ULPower Alternator/Regulator
cluros(at)gmail.com
PostPosted: Thu Dec 23, 2021 9:18 am    Post subject: ULPower Alternator/Regulator Reply with quote
Does anyone have experience with this system? My friend is installing a UL350 Engine and their wiring diagram and instructions specify no protective devices between the alternator and the battery.
Does anyone know if this alternator/regulator combination can suffer from an overvoltage event? Or is the regulator fault tolerant?
Sebastien
PostPosted: Thu Dec 23, 2021 11:34 am    Post subject: Re: ULPower Alternator/Regulator Reply with quote
When the alternator "B" lead shorts to ground, the pilot will be lucky if there is no
fire when the "B" lead turns white hot and melts from high battery current.
Now that the alternator is no longer connected, the electrical
system relies on the battery. But half of the battery energy has already been
depleted melting the "B" lead. Either a large fuse or fusible link should
protect the "B" lead from excessive battery current, regardless of what UL Power says.
Joe Gores
PostPosted: Thu Dec 23, 2021 2:01 pm    Post subject: ULPower Alternator/Regulator Reply with quote
Protecting b-lead wiring from hard faults within
the alternator itself is a legacy protocol in
T/C aircraft since the first Ford alternator was
bolted to a Cessna (approx 1964).
However, LOTS of automotive applications tie
the alternator b-lead right to battery (+)
(like my '87 GMC) with some later models
adding a fusible link at the battery end
(like the 97 Chevy I worked on last week).
What kind of alternator is on the UL350, wound
field or permanent magnet?
fault tolerant?
There is NO alternator system immune to OV events.
Probability, severity and risk run the gamut from
a little puff of smoke to a major incendiary event.
That needs to be sorted out in a failure mode
effects analysis with appropriate prophylactics
incorporated.
As supplier of the system, the engine manufacturer
SHOULD have conducted those studies and published
well considered protocols in their manual . . .
unfortunately, few engine suppliers have any notion
of what that process entails.
The usual answer to a query on the matter is: "we've
got xxxx of these flying with no reported events of
noteworthy magnitude."
For this List to offer any more considered advice,
much more data are needed as to system characteristics.
The SAFE thing is to incorporate b-lead and ov protection
as a matter of policy . . . it's light, cheap and better
to have it and not need it as opposed to needing and
not having.
out of that stuff?"
dj_theis
PostPosted: Fri Dec 24, 2021 6:29 am    Post subject: Re: ULPower Alternator/Regulator Reply with quote
From their website, all the UL 350 engines are listed as having integrated PMA charging systems with external R/R. All listed at 30 amp total and requiring 15 amps for the engine ignition and fuel pumps, leaving15 amps for Avionics.
https://ulpower.com/en/engines/ul350/ul350is
Dan Theis
Scratch building Sonex #1362
Revmaster Alternator problem solved.
dj_theis
PostPosted: Fri Dec 24, 2021 6:30 am    Post subject: Re: ULPower Alternator/Regulator Reply with quote
Dan Theis
cluros(at)gmail.com
PostPosted: Fri Dec 24, 2021 8:24 pm    Post subject: ULPower Alternator/Regulator Reply with quote
As Dan already posted, the alternator is permanent magnet.
I was wondering more if anyone knows if the voltage regulator has any over-voltage protection included. ULPower are apparently very good about responding to inquiries so I will send them an email and post the reply to this list.
In any case, the electrical system on the aircraft in question has already been installed but was designed by a highly qualified and experienced electrical & robotics engineer with no GA aircraft knowledge. The aircraft owner sent me the diagram so that I could admire it but a quick and dirty FMEA showed some problems. A review of the manufacturer's instructions lead me to suggest that they rewire it to conform with those instructions but since the alternator wiring already includes a current limiter and a solenoid I thought it would be appropriate to leave those in rather than create the problem Joe pointed out vis a vis shorted b lead.1 If I can get permission I will post the schematic to the list; notwithstanding its problematic features it's quite a work of art.
Sebastien
On Thu, Dec 23, 2021 at 2:11 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
fault tolerant?
  incorporated.
  not having.
  out of that stuff?"
PostPosted: Sun Dec 26, 2021 1:33 pm    Post subject: ULPower Alternator/Regulator Reply with quote
Okay, thanks . . . is there a recommended system
wiring diagram I can access?
out of that stuff?"
cluros(at)gmail.com
PostPosted: Sun Dec 26, 2021 1:55 pm    Post subject: ULPower Alternator/Regulator Reply with quote
On Sun, Dec 26, 2021 at 1:37 PM Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  out of that stuff?"
UL350_Electrical_System.pdf
 Filename:  UL350_Electrical_System.pdf
 Filesize:  385.81 KB
 Downloaded:  459 Time(s)
PostPosted: Sun Dec 26, 2021 5:28 pm    Post subject: Re: ULPower Alternator/Regulator Reply with quote
If that 40 amp fuse blows, the engine quits. Remove it.
Repurpose that 40 amp fuse to protect the electrical system from a shorted
alternator or its "B" lead. Or use a fuselink.
Good workmanship will prevent the engine busbar from shorting out.
Relocate the engine Fuses. They should be between the busbar and the switches.
The 60 amp fuse is not needed. Eliminate it.
I suggest that you use battery contactor in series with the aircraft main power bus
(not to be confused with the engine bus).
There should be a fuse between the engine busbar and the start push button.
Joe Gores
PostPosted: Mon Dec 27, 2021 4:16 pm    Post subject: ULPower Alternator/Regulator Reply with quote
Sebastien
Is this document published on the 'net? If so, permission to republish
should not be an issue as long as original source is not obscured.
If you know of a link, you can share that and let people download
themselves.
out of that stuff?"
cluros(at)gmail.com
PostPosted: Mon Dec 27, 2021 4:23 pm    Post subject: ULPower Alternator/Regulator Reply with quote
No, it was sent to me by a member of our local Recreational Aircraft Association and was created by a friend of his for his Zenith 750.
On Mon, Dec 27, 2021, 19:19 Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Sebastien
 themselves.
  out of that stuff?"
Ceengland
PostPosted: Mon Dec 27, 2021 4:30 pm    Post subject: ULPower Alternator/Regulator Reply with quote
Sebastien
 themselves.
A little google-foo yields:
https://ulpower.com/en/engines/manuals
The website itself doesn't seem to have a public-facing link to the page, but there it is.
Ceengland
PostPosted: Mon Dec 27, 2021 4:32 pm    Post subject: ULPower Alternator/Regulator Reply with quote
750.
I thought we were talking about ULPower's diagram in their installation
manual. Are we talking about some individual's self-created diagram?
cluros(at)gmail.com
PostPosted: Mon Dec 27, 2021 4:54 pm    Post subject: ULPower Alternator/Regulator Reply with quote
There are two documents mentioned in this discussion Charlie. One is the ULPower diagram I attached to the thread, the other is a document that I cannot share at this time. I was reviewing this document and found several problems with it and was trying to help them correct these problems by pointing them to the installation instructions from ULPower. Unfortunately while these instructions are much better than their current architecture, I'm still finding them problematic for their own reasons as Joe and Bob have pointed out. I have also pointed them to the AEC and Z101b.
They seem receptive to suggestions but the aircraft is already built. I'm not sure how far they are willing to redo the electrical system. As it stands there are 3 circuit protective devices, one solenoid, and one switch between the battery and the EDC. The alternator power goes through 2 extra protective devices and an additional solenoid before getting to the EDC for a whopping total of 8 points of failure in series between alternator and engine but only 5 from the battery.
On Mon, Dec 27, 2021 at 4:35 PM Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
> 750.
="noreferrer" target="_blank">https://matronics.com/contribution
Ceengland
PostPosted: Mon Dec 27, 2021 5:21 pm    Post subject: ULPower Alternator/Regulator Reply with quote
> 750.
Ah; got it now. If it's a dual ECU, the factory diagram has its own issues, that while they may not be single points of outright failure, they could cause serious issues with engine operation. For instance, it looks like a failed injector current sink (switches, labeled A, B, a, & z)  in either ECU could cause the injector to stay open.
[img]cid:part1.nZY0Ilt8.ek2QY5wG(at)gmail.com[/img] Virus-free. www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 Filesize:  80.27 KB
 Viewed:  11825 Time(s)
cluros(at)gmail.com
PostPosted: Mon Dec 27, 2021 5:32 pm    Post subject: ULPower Alternator/Regulator Reply with quote
In this particular case it's a single ECU installation. Single battery and alernator as well.
On Mon, Dec 27, 2021, 20:25 Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
> 750.
Virus-free. www.avast.com [url=#m_-8456691566823616747_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 Filesize:  80.27 KB
 Filesize:  80.27 KB
yellowduckduo(at)gmail.co
PostPosted: Mon Dec 27, 2021 5:48 pm    Post subject: ULPower Alternator/Regulator Reply with quote
I've found that a failed open injector in flight is of little concern.
At high power settings it may not even be noticed.  At mid power levels
it might run a little rough. Close the throttle too far and it merely
encourages you to not reduce power too much until you have to.  Most
injectors are sized to run fairly high duty cycles at full power.
Ken
> Zenith
> > 750.
> installation
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=icon>
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient&utm_term=link>
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
