that? statute of
limitations run out?
Larry, Oregon
