		robust_design(at)hotmail. Guest
				 Posted: Fri Feb 03, 2017 10:47 am    Post subject: Europa-List Digest: 7 Msgs - 02/02/17 |
				This is probably mentioned somewhere, but I missed it.  Has anyone done a study of the Europa XS Mono glide ratio?  I would be interested in the glide ratio with a feathered prop and a non-feathered prop.
 I would like to make a 50-mile crossing of Lake Michigan.   And survive.
 Donald Ingram
 A204
 From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Europa-List Digest Server <europa-list(at)matronics.com>
 Sent: Friday, February 3, 2017 8:03:43 AM
 To: Europa-List Digest List
 Subject: Europa-List Digest: 7 Msgs - 02/02/17
 Today's complete Europa-List Digest can also be found in either of the
 two Web Links listed below.  The .html file includes the Digest formatted
 and Message Navigation.  The .txt file includes the plain ASCII version
 of the Europa-List Digest and can be viewed with a generic text editor
 HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-02-02&Archive=Europa
 Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-02-02&Archive=Europa
                            Europa-List Digest Archive
                      Total Messages Posted Thu 02/02/17: 7
 Today's Message Index:
      1. 03:46 AM - Painting  (William Daniell)
      2. 06:16 AM - Re: Painting  (rampil)
      3. 07:05 AM - Aluminium spec  (flyingphil2)
      4. 12:36 PM - Re: Painting  (davidjoyce(at)doctors.org.uk)
      5. 03:24 PM - Re: Dynon Pitot/AOA  (carlp101)
      6. 03:33 PM - Re: EUROPA XS GAS STRUTS  (carlp101)
      7. 03:43 PM - Re: Trips 2017 UK/Europe  (carlp101)
 ________________________________  Message 1  _____________________________________
 Time: 03:46:53 AM PST US
 From: William Daniell <wdaniell.longport(at)gmail.com>
 Subject: Painting
 Finally after 12 years ....HJ460 is now in its hangar awaiting paint.  We
 fired up the engine and the dynon and much to my surprise everthing works
 I realize that this is not over and I have merely completed phase 1.
 HJ460 is a "fast build" (hahahaha) with gel coat over wings and fuselage
 and the cloth flying surfaces are filled and sanded.  She has the minor
 dings and epoxy drips from 12 years of constructions.
 PAINTING  the plan suggested by the Colombian painter is
    - sand gel coat with fine paper
    - fill all visible dings with micro
    - apply epoxy primer
    - sand
    - fill with polyester filler
    - re primer
    - paint (white) with aircraft paint.
    - Lacquer on top
 Any input gratefully received.  Does this sound like a plan?  Is polyester
 car filler appropriate?
 Many thanks
 WIll
 William Daniell
 LONGPORT
 +57 310 295 0744
 ________________________________  Message 2  _____________________________________
 Time: 06:16:35 AM PST US
 Subject: Re: Painting
 I would not mix chemistries. Use expo micro, not polyester for filling.
 When you say aircraft paint, you realize that there are dozens of different
 kinds of aircraft paint, some suitable for fabric, some for metal and composite.
 I recommend Dupont Imron with Clearcoat finish.  This is my choice as it is
 extremely hard and scratch resistant. It is expensive and is (cyanide) toxic. Have
 a professional spray it for you. My 13 year old is still looking good.
 Ira N224XS
 http://forums.matronics.com/viewtopic.php?p=465651#465651
 ________________________________  Message 3  _____________________________________
 Time: 07:05:01 AM PST US
 Subject: Aluminium spec
 From: "flyingphil2" <flyingphil627-europastuff(at)yahoo.co.uk>
 I'm sure this was discussed before but I can't find the posting.
 Could someone advise what the material spec is for the aluminium used on the instrument
 module sub panels (and also the flap brackets)?
 Phil
 http://forums.matronics.com/viewtopic.php?p=465652#465652
 ________________________________  Message 4  _____________________________________
 Time: 12:36:22 PM PST US
 William, If you use gel coat there is just a single layer to spray on
 and then you wet & dry sand most of it off, going progressively through
 400, 1200 and 2000 grit to produce the most superb and very durable
 finirsh. You do not need any primer or UV barrier as gel coat includes
 those.
 Regards, David, GXSDJ
 On 2017-02-02 11:45, William Daniell wrote:
  	  | Quote: | 	 		   Finally after 12 years ....HJ460 is now in its hangar awaiting paint. We fired
  HJ460 is a "fast build" (hahahaha) with gel coat over wings and fuselage and
 the cloth flying surfaces are filled and sanded. She has the minor dings and epoxy
  * sand gel coat with fine paper
  * fill all visible dings with micro
  * apply epoxy primer
  * sand
  * fill with polyester filler
  * re primer
  * paint (white) with aircraft paint.
  * Lacquer on top
  Any input gratefully received. Does this sound like a plan? Is polyester car
 filler appropriate? Many thanks
  WIll
  William Daniell LONGPORT
  +57 310 295 0744
 ________________________________  Message 5  _____________________________________
 Time: 03:24:59 PM PST US
 Subject: Re: Dynon Pitot/AOA
 Hi all,
 I took delivery of my Dynon heated pitot/AOA probe today. I'm aiming to replace
 the existing pitot with this one. As Dynon says the tip of the probe can be anywhere
 from 2-12 inches from the leading edge, approx 6 inches below the wing
 surface and half way along the wing, I think this location will be OK. I'll measure
 it tomorrow.
 As I have a classic wing the next challenge will be fitting the probe and the wiring.
 I'll give Andy Draper a call too to get his advice, but hopefully I can
 use the existing mounting and modify the mounting tube I also got from Dynon.
 I have just finished adding my cabin lighting (red dimable LED), so the heated
 pitot should be the final bit of kit I need before I'm ready to apply for the
 removal of the VFR restriction. Wish me luck as I may be first-of-type.
 All the best.
 Carl
 http://forums.matronics.com/viewtopic.php?p=465662#465662
 ________________________________  Message 6  _____________________________________
 Time: 03:33:57 PM PST US
 Subject: Re: EUROPA XS GAS STRUTS
 Hi Bill,
 I called IGS and sent them the details of my struts. They came back and said they
 could not re-gas them because they were custom struts made for Europa. They
 said I had to contact them. Have you had yours returned yet? Are they OK? Do
 you have a contact at IGS I could speak to?
 Many thanks
 Carl
 http://forums.matronics.com/viewtopic.php?p=465663#465663
 ________________________________  Message 7  _____________________________________
 Time: 03:43:15 PM PST US
 Subject: Re: Trips 2017 UK/Europe
 Hi Roland,
 I'm interested in this three day trip, but I've never flown in Europe. Do you know
 if anyone else from the UK has shown an interest in this event? I'd appreciate
 tagging along with someone who has some experience (plus it would be more
 fun).
 Carl
 G-URMS
 Roland wrote:
  	  | Quote: | 	 		   Hi David and all,
  after reply from Jens I'm pleased to let you know, that all Europa-pilots are
 very welcome at the OUV-summer meeting, which will take place at
  Bad Drkheim EDRF from 16th-18th June 2017
  Mogas is available at EDRF and no landing fees will be charged on arrival
		h&jeuropa
		rampil
				 Posted: Sun Feb 05, 2017 5:46 am    Post subject: Re: Europa-List Digest: 7 Msgs - 02/02/17 |
				Have you considered measuring the glide ratio yourself, in your aircraft.
 The results are going to depend on your weight, finish quality of your
 paint, degree of out of rig trim drag, type of prop, etc, etc, etc.
 Since the Europa is not a factory aircraft, there really is no such thing
 as a standard value and over the years, many of the promotional values
 were found to be simply aspirational for most builders.
		houlihan(at)blueyonder.co Guest
