Colyn Case
Joined: 12 Oct 2009 Posts: 13 Location: Thetford Center
Posted: Thu May 28, 2020 9:29 am Post subject: coax switches for sharing an antenna |
I'm adding a second transponder to my carbon airplane and am out of places to mount a second antenna. I would only be using one transponder at a time so I am thinking of using a coax switch to select which transponder gets the antenna. I'm not sure if these are built for my application, namely a transceiver vs. a transmitter. Here's an example of one I am considering. Anything I need to look out for here?
...and what does "latching" mean?
https://www.mouser.com/datasheet/2/404/CCR-33S_CR-33S_LATCHING-1228654.pdf
_________________ Colyn Case
colyncase@earthlink.net |
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Thu May 28, 2020 2:59 pm Post subject: Re: coax switches for sharing an antenna |
A switch will fail someday. Or a transponder will inadvertently be turned on
without an antenna connected. A transponder could be damaged. I suggest
that a second antenna be installed even if the location does not comply with
the manufactures suggested spacing. It will not hurt to locate a transponder
antenna closer to a com antenna than recommended because they operate at
considerably different frequencies.
_________________ Joe Gores |
Colyn Case
Posted: Thu May 28, 2020 6:41 pm Post subject: Re: coax switches for sharing an antenna |
It's complicated. to be that close to the com antenna I would have to be physically mounted in the metal that forms its ground plane.
Does the transponder blow up if its side of the switch is open?
Colyn Case
Posted: Thu May 28, 2020 6:47 pm Post subject: Re: coax switches for sharing an antenna |
nvm. i see there's a risk there...
Colyn Case
Posted: Thu May 28, 2020 8:04 pm Post subject: Re: coax switches for sharing an antenna |
Wait. Does a transponder ever transmit without receiving anything?
cluros(at)gmail.com Guest
Posted: Thu May 28, 2020 8:05 pm Post subject: coax switches for sharing an antenna |
I think most transponders have a supression line that is used to make sure only one can transmit at a time. No switching required.
On Thu, May 28, 2020, 19:52 Colyn Case <colyncase(at)earthlink.net (colyncase(at)earthlink.net)> wrote:
Quote: | --> AeroElectric-List message posted by: "Colyn Case" <colyncase(at)earthlink.net (colyncase(at)earthlink.net)>
Colyn Case
http://forums.matronics.com/viewtopic.php?p=496563#496563
Electric-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/contribution
Posted: Thu May 28, 2020 8:51 pm Post subject: coax switches for sharing an antenna |
Squawk Ident?
On Thu, May 28, 2020, 21:10 Colyn Case <colyncase(at)earthlink.net (colyncase(at)earthlink.net)> wrote:
Colyn Case
http://forums.matronics.com/viewtopic.php?p=496565#496565
FORUMS -
WIKI -
b Site -
