		| Author | Message |
		| pete(at)lawless.info Guest
				|  Posted: Mon Dec 11, 2017 2:43 pm    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Graeme
 Suspect first sign would be a fuel smell and damp filler pipe.
 Standard mod shortly available as SM 13070.  Paper work is with Andy
 Draper at the moment but I believe just about complete.
 John Archer is getting a batch of pipes made down in France. Suggest you
 contact John direct 77alembert(at)gmail.com.
 Pete
 On 11/12/17 21:30, graeme bird wrote:
  	  | Quote: |  	  |
 Checked my 6 year old, rubber conventional filler tube (old style long one from the centre of the fuselage. Looked good as new to me and very flexible, no signs of cracking around the face or inside. Surely first signs would be black bits in the fuel filter.
 Was there any progress on the metal filler, did anyone get a batch made? Was it with Nev?
 Graeme Bird
 G-UMPY -  Mono Classic/XS FFW 912S, Woodcomp 3000/3W CS, trutrak Gemini 2 axis AP, PAW, PFLARM core, ads-b out, 8.33khz, mode S, FP-5, Aera500, SD on Nexus, SmartA3
 325 hours & 6 years on the Mono, 930 total
 g(at)gdbmk.co.uk
 http://forums.matronics.com/viewtopic.php?p=476346#476346
		| Back to top |  |
				|  Posted: Fri Dec 15, 2017 10:20 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Ivor
 Been looking for hose for a standard mod to replace the classic pipe
 with aluminium.  The only hose we have found so far that is guaranteed
 100% for petrol is Samco ProFuel. Unfortunately it is on a 42 day lead time.
 https://www.merlinmotorsport.co.uk/p/samco-profuel-silicone-coupling-hose-psch
 Pete
 G-RMAC Europa 109 Classic
 On 15/12/17 17:53, Ivor wrote:
  	  | Quote: |  	  |
 Hi Duncan
 as previously said i managed to get a piece of the original hose from
 Frank Xuereb that will work fine until the next flying season when hopefully
 a more permanent solution is found,
 IMO if a hose designed for fuel cannot be immersed in fuel then it’s not fit
 for purpose,
 my last hose lasted at least 5 years before starting to degrade so an original hose should be fine until a proper replacement is found,
 http://forums.matronics.com/viewtopic.php?p=476410#476410
		| Back to top |  |
		| andy_ringrose(at)onetel.c Guest
				|  Posted: Fri Dec 15, 2017 11:10 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Carbuildersolutions.com have a silicon fuel filler hose 51mm I.D part no. SKU:SILFF51BK
 Time will tell if it's an improvement on the standard hose. I also have an aluminium pipe in place of the factory version due to early concerns re fuel immersion particularly on the Mono. The lower joining section had identical deterioration to that which Ivor reported. Time in service 10 years mostly with Premium unleaded.
 Andy
 GMAUS Mono
		| Back to top |  |
		| Roland
				|  Posted: Fri Dec 15, 2017 11:54 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Is 51 mm inner diameter the correct size?
I'm about to replace the fuel hoses next month and I'm afraid that the fuel filler hose has deteriorated on the inside as well and I'd like to choose the best available.
 Roland
 PH-ZTI
 XS TG 914
		| Back to top |  |
		| brian.davies44(at)gmail.c Guest
				|  Posted: Sat Dec 16, 2017 1:27 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Also www.demon-tweeks.co.uk
 Choice of three suppliers 51mm fuel filler hose .
 Note that silicone hose must be lined with fuel resistant material and that is only specified for short term contact with liquid fuel but long term contact with fuel vapours.
 Brian
		| Back to top |  |
				|  Posted: Sat Dec 16, 2017 1:32 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Demon Tweeks says in stock 3 day delivery.
 Brian
		| Back to top |  |
				|  Posted: Sat Dec 16, 2017 1:50 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Brian
 I have been working with John Archer to get the standard mod for
 converting the classic filler tube to aluminium approved.  This is
 currently with Andy Draper and just about ready to go.  LAA will only
 consider fully fuel proof hose, which is the Samco Pro Fuel. Everything
 I have found other than this is only usable as a filler not for
 permanent contact.  The same problem will apply to the XS replacement.
 Pete
 Brian
		| Back to top |  |
				|  Posted: Sat Dec 16, 2017 2:29 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Pete,
 You have expressed the problem much more clearly than I did.  You could use rubber instead of lined silicone hoses but it is hard (impossible?) to find out if the rubber is proof against modern Mogas without actually testing it. It is, however,  nearly 1/4 inch thick so it should last for at least a year.
 Brian
		| Back to top |  |
		| Burrilla
				|  Posted: Sat Dec 16, 2017 2:43 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| I’ve been looking at the Samco Pro for an XS, has the shorter 45 degree bend rubber pipe. Unfortunately my measurements indicate I need one with leg lengths of 100mm and 160mm which is not standard and would be a special order. I’ve been quoted Feb 18 delivery if I provide a drawing.
 Anyone found a suitable replacement elsewhere?
 Of course I could just use the one from Europa but I guess that routine checking and/or replacement is going to become a maintenance item so silicon would be a sensible lifetime solution.
 Alan
 G-OBJT
 Sent from my iPad
 [quote] On 16 Dec 2017, at 10:29, Brian Davies <brian.davies44(at)gmail.com> wrote:
 Hi Pete,
 Brian
		| Back to top |  |
				|  Posted: Sat Dec 16, 2017 9:42 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| The LAA will want chapter and verse on its suitability for petrol       + ethalene fuel.
Pete
 On 16/12/17 15:35, David Watts wrote:
 [quote]              I have seen an aluminium tube 45 degree solution on eBay at         item number 300735817645 for less than £20. May be suitable.
 Dave Watts
 G-BXDY
 On 16 Dec 2017, at 14:28, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)         wrote:
 Dave, a nice solution, but for those who haven't got a tame             aluminium welder it might be cheaper to buy a flurosilicone             lined angled fuel filler hose from carbuildersolutions.com and use             a straight section of alloy tubing to make up the necessary             length. Regards, David, G-XSDJ
 On 2017-12-16 11:27, david park wrote:           [quote]
 <image1.jpeg>
 Simple and cheap did this three years ago without any             problem
 Dave Park
 On 16 Dec 2017, at 11:19, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)>               wrote:
 [quote]                                                   Best solution is to use short silicone                       joints to an aluminium elbow, it's much lighter                       and the silicone is less problematic regarding                       erosion etc.
 Tim Ward organised a batch of nice elbows                       but that was years ago.
 It wouldn't be difficult to weld one up?
 Graham
 On Saturday, 16 December                             2017, 9:33, Brian Davies <brian.davies44(at)gmail.com (brian.davies44(at)gmail.com)>                             wrote:
 --> Europa-List message                             posted by: "Brian Davies" <brian.davies44(at)gmail.com (brian.davies44(at)gmail.com)>
 Brian
		| Back to top |  |
				|  Posted: Sat Dec 16, 2017 11:12 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Roger I think ProFuel is a Samco brand name.
Pete
 On 16/12/17 18:26, Roger Sheridan       wrote:
  	  | Quote: |  	  | Chaps, This link has some interesting information on         variations in “fluorosilicone” hose.
 http://www.silflex.com/products/fuel-oil-applications.html
 I will be looking for the term “profuel”.
 Roger
  	  | Quote: |  	  | On 16 Dec 2017, at 17:41, Pete Lawless <pete(at)lawless.info (pete(at)lawless.info)>                 wrote:
 Pete                                                   On                   16/12/17 15:35, David Watts wrote:
  	  | Quote: |  	  | I have seen an aluminium tube 45 degree                     solution on eBay at item number 300735817645 for                     less than £20. May be suitable.
 Dave Watts
 G-BXDY
  	  | Quote: |  	  | Dave, a nice solution, but for those                         who haven't got a tame aluminium welder it might                         be cheaper to buy a flurosilicone lined angled                         fuel filler hose from carbuildersolutions.com and use                         a straight section of alloy tubing to make up                         the necessary length. Regards, David, G-XSDJ
  	  | Quote: |  	  | <image1.jpeg>                                                  Simple and cheap did this three years ago                         without any problem                                                  Dave Park
		| Back to top |  |
				|  Posted: Sun Dec 17, 2017 11:49 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Tim
 I have just been involved in getting together an LAA Standard Mod for
 the classic long fuel pipe to be made in aluminium.  One of the LAA
 requirements was documentary proof that the type of aluminium used was
 suitable for use with petrol containing ethanol.
 Pete
 G-RMAC Europa #109 classic
 On 17/12/17 19:02, Tim Ward wrote:
  	  | Quote: |  	  |
 Hi Europa owners,
 It has become evident my aluminium elbow maybe in demand again.
 I can ask the manufacturer of the aluminium elbow to make another run. This would require at least ten Europa owners to commit to buying. As I am now flying to Heathrow  again I can bring them with me and post them in Londontown to save cost. American builders also, as I am in Los Angeles/San Francisco frequently.
 Those builders interested in buying an elbow please email me. If there are enough I will get a price for you before committing.
 I have had no problem with this fuel flow connection.
 Merry Christmas.
 Cheers,
 Tim Ward
 12 Waiwetu Street,
 Fendalton,
 Christchurch, 8052
 New Zealand
 ward.t(at)xtra.co.nz
 Mob +64 210640221
 > On 18/12/2017, at 3:34 AM, Richard Wheelwright <rpwheelwright(at)yahoo.co.uk> wrote:
 > Just completed the check on G-IRPW. And all is well. Just for info I did fit Tim Wards elbow a few years ago.
 > Richard Wheelwright
 > G-IRPW
 > First Flight 24th July 2013
 > http://forums.matronics.com/viewtopic.php?p=476460#476460
 > http://forums.matronics.com//files/58e4a1ae_d8b9_43d9_a5c9_b35c398813c7_133.jpeg
		| Back to top |  |
				|  Posted: Tue Dec 19, 2017 6:35 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Can't seem to find this mod listed in the LAA list of Europa standard mods.
 Pete
		| Back to top |  |
		| Richard Lamprey
				|  Posted: Wed Dec 20, 2017 11:11 pm    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Stupid question, but I will ask anyway...  All the examples, photos, LAA report etc point to the side-filler Europa pipe, with 45 degree bend, which was an alternative to the top-of-fuselage original filler.  I have the latter, the long pipe coming down through a hole in the rear bulkhead.  Was this a different pipe batch?  Inspection shows no problem with mine, I fill to the top before every flight, ie right up the pipe, then fly, then leave tank with about 3/4 full ie the pipe is not immersed for long.  I fly once a month,  Nice constant temps in Kenya 15-28 C for storage, all seems to be OK.
Best
 Richard
 Classic 5Y-LRY, Kenya
		| Back to top |  |
		| clivesutton
				|  Posted: Thu Dec 21, 2017 2:30 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				|  	  | pete(at)lawless.info wrote: |  	  | Can't seem to find this mod listed in the LAA list of Europa standard mods.
 Hi Pete, as the link (refreshed here again in case there is a problem with it), it is a factory MOD that has been in existence since mid-2015 and is listed under the usual Technical Updates/Modifications section on their website.  It is also listed in the TADS under 'Standard Options'.  BR Clive
 http://www.europa-aircraft.com/upload/Modification%20Bulletin%20No%2079%20(Issue%2003).pdf
  	  | Quote: |  	  |
 As you say Bob, lots of activity behind the scenes.
 MOD79 may also bring something to the party for some Europa-owners (LAA aware).  The black silicone hoses in that MOD kit have a green fluoro fuel-resistant lining.
		| Back to top |  |
				|  Posted: Thu Dec 21, 2017 10:14 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Richard
 You have a Classic the pictures were for the XS with a side filler.  The
 AD applies to both.
 I have just inspected mine and whilst the inside looked perfect the fuel
 tank end was noticeably soft compared to the top section. I intend to
 replace it with aluminium as per Standard Mod 13070. If you are
 interested John Archer, who is getting the pipes made, is taking orders now.
 Pete
 G-RMAC Classic #109
 On 21/12/17 07:11, Richard Lamprey wrote:
  	  | Quote: |  	  |
 Best
 Richard
 http://forums.matronics.com/viewtopic.php?p=476654#476654
		| Back to top |  |
				|  Posted: Fri Dec 22, 2017 8:14 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| As I explained in an earlier e-mail, there is no LAA Standard Mod to fit an aluminium elbow on an XS Europa. As nobody has applied for a standard Mod I have agreed with Andy Draper that I will do so.  It will be based on Tim Ward's aluminium elbow and will use Samco Profuel joints.  These can be purchased  from  www.merlinmotorsport.co.uk   in a short length of 76mm for UK Pounds 11.24 plus VAT and postage.  Currently there is a 39 day lead time on this item. Part number PSCH51-BLU
 I will give you a progress report after Christmas.
 Brian Davies
		| Back to top |  |
		| Richard Lamprey
				|  Posted: Fri Dec 22, 2017 11:51 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Thanks Pete, do you have John Archers contact email?
Best
 Richard
  	  | pete(at)lawless.info wrote: |  	  | Hi Richard
 AD applies to both.
 Pete
 G-RMAC Classic #109
  	  | Quote: |  	  |
 Best
 Richard
		| Back to top |  |
				|  Posted: Fri Dec 22, 2017 2:04 pm    Post subject: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Richard
 John is at 77alembert(at)gmail.com
 Pete
 On 22/12/17 19:51, Richard Lamprey wrote:
  	  | Quote: |  	  |
 Best
 Richard
 > Hi Richard
 > AD applies to both.
 > Regards
 > Pete
 > G-RMAC Classic #109
 >>   Best
 >>   Richard
 >>   Read this topic online here:
 http://forums.matronics.com/viewtopic.php?p=476691#476691
		| Back to top |  |
		| JonSmith
				|  Posted: Fri Dec 29, 2017 3:47 am    Post subject: Re: LAA Airworthiness Alert. AIL December 2017 All 	Europas |   |
				| Hi Brian,  I am going to order the Profuel joint from Merlin as you described, in anticipation of the standard mod.   I bought one of Tim’s aluminium elbows some years ago but never got around to fitting it and it’s still in my garage!
Sorry for a silly question but do you think I need two of them (one for each end) or will one of them cut into two be sufficient?
 Cheers!
  	  | brian.davies44(at)gmail.c wrote: |  	  | As I explained in an earlier e-mail, there is no LAA Standard Mod to fit an aluminium elbow on an XS Europa. As nobody has applied for a standard Mod I have agreed with Andy Draper that I will do so.  It will be based on Tim Ward's aluminium elbow and will use Samco Profuel joints.  These can be purchased  from  www.merlinmotorsport.co.uk   in a short length of 76mm for UK Pounds 11.24 plus VAT and postage.  Currently there is a 39 day lead time on this item. Part number PSCH51-BLU
 Brian Davies
 G-TERN
 Classic Mono
		| Back to top |  |
