coax switches for sharing an antenna
Colyn Case
PostPosted: Thu May 28, 2020 9:29 am    Post subject: coax switches for sharing an antenna Reply with quote
I'm adding a second transponder to my carbon airplane and am out of places to mount a second antenna. I would only be using one transponder at a time so I am thinking of using a coax switch to select which transponder gets the antenna. I'm not sure if these are built for my application, namely a transceiver vs. a transmitter. Here's an example of one I am considering. Anything I need to look out for here?
...and what does "latching" mean?
https://www.mouser.com/datasheet/2/404/CCR-33S_CR-33S_LATCHING-1228654.pdf
Colyn Case
colyncase@earthlink.net
PostPosted: Thu May 28, 2020 2:59 pm    Post subject: Re: coax switches for sharing an antenna Reply with quote
A switch will fail someday. Or a transponder will inadvertently be turned on
without an antenna connected. A transponder could be damaged. I suggest
that a second antenna be installed even if the location does not comply with
the manufactures suggested spacing. It will not hurt to locate a transponder
antenna closer to a com antenna than recommended because they operate at
considerably different frequencies.
Joe Gores
Colyn Case
PostPosted: Thu May 28, 2020 6:41 pm    Post subject: Re: coax switches for sharing an antenna Reply with quote
It's complicated. to be that close to the com antenna I would have to be physically mounted in the metal that forms its ground plane.
Does the transponder blow up if its side of the switch is open?
Colyn Case
Colyn Case
PostPosted: Thu May 28, 2020 6:47 pm    Post subject: Re: coax switches for sharing an antenna Reply with quote
nvm. i see there's a risk there...
Colyn Case
Colyn Case
PostPosted: Thu May 28, 2020 8:04 pm    Post subject: Re: coax switches for sharing an antenna Reply with quote
Wait. Does a transponder ever transmit without receiving anything?
Colyn Case
cluros(at)gmail.com
PostPosted: Thu May 28, 2020 8:05 pm    Post subject: coax switches for sharing an antenna Reply with quote
I think most transponders have a supression line that is used to make sure only one can transmit at a time. No switching required.
On Thu, May 28, 2020, 19:52 Colyn Case <colyncase(at)earthlink.net (colyncase(at)earthlink.net)> wrote:
--> AeroElectric-List message posted by: "Colyn Case" <colyncase(at)earthlink.net (colyncase(at)earthlink.net)>
Colyn Case
http://forums.matronics.com/viewtopic.php?p=496563#496563
cluros(at)gmail.com
PostPosted: Thu May 28, 2020 8:51 pm    Post subject: coax switches for sharing an antenna Reply with quote
Squawk Ident?
On Thu, May 28, 2020, 21:10 Colyn Case <colyncase(at)earthlink.net (colyncase(at)earthlink.net)> wrote:
Colyn Case
http://forums.matronics.com/viewtopic.php?p=496565#496565
