robust_design(at)hotmail. Guest
Posted: Fri Feb 03, 2017 10:47 am Post subject: Europa-List Digest: 7 Msgs - 02/02/17 |
This is probably mentioned somewhere, but I missed it. Has anyone done a study of the Europa XS Mono glide ratio? I would be interested in the glide ratio with a feathered prop and a non-feathered prop.
I would like to make a 50-mile crossing of Lake Michigan. And survive.
Donald Ingram
A204
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Europa-List Digest Server <europa-list(at)matronics.com>
Sent: Friday, February 3, 2017 8:03:43 AM
To: Europa-List Digest List
Subject: Europa-List Digest: 7 Msgs - 02/02/17
Today's complete Europa-List Digest can also be found in either of the
of the Europa-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2017-02-02&Archive=Europa
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2017-02-02&Archive=Europa
Europa-List Digest Archive
Total Messages Posted Thu 02/02/17: 7
Today's Message Index:
1. 03:46 AM - Painting (William Daniell)
2. 06:16 AM - Re: Painting (rampil)
3. 07:05 AM - Aluminium spec (flyingphil2)
4. 12:36 PM - Re: Painting (davidjoyce(at)doctors.org.uk)
5. 03:24 PM - Re: Dynon Pitot/AOA (carlp101)
6. 03:33 PM - Re: EUROPA XS GAS STRUTS (carlp101)
7. 03:43 PM - Re: Trips 2017 UK/Europe (carlp101)
Time: 03:46:53 AM PST US
From: William Daniell <wdaniell.longport(at)gmail.com>
Subject: Painting
Finally after 12 years ....HJ460 is now in its hangar awaiting paint. We
fired up the engine and the dynon and much to my surprise everthing works
I realize that this is not over and I have merely completed phase 1.
HJ460 is a "fast build" (hahahaha) with gel coat over wings and fuselage
and the cloth flying surfaces are filled and sanded. She has the minor
dings and epoxy drips from 12 years of constructions.
PAINTING the plan suggested by the Colombian painter is
- sand gel coat with fine paper
- fill all visible dings with micro
- apply epoxy primer
- sand
- fill with polyester filler
- re primer
- paint (white) with aircraft paint.
- Lacquer on top
Any input gratefully received. Does this sound like a plan? Is polyester
car filler appropriate?
Many thanks
WIll
William Daniell
LONGPORT
+57 310 295 0744
Time: 06:16:35 AM PST US
Subject: Re: Painting
I would not mix chemistries. Use expo micro, not polyester for filling.
When you say aircraft paint, you realize that there are dozens of different
kinds of aircraft paint, some suitable for fabric, some for metal and composite.
I recommend Dupont Imron with Clearcoat finish. This is my choice as it is
extremely hard and scratch resistant. It is expensive and is (cyanide) toxic. Have
a professional spray it for you. My 13 year old is still looking good.
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=465651#465651
Time: 07:05:01 AM PST US
Subject: Aluminium spec
From: "flyingphil2" <flyingphil627-europastuff(at)yahoo.co.uk>
I'm sure this was discussed before but I can't find the posting.
Could someone advise what the material spec is for the aluminium used on the instrument
module sub panels (and also the flap brackets)?
Phil
http://forums.matronics.com/viewtopic.php?p=465652#465652
________________________________ Message 4 _____________________________________
Time: 12:36:22 PM PST US
William, If you use gel coat there is just a single layer to spray on
and then you wet & dry sand most of it off, going progressively through
400, 1200 and 2000 grit to produce the most superb and very durable
finirsh. You do not need any primer or UV barrier as gel coat includes
those.
Regards, David, GXSDJ
On 2017-02-02 11:45, William Daniell wrote:
Quote: | Finally after 12 years ....HJ460 is now in its hangar awaiting paint. We fired
HJ460 is a "fast build" (hahahaha) with gel coat over wings and fuselage and
the cloth flying surfaces are filled and sanded. She has the minor dings and epoxy
* sand gel coat with fine paper
* fill all visible dings with micro
* apply epoxy primer
* sand
* fill with polyester filler
* re primer
* paint (white) with aircraft paint.
* Lacquer on top
Any input gratefully received. Does this sound like a plan? Is polyester car
filler appropriate? Many thanks
Quote: |
WIll
William Daniell LONGPORT
+57 310 295 0744
________________________________ Message 5 _____________________________________
Time: 03:24:59 PM PST US
Subject: Re: Dynon Pitot/AOA
Hi all,
I took delivery of my Dynon heated pitot/AOA probe today. I'm aiming to replace
the existing pitot with this one. As Dynon says the tip of the probe can be anywhere
from 2-12 inches from the leading edge, approx 6 inches below the wing
surface and half way along the wing, I think this location will be OK. I'll measure
it tomorrow.
As I have a classic wing the next challenge will be fitting the probe and the wiring.
I'll give Andy Draper a call too to get his advice, but hopefully I can
use the existing mounting and modify the mounting tube I also got from Dynon.
I have just finished adding my cabin lighting (red dimable LED), so the heated
pitot should be the final bit of kit I need before I'm ready to apply for the
removal of the VFR restriction. Wish me luck as I may be first-of-type.
All the best.
Carl
http://forums.matronics.com/viewtopic.php?p=465662#465662
________________________________ Message 6 _____________________________________
Time: 03:33:57 PM PST US
Subject: Re: EUROPA XS GAS STRUTS
Hi Bill,
I called IGS and sent them the details of my struts. They came back and said they
could not re-gas them because they were custom struts made for Europa. They
said I had to contact them. Have you had yours returned yet? Are they OK? Do
you have a contact at IGS I could speak to?
Many thanks
Carl
http://forums.matronics.com/viewtopic.php?p=465663#465663
________________________________ Message 7 _____________________________________
Time: 03:43:15 PM PST US
Subject: Re: Trips 2017 UK/Europe
Hi Roland,
I'm interested in this three day trip, but I've never flown in Europe. Do you know
if anyone else from the UK has shown an interest in this event? I'd appreciate
tagging along with someone who has some experience (plus it would be more
fun).
Carl
G-URMS
Roland wrote:
Quote: | Hi David and all,
after reply from Jens I'm pleased to let you know, that all Europa-pilots are
very welcome at the OUV-summer meeting, which will take place at
Bad Drkheim EDRF from 16th-18th June 2017
Mogas is available at EDRF and no landing fees will be charged on arrival
h&jeuropa
rampil
Posted: Sun Feb 05, 2017 5:46 am Post subject: Re: Europa-List Digest: 7 Msgs - 02/02/17 |
Have you considered measuring the glide ratio yourself, in your aircraft.
The results are going to depend on your weight, finish quality of your
paint, degree of out of rig trim drag, type of prop, etc, etc, etc.
Since the Europa is not a factory aircraft, there really is no such thing
as a standard value and over the years, many of the promotional values
were found to be simply aspirational for most builders.
houlihan(at)blueyonder.co Guest
