draftsjust417(at)gmail.co Guest
Posted: Mon Apr 01, 2019 6:13 am Post subject: suggestions on changing Housai rubber shock mounts? |
Ok Housai guru's...
It's not necessary soon, but eventually I'll need to replace the rubber shock mounts on my CJ's Housai, around the engine mount ring.
I understand there are (16) total: ( on front and ( on back?
Are there any special techniques I should be aware of, that anyone has found particularly effective?
Pitfalls to avoid?
Seems like placing a tail stand is wise, and perhaps shoring up the engine to counteract its weight to relieve pressure on the ( mounting studs?
Doesn't seem like the studs need to be removed. ?
Planning ahead before I make a costly mistake...
Many thanks all-
Justin Drafts
N280NC
Everett, WA
JL2A
Posted: Fri Apr 26, 2019 9:33 pm Post subject: Re: suggestions on changing Housai rubber shock mounts? |
Normal shop engine crane lifting through a fat strap around the gearbox / crankcase interface with tail supported seems to work nicely.
We have given up using the rubber engine mounts. They do not seem to last very long. Instead we use a urethane material that is much more durable. They aren't cheap but then nor is having to change those 16 pesky rubber things every 100 hours.
A35plt
Joined: 14 Aug 2013 Posts: 9 Location: Wiesbaden, Germany
Posted: Sat Apr 27, 2019 8:20 am Post subject: Re: suggestions on changing Housai rubber shock mounts? |
JL2A do you have a source for these? I need to change mine soon as well. Thanks Robert
Posted: Mon Apr 29, 2019 8:21 am Post subject: suggestions on changing Housai rubber shock mounts? |
Ah good point, THANKS for inputs... this looks like a good summer project for me.Justin/N280NC
On Fri, Apr 26, 2019 at 10:39 PM JL2A <info(at)flyingwarbirds.com.au.matronics.com (info(at)flyingwarbirds.com.au.matronics.com)> wrote:
| Quote: | --> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au.matronics.com (info(at)flyingwarbirds.com.au.matronics.com)>
http://forums.matronics.com/viewtopic.php?p=488979#488979
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
stephen.hayne
Joined: 01 Nov 2013 Posts: 59 Location: United States
Posted: Mon Apr 29, 2019 8:37 am Post subject: Re: suggestions on changing Housai rubber shock mounts? |
| JL2A wrote: | | We have given up using the rubber engine mounts. They do not seem to last very long. Instead we use a urethane material that is much more durable. They aren't cheap but then nor is having to change those 16 pesky rubber things every 100 hours. |
Can you please post a source? I'm facing this when I can get around to it...
_________________ -
Stephen Hayne, Cyber Security Consultant, Professor Emeritus (retired)
443LM Nanchang CJA
http://selfsynchronize.com/hayne/plane/cj6.asp |
stephen.hayne
Posted: Mon Apr 29, 2019 8:48 am Post subject: Re: suggestions on changing Housai rubber shock mounts? |
_________________ -
443LM Nanchang CJA
Jacquescj6
Joined: 20 Dec 2011 Posts: 23 Location: Swakopmund , Namibia
Posted: Thu Jan 06, 2022 8:06 am Post subject: Re: suggestions on changing Housai rubber shock mounts? |
Hi all
Could any body explain how to replace these rubber shocks.
Do one need to take the hole engine of or can you replace them one at a time with out taking the engine of the ring.
Any help would be appreciated.
