  Joined: 28 Mar 2008 Posts: 1944 Location: Riley TWP Michigan
				 Posted: Sat Jan 16, 2016 11:36 am    Post subject: Re: Schematic for twin PM alternators |
				You are right Paul.  If each generator has its own rectifier, there is no concern about phase.  But the picture that you posted appears to show an alternating current (AC) wire connected to the battery.  Without more information, I would NOT go by that picture.  Nor would I connect an AC wire from each alternator winding to the battery.
   Can you provide a link to the schematic for the Lockwood AirCam?  Wiring your alternator according to that schematic might be the way to go.  A schematic is better than a confusing picture.
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
 _________________ Joe Gores |
		N509RV(at)eckenroth.com Guest
				 Posted: Sat Jan 16, 2016 12:50 pm    Post subject: Schematic for twin PM alternators |
				Joe.  I think you may be taking the picture too literally.  I would think the connector is hiding cross circuitry.  But then this is the first rectifier/regulator representation I've seen that relies on two wire connection. As I read more about PM alternators and the required rectifier/regulator when used in aircraft it seems the weak link is the regulator.  So what happens when the regulator goes bad.  Do you get a high voltage spike into the battery and avionics.  If you add a crowbar to counter this. Do you cut the feed after the regulator or possibly the AC feed before the regulator.The AirCam schematic is not on line.  But it seems very basic to me utilizing a rectifier/regulator plus capacitor for each engine and both into a single battery with a single master switch and solenoid.
 Paul
 On Sat, Jan 16, 2016 at 2:36 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
  	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
  Joe Gores
  http://forums.matronics.com/viewtopic.php?p=452035#452035
  br> fts!)
  r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
		ceengland7(at)gmail.com Guest
				 Posted: Sat Jan 16, 2016 2:27 pm    Post subject: Schematic for twin PM alternators |
				Exactly. The only issue is if the total       load significantly exceeds the rating of one side, in which case       you need to know whether they can 'share' the load, as Bob       mentioned.
        On 1/16/2016 12:52 PM, Paul Eckenroth wrote:
       	  | Quote: | 	 		         I don't understand the comment about the two         generators being in or out of phase.  If they are both run         through a rectifier.regulator wouldn't that eliminate the phase         concern.         I looked at a schematic for a Lockwood AirCam.  This has           two Rotax engines each with magneto, rectifier/regulator, and           capacitor all tied into one battery.
          Paul
              On Fri, Jan 15, 2016 at 8:22 PM,               user9253 <fransew(at)gmail.com (fransew(at)gmail.com)>               wrote:
                 	  | Quote: | 	 		  -->                 AeroElectric-List message posted by: "user9253" <[url=mailto:fransew(at)gmail.com]fransew(at)gmail.com (fransew(at)gmail.com)[/url]>
                  > What is the downside of both alternators connected                 to the battery at the same time.
                  If the outputs from both alternators are exactly in                 phase with each other, then I suppose that they could be                 connected in parallel to a rectifier/regulator.  The                 alternators may very well be in phase (if the wires are                 not connected backwards) because they are excited by the                 same rotating magnets.  I do not understand how the                 alternators are connected to the rectifier/regulator in                 the picture that you posted.  AC voltage can not be                 connected directly to a battery.  The AC needs to be                 rectified and regulated first.  The alternator coils can                 be damaged if not wired correctly.  The trial and error                 method should not be used.
                  > What is the purpose of the capacitor.
                  The output voltage from a rectifier/regulator is pulsing                 DC.  A capacitor tries to smooth out the pulses.  A                 flywheel on an engine is analogous to a capacitor in a                 circuit.  They each smooth out pulses.
                  > If the crowbar disconnects a generator from the                 battery what happens.  Is there any harm to the                 generator.
                  I do not think so, but will leave that for others to                 answer.
                  Joe Gores
                  http://forums.matronics.com/viewtopic.php?p=452010#452010
                  br>                 fts!)
                  rel="noreferrer"                 target="_blank">http://www.matronics.com/contribution
                  Electric-List" rel="noreferrer"                 target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
				I agree; the drawing looks like a       simple half-wave rectifier combined with the regulator. Not the       most efficient concept, but tying one end of the coil to ground       would be normal in that case.
        OV protection on PM alternators is usually with a relay in series       with the output that *opens* to protect the avionics; a true       'crowbar' across the output would take a really big shorting       device and tripping a really big circuit breaker. (There's no       'field' winding available to open.)
        On 1/16/2016 2:46 PM, Paul Eckenroth wrote:
       	  | Quote: | 	 		         Joe.  I think you may be taking the picture too         literally.  I would think the connector is hiding cross         circuitry.  But then this is the first rectifier/regulator         representation I've seen that relies on two wire connection. As         I read more about PM alternators and the required         rectifier/regulator when used in aircraft it seems the weak link         is the regulator.  So what happens when the regulator goes bad.          Do you get a high voltage spike into the battery and avionics.          If you add a crowbar to counter this. Do you cut the feed after         the regulator or possibly the AC feed before the regulator.         The AirCam schematic is not on line.  But it seems very           basic to me utilizing a rectifier/regulator plus capacitor for           each engine and both into a single battery with a single           master switch and solenoid.
          Paul
              Joe Gores
              br>             fts!)
				 Posted: Sat Jan 16, 2016 2:54 pm    Post subject: Re: Schematic for twin PM alternators |
				 	  | Quote: | 	 		  | Joe.  I think you may be taking the picture too literally. |
 You may be right.
 And you are right about the regulator being the weak link.
 Many of them made for the Rotax have failed.  The alternator is
 unlikely to fail because it has no moving parts except for the
 permanent magnets that are attached to the flywheel.  The
 magnets will not stop spinning unless the engine stops first,
 then you have bigger problems.  Usually when the regulator
 fails, the voltage drops.  But it would be prudent to be
 prepared for other failure modes like shorts to ground or
 over-voltage.  That is why my schematic in a previous post has
 the relays interrupting power to the regulator DC output, to isolate
 a regulator that is shorted to ground from the other regulator.
 If the Revmaster had only one alternator, then switching the AC
 would be a more elegant way to cut charging power.
 Unless your Onex will be flown IFR, using only one alternator at
 a time should supply enough power.
		ashleysc(at)broadstripe.n Guest
				 Posted: Sat Jan 16, 2016 8:07 pm    Post subject: Schematic for twin PM alternators |
				Hi All;
 Please allow a 75 year old from New England, the home of sarcastic humor, to note:
 So many e-mails entitled; "Schematic for Twin PM Alternators."  So few schematics actually presented.
 I have two identical 12 V, 20 amp permanent magnet, internally regulated alternators for which I have not yet developed a schematic.
 That's why I'm interested.
 Cheers!   Stu.
				 Posted: Sat Jan 16, 2016 9:31 pm    Post subject: Schematic for twin PM alternators |
				On January 16, 2016 10:05:28 PM CST, ashleysc(at)broadstripe.net wrote:[quote] [quote]--> AeroElectric-List message posted by: ashleysc(at)broadstripe.netHi All;Please allow a 75 year old from New England, the home of sarcastic humor, to note:So many e-mails entitled; "Schematic for Twin PM Alternators."  So few schematics actually presented.I have two identical 12 V, 20 amp permanent magnet, internally regulated alternators for which I have not yet developed a schematic.That's why I'm interested.Cheers!   Stu.---
				 Posted: Sat Jan 16, 2016 11:34 pm    Post subject: Re: Schematic for twin PM alternators |
				Hi Stu!  What kind of engine and alternators do you have.
 It will be interesting to see the schematic that you develop.
				 Posted: Sun Jan 17, 2016 8:19 am    Post subject: Schematic for twin PM alternators |
				Hi Charlie;
  For a start get on EBAY and input:
  "Permanent Magnet PM Alternator Fits Isuzu"
  It should come up as the first item listed.
  The manufacturer is named "LActrical".
  These units are most likely built in China, so you have to accommodate your fears, expectations, prejudices, if any, to that.
  (My personal belief is that there is a range of quality being manufactured in China ranging from terrible to excellent.)
  These units appear to be well made, but I have not run them yet.  Once you know what you are looking for, you can probably get the cost down to about $75.  Note that the internally regulated ones have a black plastic infill on the back side.  If it looks hollow back there, it is the externally regulated version.  Knowing this allows a quick visual sorting as you scroll down the various EBAY and Amazon offerings.
  Cheers! (and good luck):   Stu.
 Sent: Saturday, January 16, 2016 9:26:25 PM
 Subject: Re: Re: Schematic for twin PM alternators
  On January 16, 2016 10:05:28 PM CST, ashleysc(at)broadstripe.net wrote: [quote]
  	  | Quote: | 	 		  | Hi All;Please allow a 75 year old from New England, the home of sarcastic humor, to note:So many e-mails entitled; "Schematic for Twin PM Alternators."  So few schematics actually presented.I have two identical 12 V, 20 amp permanent magnet, internally regulated alternators for which I have not yet developed a schematic.That's why I'm interested.Cheers!   Stu. |
 [quote]---
				 Posted: Sun Jan 17, 2016 8:26 am    Post subject: Schematic for twin PM alternators |
				Hi Joe;
 I don't have a schematic yet.  I was hoping to encounter one during the ongoing discussion.  The manufacturer is "LActrical."
 If you get on EBAY and input "Permanent Magnet PM Alternator Fits Isuzu", one of these should be the first item listed.  Once you know what you are looking for, you can get the price down to about $75 on EBAY or Amazon.  Full disclosure: Although the quality looks good, I have not run mine yet.
 Cheers!   Stu.
				 Posted: Sun Jan 17, 2016 9:13 am    Post subject: Schematic for twin PM alternators |
				At 04:54 PM 1/16/2016, you wrote:
   	  | Quote: | 	 		  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
  You may be right.
  Many of them made for the Rotax have failed. |
    That situation along with R/R assemblies
    for B&C products is being evaluated. We'll
    have more robust recommendations for virtually
    all OBAM aircraft PM alternator installations.
				 Posted: Sun Jan 17, 2016 9:38 am    Post subject: Schematic for twin PM alternators |
				Thanks for the link. From memory, the pic looks like they've just bolted a rectifier/regulator to the back of a typical John Deer/Kubota style PM alternator. I wonder if the regulator is available separately. Also wonder if it's a shunt style or switcher.
 On Sun, Jan 17, 2016 at 10:17 AM,  <ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)> wrote:
 [quote]Hi Charlie;
    From: "Charlie England" <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
  On January 16, 2016 10:05:28 PM CST, ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net) wrote: [quote]
 [quote]---
		kenryan
				Did that overhauled over voltage protection module ever come to fruition?
 On Sun, Jan 17, 2016 at 8:11 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  You may be right.
				 Posted: Sun Jan 17, 2016 10:09 am    Post subject: Schematic for twin PM alternators |
				Hi Charlie;
  Well, the regulator is bonded  (plastic cast in place?) to the back side, not bolted.  It doesn't look like it can be easily separated, should you want to replace it, or mount it remotely.
  Cheers!   Stu.
 Sent: Sunday, January 17, 2016 9:36:43 AM
  [quote]   Hi Charlie;
  On January 16, 2016 10:05:28 PM CST, ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)wrote: [quote]
  	  | Quote: | 	 		  Hi All;
 Cheers!   Stu.
 [quote]---
				 Posted: Sun Jan 17, 2016 12:00 pm    Post subject: Schematic for twin PM alternators |
				The listing I found
  http://www.ebay.com/itm/PERMANENT-MAGNET-PM-ALTERNATOR-Fits-ISUZU-KOKUSAN-DENKI-SMALL-ENG-12VOLT-20AMP-/301651032847?hash=item463bcd7b0f:g:bCUAAOSwstxVbPpU&vxp=mtr
        shows what looks like a truncated metal disc with the potting       material in it, and 2 bolt heads showing in back. I assumed that       the entire metal disc including the potted section would unbolt       from the dynamo. The bare, unregulated dynamos look more or less       like
  http://www.ebay.com/itm/PERMANENT-MAGNET-PM-ALTERNATOR-Fits-PERKINS-YANMAR-SMALL-ENGINES-12-VOLT-20-AMP-/271888026588?hash=item3f4dca0bdc:g:55IAAOSwBahVbPnp&vxp=mtr
        I googled 'ISUZU KOKUSAN DENKI wiring diagram' & found
  http://www.alibaba.com/product-detail/Permanent-Magnet-Alternator-Kokusan-Denki_252852606.html
        which basically shows a B lead & ground. Since there's no       field winding, you can't depend on the switched ignition line to       shut down the alternator, so IMO, you'd still need a series       contactor to disconnect the B lead in an OV condition.
        If the diagram is accurate for your device (and likely is), then       you *should* be able to treat it like a black box with a case       ground and a B lead (with the L terminal tied through an indicator       lamp & switch to the B lead).
        On 1/17/2016 12:05 PM, ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net) wrote:
      [quote]                Hi Charlie;
          Cheers!   Stu.
                   From:           "Charlie England" <ceengland7(at)gmail.com> (ceengland7(at)gmail.com)
                    [quote]        Hi Charlie;
                                                   From:                           "Charlie England" <[url=mailto:ceengland7(at)gmail.com]ceengland7(at)gmail.com (ceengland7(at)gmail.com)[/url]>
                                 	  | Quote: | 	 		  Hi All;
 Cheers!   Stu.
                                [quote]---
				 Posted: Sun Jan 17, 2016 3:23 pm    Post subject: Schematic for twin PM alternators |
				Hi Charlie;
  1.  Well you found the right listing.  I've looked at a few more alternators that are apparently the same animal, minus regulator, and it appears you are right.  So you could have your choice: internally regulated or remotely regulated.  I don't know why all the unregulated units are more than $100!  Plus you have to buy the regulator!
  2.  Concerning your second reference, please note it is not exactly as above.  The mounting ears are not directly opposite each other.  This may or may not be a disadvantage, depending on how you intend to mount it.  I wanted a symmetrical configuration, so I had the option of mounting facing forward or aft.  (These alternators don't care which way they are rotated.)  As it turns out both my pulleys will be facing forward.
  3.  Thanks for the reference to the wiring diagram.  I will look further into it for paralleling. two units.
  Cheers!   Stu.
 Sent: Sunday, January 17, 2016 11:59:38 AM
  The listing I found
  [quote]  Hi Charlie;
  Cheers!   Stu.
  [quote]   Hi Charlie;
  	  | Quote: | 	 		  Hi All;
 Cheers!   Stu.
 [quote]---
				 Posted: Sun Jan 17, 2016 3:45 pm    Post subject: Schematic for twin PM alternators |
				At 11:35 AM 1/17/2016, you wrote:
   	  | Quote: | 	 		  | Did that overhauled over voltage protection module ever come to fruition? |
    Yes . . . its in the que for loading to the
    B&C production line.
		yellowduckduo(at)gmail.co Guest
				 Posted: Sun Jan 17, 2016 4:07 pm    Post subject: Schematic for twin PM alternators |
				J.Deere part numbers are AM877557 for the alternator, and AM101406 for
 the regulator.
 Unverified info is that the same regulator is also used on a 35 amp
 alternator.
 I use a little automotive 40 amp rated cube relay on an AC lead with an
 crowbar module for overvoltage control and have a C/B on the B lead that
 could theoretically also be pulled to isolate the regulator from the
 battery if need be. I also fitted a larger multi-V pulley and around 500
 hours I replaced the pulley side ball bearing.
 Check out Mark Langford's KR2S website for more info.
 http://www.n56ml.com/
 Ken
 On 17/01/2016 12:36 PM, Charlie England wrote:
 [quote] Thanks for the link. From memory, the pic looks like they've just
  <mailto:ashleysc(at)broadstripe.net>> wrote:
      Hi Charlie;
      <mailto:ceengland7(at)gmail.com>>
      *To: *aeroelectric-list(at)matronics.com
      <mailto:aeroelectric-list(at)matronics.com>
      *Sent: *Saturday, January 16, 2016 9:26:25 PM
      *Subject: *Re: Re: Schematic for twin PM
      alternators
      <mailto:ashleysc(at)broadstripe.net> wrote:
          Hi All;
          Cheers!   Stu.
				 Posted: Mon Jan 18, 2016 3:08 pm    Post subject: Re: Schematic for twin PM alternators |
				B & C permanent magnet alternator schematic:
 http://www.bandc.aero/pdfs/420-506_revb.pdf
  	  | Quote: | 	 		  Please allow a 75 year old from New England, the home of
 sarcastic humor, to note: So many e-mails entitled; "Schematic
 for Twin PM Alternators." So few schematics actually presented. |
 OK, I have attached another version.
 Design considerations:
 Rectifiers/Regulators get hot.  Connecting two alternators to
 one rectifier/regulator could overheat it (when under heavy load).
 If the output of two separate rectifier/regulators are
 connected together, will the load be shared equally or will one
 be overworked and self destruct?
 If there is an over-voltage condition, how will the faulty
 regulator be identified and shut off quickly (in less than one second)?
 If one charging system fails, will the other one then be
 overloaded and fail also?
 Hundreds of Rotax powered aircraft are flying with modern glass
 panels and LED lighting powered by one 20 amp permanent-magnet
 dynamo (usually loaded to no more than 80 percent).  The
 Revmaster should be able to do the same using one alternator at
 a time.  An outbound leg can use the left alternator and the
 inbound leg can use the right alternator.  The pilot will know
 that both systems work and there will always be a backup.
		|  Description: |
		  Download |
		|  Filename: |
		 Revmaster3.pdf |
		|  Filesize: |
		 66.53 KB |
		|  Downloaded: |
		 734 Time(s) |
				 Posted: Mon Jan 18, 2016 8:06 pm    Post subject: Schematic for twin PM alternators |
				Hi Joe;
 Being internally regulated, each alternator has it's own regulator.  I think I will probably wire so that only one is in use at a time.
 Cheers!   Stu.
