		draftsjust417(at)gmail.co Guest
				 Posted: Mon Apr 01, 2019 6:13 am    Post subject: suggestions on changing Housai rubber shock mounts? |
				Ok Housai guru's...
 It's not necessary soon, but eventually I'll need to replace the rubber shock mounts on my CJ's Housai, around the engine mount ring.
 I understand there are (16) total: (  on front and (  on back?
 Are there any special techniques I should be aware of, that anyone has found particularly effective?
 Pitfalls to avoid?
 Seems like placing a tail stand is wise, and perhaps shoring up the engine to counteract its weight to relieve pressure on the (  mounting studs?
 Doesn't seem like the studs need to be removed. ?
 Planning ahead before I make a costly mistake...
 Many thanks all-
 Justin Drafts
 N280NC
 Everett, WA
  |  | - The Matronics Yak-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		JL2A
				 Posted: Fri Apr 26, 2019 9:33 pm    Post subject: Re: suggestions on changing Housai rubber shock mounts? |
				Normal shop engine crane lifting through a fat strap around the gearbox / crankcase interface with tail supported seems to work nicely.
 We have given up using the rubber engine mounts. They do not seem to last very long. Instead we use a urethane material that is much more durable. They aren't cheap but then nor is having to change those 16 pesky rubber things every 100 hours.
		A35plt
  Joined: 14 Aug 2013 Posts: 9 Location: Wiesbaden, Germany
				 Posted: Sat Apr 27, 2019 8:20 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? |
				JL2A do you have a source for these? I need to change mine soon as well. Thanks Robert
				 Posted: Mon Apr 29, 2019 8:21 am    Post subject: suggestions on changing Housai rubber shock mounts? |
				Ah good point, THANKS for inputs... this looks like a good summer project for me.Justin/N280NC
 On Fri, Apr 26, 2019 at 10:39 PM JL2A <info(at)flyingwarbirds.com.au.matronics.com (info(at)flyingwarbirds.com.au.matronics.com)> wrote:
  	  | Quote: | 	 		  --> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.com (info(at)flyingwarbirds.com.au.matronics.com)>
  http://forums.matronics.com/viewtopic.php?p=488979#488979
		stephen.hayne
  Joined: 01 Nov 2013 Posts: 59 Location: United States
				 Posted: Mon Apr 29, 2019 8:37 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? |
				 	  | JL2A wrote: | 	 		  | We have given up using the rubber engine mounts. They do not seem to last very long. Instead we use a urethane material that is much more durable. They aren't cheap but then nor is having to change those 16 pesky rubber things every 100 hours. |
 Can you please post a source?  I'm facing this when I can get around to it...
  _________________ -
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
 http://selfsynchronize.com/hayne/plane/cj6.asp |
		stephen.hayne
				 Posted: Mon Apr 29, 2019 8:48 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? |
  _________________ -
443LM Nanchang CJA
		Jacquescj6
  Joined: 20 Dec 2011 Posts: 23 Location: Swakopmund , Namibia
				 Posted: Thu Jan 06, 2022 8:06 am    Post subject: Re: suggestions on changing Housai rubber shock mounts? |
				Hi all
 Could any body explain how to replace these rubber shocks.
 Do one need to take the hole engine of or can you replace them one at a time with out taking the engine of the ring.
 Any help would be appreciated.
