Grand Rapids EIS 2000
willydewey
PostPosted: Mon Dec 17, 2018 1:54 am    Post subject: Grand Rapids EIS 2000 Reply with quote
Hi Guys
I have an anomoly. My Grand Rapids EIS2000 reads 8.5 volts when the engine is running and I am in the air in the cruise. Ay the same time my supplimentary analogue voltmeter shows 13.8 volts as normal. Cannot stop the warning EIS light from flashing as a result. Any Ideas and suggestions would be much appreciated.
Best Regards and I hope all you Guys have a good Christmas and a safe and happy 2019
Very sorry about the crash in Holland. RIP and sympathies to the families
Bill
Give a wise man knowledge and he will be yet wiser
davidjoyce(at)doctors.org
PostPosted: Mon Dec 17, 2018 2:00 am    Post subject: Grand Rapids EIS 2000 Reply with quote
If it is anything like an MGL EIS that I recently had dealings with, it is probably a poor earth return from the EIS. Happy Christmas, David Joyce, GXSDJ
On 2018-12-17 09:54, willydewey wrote:
--> Europa-List message posted by: "willydewey" <willydewey(at)gmail.com (willydewey(at)gmail.com)>
Hi Guys
Bill
http://forums.matronics.com/viewtopic.php?p=486339#486339
lotstore.com
.matronics.com/contribution
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
Burrilla
PostPosted: Mon Dec 17, 2018 2:39 am    Post subject: Grand Rapids EIS 2000 Reply with quote
I assume that the two instruments are measuring the voltage at the same point and that the connections to the EIS are all good.
I had a faulty reading on one sensor on mine and it turned out the pin wasn’t locked in the plug so had shaken loose.
If you determine it is a faulty unit I have one for sale I removed last year and it is functional.
Alan Burrill
G-OBJT
Sent from my iPad
On 17 Dec 2018, at 09:54, willydewey <willydewey(at)gmail.com> wrote:
Hi Guys
Bill
pjeffers(at)talktalk.net
Hi Bill,
The 13.8volt bit would seem to indicate that the battery and charging system is AOK.   I would probably concur with David and go for high resistance in the +ve sensing or earth connections on the EIS itself.   Failing that contact Grand Rapids Avionics  in the States.  They really know their stuff.
Pete
PS Have a very happy Xmas.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of davidjoyce(at)doctors.org.uk
Sent: 17 December 2018 10:00
Subject: Re: Grand Rapids EIS 2000
--> Europa-List message posted by: "willydewey" <willydewey(at)gmail.com (willydewey(at)gmail.com)> Hi GuysI have an anomoly.  My Grand Rapids EIS2000 reads 8.5 volts when the engine is running and I am in the air in the cruise. Ay the same time my supplimentary analogue voltmeter shows 13.8 volts as normal. Cannot stop the warning EIS light from flashing as a result. Any Ideas and suggestions would be much appreciated.Best Regards and I hope all you Guys have a good Christmas and a safe and happy 2019Very sorry about the crash in Holland. RIP and sympathies to the familiesBill --------Give a wise man knowledge and he will be yet wiser
Hi Guys
Hi Guys
Hi Guys
Hi Guys
Hi Guys
Hi Guys
5
Hi Guys
6
Hi Guys
7
Hi Guys
8
Hi Guys
9
Virus-free. www.avg.com
Burrilla
PostPosted: Mon Dec 17, 2018 3:02 am    Post subject: Grand Rapids EIS 2000 Reply with quote
It's worth noting that the Sensor is attached internally to the `Power input for the device, there is no separate sensor or earth, so effectively the voltage is that of the Power in to the device and putting a resistor or any other complaint in the circuit will impact he power to the device itself.
Pin 9 is the Power input and ground is on pin 13 of the connector.
I have a paper copy of the wiring diagram if that helps.
Alan Burrill
G_OBJT
Alan Burrill
G-OBJT
Sent from my iPad
> Hi Guys
> Bill
willydewey
PostPosted: Sun Dec 30, 2018 7:01 am    Post subject: Re: Grand Rapids EIS 2000 Reply with quote
Thanks Guys for your replies all very much appreciated.
With the Christmas and New year Holidays upon us I have not been to the airfield to carry out the suggested work but hope to do so shortly providing the Beast from the East does not arrive.
Happy New year to One and All
Bill Dewey G-IANI
willydewey
PostPosted: Thu Mar 14, 2019 8:34 am    Post subject: Re: Grand Rapids EIS 2000 Reply with quote
Alan Burrill
G-OBJT
Sent from my iPad
On 17 Dec 2018, at 09:54, willydewey <willydewey> wrote:
Hi Guys
Bill
HI Alan
I am still struggeling with the voltage on my GR 2000 EIS and have tried out the suggestions by the GR suppott team as well as those proposed by Pete Jeffers and David Joyce all to no avail. Its a bit uneconomical to send the unit back to GR and you mentioned that you had one hanging around that you might be willing to part with. If thats still the case how much are you asking for it as it might be a cheaper route for me. unfortunatly the builder didnt leave any slack in the connecting cables and so just to remove the EIS its necessary to remove the binacle as well as the instrument panels
best regards
Bill Dewey GIANI
