willydewey
Joined: 24 Sep 2014 Posts: 53 Location: Guildford Surrey United Kingdom
Posted: Mon Dec 17, 2018 1:54 am Post subject: Grand Rapids EIS 2000 |
Hi Guys
I have an anomoly. My Grand Rapids EIS2000 reads 8.5 volts when the engine is running and I am in the air in the cruise. Ay the same time my supplimentary analogue voltmeter shows 13.8 volts as normal. Cannot stop the warning EIS light from flashing as a result. Any Ideas and suggestions would be much appreciated.
Best Regards and I hope all you Guys have a good Christmas and a safe and happy 2019
Very sorry about the crash in Holland. RIP and sympathies to the families
_________________ Give a wise man knowledge and he will be yet wiser |
Posted: Mon Dec 17, 2018 2:00 am Post subject: Grand Rapids EIS 2000 |
If it is anything like an MGL EIS that I recently had dealings with, it is probably a poor earth return from the EIS. Happy Christmas, David Joyce, GXSDJ
On 2018-12-17 09:54, willydewey wrote: | Quote: | | Quote: | --> Europa-List message posted by: "willydewey" <willydewey(at)gmail.com (willydewey(at)gmail.com)>
Hi Guys
http://forums.matronics.com/viewtopic.php?p=486339#486339
lotstore.com
.matronics.com/contribution
ics.com
.com
Burrilla
Posted: Mon Dec 17, 2018 2:39 am Post subject: Grand Rapids EIS 2000 |
I assume that the two instruments are measuring the voltage at the same point and that the connections to the EIS are all good.
I had a faulty reading on one sensor on mine and it turned out the pin wasn’t locked in the plug so had shaken loose.
If you determine it is a faulty unit I have one for sale I removed last year and it is functional.
Alan Burrill
G-OBJT
| Quote: | On 17 Dec 2018, at 09:54, willydewey <willydewey(at)gmail.com> wrote:
Hi Guys
pjeffers(at)talktalk.net Guest
Hi Bill,
The 13.8volt bit would seem to indicate that the battery and charging system is AOK. I would probably concur with David and go for high resistance in the +ve sensing or earth connections on the EIS itself. Failing that contact Grand Rapids Avionics in the States. They really know their stuff.
Pete
PS Have a very happy Xmas.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of davidjoyce(at)doctors.org.uk
Sent: 17 December 2018 10:00
Subject: Re: Grand Rapids EIS 2000
On 2018-12-17 09:54, willydewey wrote: | Quote: | | Quote: | | --> Europa-List message posted by: "willydewey" <willydewey(at)gmail.com (willydewey(at)gmail.com)> Hi GuysI have an anomoly. My Grand Rapids EIS2000 reads 8.5 volts when the engine is running and I am in the air in the cruise. Ay the same time my supplimentary analogue voltmeter shows 13.8 volts as normal. Cannot stop the warning EIS light from flashing as a result. Any Ideas and suggestions would be much appreciated.Best Regards and I hope all you Guys have a good Christmas and a safe and happy 2019Very sorry about the crash in Holland. RIP and sympathies to the familiesBill --------Give a wise man knowledge and he will be yet wiser | 01234567890123456789 | Quote: | | I have an anomoly. My Grand Rapids EIS2000 reads 8.5 volts when the engine is running and I am in the air in the cruise. Ay the same time my supplimentary analogue voltmeter shows 13.8 volts as normal. Cannot stop the warning EIS light from flashing as a result. Any Ideas and suggestions would be much appreciated. | 0 | Quote: | | I have an anomoly. My Grand Rapids EIS2000 reads 8.5 volts when the engine is running and I am in the air in the cruise. Ay the same time my supplimentary analogue voltmeter shows 13.8 volts as normal. Cannot stop the warning EIS light from flashing as a result. Any Ideas and suggestions would be much appreciated. | 1 |
Virus-free. www.avg.com
Burrilla
Posted: Mon Dec 17, 2018 3:02 am Post subject: Grand Rapids EIS 2000 |
It's worth noting that the Sensor is attached internally to the `Power input for the device, there is no separate sensor or earth, so effectively the voltage is that of the Power in to the device and putting a resistor or any other complaint in the circuit will impact he power to the device itself.
Pin 9 is the Power input and ground is on pin 13 of the connector.
I have a paper copy of the wiring diagram if that helps.
Alan Burrill
G_OBJT
| Quote: | On 17 Dec 2018, at 10:28, Alan Burrill <alanb(at)dpy01.co.uk> wrote:
Alan Burrill
G-OBJT
> Hi Guys
> Bill
willydewey
Posted: Sun Dec 30, 2018 7:01 am Post subject: Re: Grand Rapids EIS 2000 |
Thanks Guys for your replies all very much appreciated.
With the Christmas and New year Holidays upon us I have not been to the airfield to carry out the suggested work but hope to do so shortly providing the Beast from the East does not arrive.
Happy New year to One and All
Bill Dewey G-IANI
willydewey
Posted: Thu Mar 14, 2019 8:34 am Post subject: Re: Grand Rapids EIS 2000 |
| Burrilla wrote: | I assume that the two instruments are measuring the voltage at the same point and that the connections to the EIS are all good.
Alan Burrill
G-OBJT
| Quote: | On 17 Dec 2018, at 09:54, willydewey <willydewey> wrote:
Hi Guys
HI Alan
I am still struggeling with the voltage on my GR 2000 EIS and have tried out the suggestions by the GR suppott team as well as those proposed by Pete Jeffers and David Joyce all to no avail. Its a bit uneconomical to send the unit back to GR and you mentioned that you had one hanging around that you might be willing to part with. If thats still the case how much are you asking for it as it might be a cheaper route for me. unfortunatly the builder didnt leave any slack in the connecting cables and so just to remove the EIS its necessary to remove the binacle as well as the instrument panels
best regards
Bill Dewey GIANI
