Tug or tow bar for the CJ6?
motoadve
PostPosted: Wed Oct 31, 2018 7:08 am    Post subject: Tug or tow bar for the CJ6? Reply with quote
I have the original tow bar, and already fell on my ass while pulling with all my strenght and the bar came off.
Also it is useless for pushing the plane back into the hangar.
Any recommendations on a tow bar or tug for the CJ 6?
If it is a good tow bar that is not the single axle kind, I would not mind it.
I was looking at this one, does anyone uses this? Its quite expensive though.
http://www.minimaxtugs.com/product-p/cj-6.htm
And adapter needs to be fitted in the nose gear (any problems with this?)
 Filesize:  5.26 KB
 Viewed:  10049 Time(s)
 Filesize:  5.15 KB
www.Backcountry182.com
Cessna 182 P
CJ -6
dougsappllc(at)gmail.com
PostPosted: Wed Oct 31, 2018 7:51 am    Post subject: Tug or tow bar for the CJ6? Reply with quote
The correct tow bar is L shaped, having the leg of the L going through the nose wheel axle. Sorry no stock at this time.  I have not stocked this part because it is rather expensive and the avg CJ driver is not willing to pay close to $300.00 for a tow bar.
One note on tugging the CJ6:
Be careful to not exceed the mfg's stops when turning sharply left or right.  It can get expensive real quickly.
Doug
On Wed, Oct 31, 2018 at 8:18 AM motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
--> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
www.Backcuountry182.com
Cessna 182 P
CJ -6
http://forums.matronics.com/viewtopic.php?p=484114#484114
http://forums.matronics.com//files/cj_6_3s_137.jpg
http://forums.matronics.com//files/cj_6_6t_241.jpg
pennington.construction.i
I use this to move my CJ around.  The unit can have what they call Yak attachments that work on the CJ great.  They are extra and work really well.
Mark
http://www.powertow.com/40-EZ-Aircraft-Tug_p_14.html
On Wed, Oct 31, 2018 at 11:18 AM motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
Cessna 182 P
CJ -6
saber369(at)comcast.net
PostPosted: Wed Oct 31, 2018 8:41 am    Post subject: Tug or tow bar for the CJ6? Reply with quote
Doug is correct about the left and right limits... Sadly this was a hard lesson learned at Sun-N-Fun for one of our CJ owners this year. The ramp guys starting pushing the airplane backwards with a tug and exceeding the limits breaking the scissors linkage and other damage.
I use this one with a golf cart (google Spoty's universal tow bar https://www.sportys.com/pilotshop/universal-aircraft-towbar.html) and for moving by hand, I use my old Mooney tow bar... it is a little loose, but I wrapped some duct tape around it an it works fine. I've seen others who simply use water pipes with a 90 degree fitting.
Just remember Doug Sapp's caution note about limits...
Saber
Doug
On Wed, Oct 31, 2018 at 8:18 AM motoadve < motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
--> Yak-List message posted by: "motoadve" < motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>
Cessna 182 P
CJ -6
hill(at)doctor-hill.com
PostPosted: Wed Oct 31, 2018 10:34 am    Post subject: Tug or tow bar for the CJ6? Reply with quote
This is what I use. It’s a remote controlled tug that has made moving the CJ-6A simple and easy.
https://acairtechnology.com/#
A Stearman PT-17 owner who shares our hangar uses the same model for the tail wheel.
The version that works best with the nose wheel of the CJ is T1V2
Warren Hill
N464TW
Mesa, AZ
On Oct 31, 2018, at 8:08 AM, motoadve <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)> wrote:
--> Yak-List message posted by: "motoadve" <motoadve(at)racsa.co.cr (motoadve(at)racsa.co.cr)>I have the original tow bar, and already fell on my ass while pulling with all my strenght and the bar came off.Also it is useless for pushing the plane back into the hangar.Any recommendations on a tow bar or tug for the CJ 6?If it is a good tow bar that is not the single axle kind, I would not mind it.I was looking at this one, does anyone uses this? Its quite expensive though.http://www.minimaxtugs.com/product-p/cj-6.htmAnd adapter needs to be fitted in the nose gear (any problems with this?)--------www.Backcuountry182.comCessna 182 PCJ -6Read this topic online here:http://forums.matronics.com/viewtopic.php?p=484114#484114Attachments: http://forums.matronics.com//files/cj_6_3s_137.jpghttp://forums.matronics.com//files/cj_6_6t_241.jpg
byronmfox(at)gmail.com
PostPosted: Wed Oct 31, 2018 12:01 pm    Post subject: Tug or tow bar for the CJ6? Reply with quote
Years ago I fabricated a tow bar with pre-threaded galvanized pipe sections and joints from Home Depot. If memory serves me correctly, 1" pipe fits nicely through the nose wheel on a CJ. Shortly, however,  I tired of pulling and pushing 2+ tons around, so I bought a tug. http://www.powertow.com/40-EZ-Aircraft-Tug_p_14.html
Also, Redline Aviation, an RPA Red Alert sponsor, sells the electric "Sidewinder." Not cheap, bit handy. https://www.redlineaviation.com/mooney/sidewinder-mooney-airplanes/
On Wed, Oct 31, 2018 at 11:41 AM Warren Hill <hill(at)doctor-hill.com (hill(at)doctor-hill.com)> wrote:
Warren Hill
N464TW
Mesa, AZ
Cessna 182 P
CJ -6
.. Blitz
[img]https://docs.google.com/uc?export=download&id=0B_Mqbj1Pr-xVTXVKN0t1SlVGT2M&revid=0B_Mqbj1Pr-xVcW0vU2crV2hMeVBQdVBmYWlaT0w2cVF3K2xBPQ[/img]
Byron M. Fox
80 Milland Drive
Mill Valley, CA 94941
415-307-2405
Ttail
PostPosted: Wed Oct 31, 2018 1:48 pm    Post subject: Re: Tug or tow bar for the CJ6? Reply with quote
What exactly are "the limits" ?
wlannon(at)shaw.ca
PostPosted: Wed Oct 31, 2018 2:07 pm    Post subject: Tug or tow bar for the CJ6? Reply with quote
Similar story for me. Used the original heavy Chinese one for years on my own and customer CJ’s until a new arrival at our field turned out to be a Supertow dealer. He decided I should have the Supertow 1 for the CJ’s and I kind of agreed with him. He also needed a new AWD complied with on his twin so a deal was struck!
Been using it for about 8 years now. Works great. Some problems with the lazy-susan resolved by replacing factory bolts with NAS high tensile units.
Walt
Sent: Wednesday, October 31, 2018 1:00 PM
To: Yak LIst (yak-list(at)matronics.com)
Subject: Re: Tug or tow bar for the CJ6?
Warren Hill
N464TW
Mesa, AZ
Cessna 182 P
CJ -6
... Blitz
Byron M. Fox
80 Milland Drive
415-307-2405
wlannon(at)shaw.ca
PostPosted: Wed Oct 31, 2018 2:15 pm    Post subject: Tug or tow bar for the CJ6? Reply with quote
I will take a photo for you.
Walt
PostPosted: Wed Oct 31, 2018 3:27 pm    Post subject: Tug or tow bar for the CJ6? Reply with quote
Please post that here.  I would like to see that to.
Mark
On Wed, Oct 31, 2018 at 6:21 PM Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
[quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
Walt
wlannon(at)shaw.ca
PostPosted: Wed Oct 31, 2018 9:02 pm    Post subject: Tug or tow bar for the CJ6? Reply with quote
Sorry for the lousy photos. Too damn old for smart phones & computers.
Photo 1; Front view of strut, rotating collar and stop lug.
" " 2. RH view of LH turn fixed stop (FWD).
" " 3. RH view of RH turn fixed stop (AFT)
The rotating collar of course is attached directly to the wheel fork and
inner strut through the scissor links. If the forced turn with a tug is
carried to stop contact (red on red) in either direction any further turn
will break something.
Walt
 Filesize:  1.07 MB
 Viewed:  10007 Time(s)
 Filesize:  1.14 MB
 Filesize:  1.23 MB
motoadve
PostPosted: Thu Nov 01, 2018 4:59 am    Post subject: Re: Tug or tow bar for the CJ6? Reply with quote
Thanks for the pics, this is very good to know.
Cessna 182 P
CJ -6
