Control positioning during ground handling
Goto page Previous  1, 2, 3  Next
planecrazzzy
PostPosted: Sun Jul 30, 2006 11:12 am    Post subject: Re: Control positioning during ground handling Reply with quote
Thanks Big Lar, I get it now....
If they really wanna make fun of me , I'm from Calif....
There's aways somethin there....or just make it up...
How's work Big Lar, ....Been really hot here, must be Hell there...
Been hitting Fly-ins like crazzzy around here , Kind of glad there wasn't
one this weekend , or I'da had to be out in this heat....
Gotta Fly...
Mike in MN , Dreamin about my next plane
 Filesize:  119.89 KB
 Viewed:  437 Time(s)
biglar
PostPosted: Sun Jul 30, 2006 1:15 pm    Post subject: Control positioning during ground handling Reply with quote
Humid and hotter'n hell here last week, but it's moderated some now.
Grin at the idiots, and talk nice to the sane ones. Helps yer own sanity.
Don't let the a--holes getcha down.
They're closing the hotel I work at for 18 - 24 months for a complete
renovation, remodeling, and expansion, so as of Aug 13, I'm out of a job.
What Fun ! ! ! Do not Archive.
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
PostPosted: Sun Jul 30, 2006 1:56 pm    Post subject: Control positioning during ground handling Reply with quote
| I imagine it would take at least 20 knots of tail wind to lift the
tail in this manner if the stick were full back. | --------
| Dave Bigelow
Dave B/Gang:
Takes very little tail wind to put the FF on its nose. Far less than
20 kts or 20 mph.
I, personally, can not imagine taxiing and flying a FF in 20 kts or
more wind.
Remember putting the FF on its nose while taxiing back to take off at
Sun and Fun several years ago. Certainly was nothing near 20 kts that
did the number on me and my trusty FF. The idle was set too high on
the 447. When it went up on its nose, the high idling 447 kept it
going for half the length of the field before I could get it stopped.
When it did stop, I stuck my foot out, pushed it back up, taxied on
down and took off like nothing had happened. All in a days work.
PostPosted: Sun Jul 30, 2006 2:00 pm    Post subject: Control positioning during ground handling Reply with quote
So if the wind comes from the front or rear it passes over the up
elevator and the lift vector on the tail is going to be down.
| At I22 it is not uncommon to taxi in winds of 20+ mph.
| Jack B. Hart FF004
Jack B Hart/Gang:
Not so.
To taxi a FF with the stick back and a 20+ mph tail wind will promptly
put you on your nose.
Check your wind speed indicator. I get the impression it needs to be
calibrated, somewhat.
PostPosted: Sun Jul 30, 2006 2:20 pm    Post subject: Control positioning during ground handling Reply with quote
| The position of the stick
| that requires the highest rpm to lift the tail is the most favorable
for
| downwind taxiing.
| Jack B. Hart FF004
Jack B Hart/Gang:
You don't reckon the FF high thrust line is having anything to do with
the tail raising when tied down no matter where the control stick is
located? I bet you could put a concrete block on the horizontal
stabilizer and still get the tail off the ground with the stick in the
aft position at wide open throttle.
Reaction of an aircraft tied to a stake and down wind taxiing don't
have much in common best I can tell.
Ed in JXN
PostPosted: Sun Jul 30, 2006 2:43 pm    Post subject: Control positioning during ground handling Reply with quote
Way too much debate going on about this for me. Seems it was worked out
just after the Wrights did their thing, and has been taught by everyone from
them to the FAA Flight Training Handbook to Langeswieche to... Into a
headwind stick back; with a tailwind stick forward.
But there are always those who will debate the laws of physics.
BTW, if someone is good at engineering, I have an interesting CG question I
need answered. Simple, but hard.
Ed in JXN (MI)
MkII/503
jindoguy(at)gmail.com
PostPosted: Sun Jul 30, 2006 3:19 pm    Post subject: Control positioning during ground handling Reply with quote
Jack, et al, As it happens I was out hacking the weeds down around the lagoon this afternoon when a 182 razorback made the turn to back taxi down the runway. It was blowing 20 with gusts to 30 here in the Sunflower State at the time. He had full up elevator cranked in and as he came around the tail of the plane began pogoing up and down far more than the surface of the runway (dead grass over sunbaked dirt) should cause. Didn't take long for him to get the elevator to full down position and the pogoing stopped.
Check out "The Compleat Taildragger Pilot" by Harvey S. Plourde, or "Stick and Rudder" by Wolfgang Langewiesche.
Neither agrees with me about full stick forward while taxiing up wind or at the start of the takeoff roll, it is my adaptation to the Mk III and it works for me.
Rick
Rick Girard
"Ya'll drop on in"
takes on a whole new meaning
when you live at the airport.
Eugene Zimmerman
PostPosted: Sun Jul 30, 2006 3:32 pm    Post subject: Control positioning during ground handling Reply with quote
Jack,
I believe your logic is flawless but your analysis of the effect is
incorrect due to a very significant piece of information has not
been taken into consideration.
That would be the completely different horizontal stabilizer and
elevator assembly leading edge and trailing plan-form SHAPE relative
to the each specific wind direction.
If you were to reverse mount your horizontal stabilizer and elevator
assembly surfaces would you still have enough elevator control
authority? Certainly not!
On Jul 30, 2006, at 2:00 PM, Jack B. Hart wrote:
If the wind flow is horizontal to the ground, it does not matter if
the wind
is up or down wind as it passes over the horizontal stabilizer and
elevator
assembly. In both cases the air must travel further to pass below the
assembly than the air that passes above it. This will place down
load on
the tail.
APilot(at)webtv.net
PostPosted: Sun Jul 30, 2006 9:01 pm    Post subject: Control positioning during ground handling Reply with quote
CG problems are fun.....let'r rip. Even if my answer is not popular, I
bet I will learn something. Vic
jbhart(at)onlyinternet.ne
PostPosted: Mon Jul 31, 2006 4:24 am    Post subject: Control positioning during ground handling Reply with quote
Kolbers,
I did not mean to question how you have been trained to taxi in windy
conditions, or how others taxi their specific aircraft. But with a Kolb
FireFly you can not load the tail up or down with prop wash. If the
horizontal stabilizer was placed higher on the tail so it was in prop wash,
I would change my stick positions. I have always admired the Mini-Max in the
way they could max out the throttle on the beginning of the take off. The
tail is up immediately with good control and no fear of putting it on it's
nose. But I picked the FireFly for the up front view, a pusher, with a high
thrust line, and I have to accept that I will never be able to launch it
like a Mini-Max.
Not picking on a J-3 Cub but only using it as an example and moving it
closer to a Kolb design, how would ground handling change if you raised the
thrust line two feet and moved the gear back a foot and one half?
As far as not taxiing or flying the FireFly in twenty mph winds, some times
we do not have much choice. Conditions change when you are out and about.
Jack B. Hart FF004
Winchester, IN
Thom Riddle
..BTW, if someone is good at engineering, I have an interesting CG
question I
Ed in JXN (MI)
MkII/503
Ed,
Post the CG problem. I'm sure you'll get lots of feedback.
Thom in Buffalo
retired engineer, but can still do simple math, sometimes correctly
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
dcreech(at)hotmail.com
PostPosted: Mon Jul 31, 2006 10:18 am    Post subject: Control positioning during ground handling Reply with quote
QUOTE: "But with a Kolb FireFly you can not load the tail up or down with
prop wash."
Interesting. When I was learning to fly my Firestar II (similar layout,
right?) I was taught that I should have the stick all the way back when I
open the throttle for takeoff, to avoid a possible nose-over. Obviously the
idea is to generate some compensatory down force on the tail. Do you think
that's all irrelevant, then? I'm not sure I want to try it with the stick
forward just to see what happens. Why don't you do that, and report back
how it goes? Smile
Lee
Reply-To: kolb-list(at)matronics.com
Subject: Re: Re: Control positioning during ground handling
Date: Mon, Jul 26 8:28:58 -5
Kolbers,
the
high
like a Mini-Max.
Not picking on a J- Cub but only using it as an example and moving it
Jack B. Hart FF4
Winchester, IN
Don’t just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm266ave/direct//
Ralph Hoover
PostPosted: Mon Jul 31, 2006 11:05 am    Post subject: Re: Control positioning during ground handling Reply with quote
"I'm not sure I want to try it with the stick forward just to see what happens. Why don't you do that, and report back how it goes? "
Well I can tell ya from A firestar standpoint! Full throtle in any stick position from standstill will "MOON" the world! I don't care if anyone believes me or not. I am living proof. And if you full backstick with even 5 MPH winds from a stand still from the front, it will moon the world. The slightest rut in a grass field at start-off and she would be happer to BOW DOWN to God than lift off . Although she will move forward with great speed!
Stick back head into wind, crank speed, full throtle, stick neutral and boom, your up . Of course, after trying and proving every "dumb" move avaliable, I'm only 4 hours of landing and takeoff, very little air time between. I certanly could be wrong, and therefore be corrected by the old salts here.
Stick in the gut Ralph of Ohio
PostPosted: Mon Jul 31, 2006 1:11 pm    Post subject: Control positioning during ground handling Reply with quote
Ralph:
I think you are right.
It has been my privilege to fly, a good bit, all models of the Kolb
line except the original Twinstar and MKII Twinstar. They all fly,
very basically, the same way. I can assure you that prop blast also
hits the horizontal stabilizers, elevators, and rudder of every model,
including the two I have never flown.
A little common sense, a good control touch, a lot of time in the
airplane you are flying to become very, very accustomed to how it will
behave in most situations, learned by experimenting with taxi and
flight, and you will become one with the aircraft. Taking time to
think about everything you will need to do when the time to do it
arises, is probably gonna be too late.
Jack B's FF may handle a little different than others. He has, from
what he has shared on the Kolb List and his web page, changed control
surface rigging somewhat from the norm. Each airplane will have its
own little character that each pilot must learn intimately to become a
good pilot of that aircraft.
Go fly, have fun, and learn,
PS: It pays off to be smooth in throttle application of any aircraft
and any power plant. Smoothness if the mark of a good pilot.
kfackler(at)ameritech.net
PostPosted: Mon Jul 31, 2006 1:19 pm    Post subject: Control positioning during ground handling Reply with quote
Brother John,
I have a Mark II that is yours to fly should you ever find yourself back up
in this part of the country.
P.S. It handles conventionally.
-Ken Fackler
Kolb Mark II / A722KWF
Rochester MI
jhankin(at)planters.net
PostPosted: Mon Jul 31, 2006 1:27 pm    Post subject: Control positioning during ground handling Reply with quote
prop wash."
I guess my Firefly is different from others. Once I tied the tail down by
the boom at the rear to a hanger door post to run up the engine, and by
increasing and decreasing the throttle I was able to float the rear of the
Firefly off the ground.
Jimmy Hankinson
912-863-7384
Firefly 035
JYL (Sylvania)
Pegasus Field (Home)
2000 Feet X 100 Feet- Grass
Rocky Ford, Georgia
Try SPAMfighter for free now!
PostPosted: Mon Jul 31, 2006 2:50 pm    Post subject: Control positioning during ground handling Reply with quote
I am not a high time Kolb Flyer, I'm up to about 40 hours, but 30 of that has been doing takeoffs and landings. I now always start my takeoff roll with the stick full forward. I roll the throttle in smoothly, the tail comes up when it is ready and all I have to do is a nice smooth pull back to lift off. I, too was warned about nose over with the adminition, "don't shove the throttle forward too fast, it has enough power to send you ass over tea kettle." Keep in mind that I'm out here on the great grass desert and the wind blows almost constantly, but I haven't seen a lot of difference when the wind is down around 5 mph.
Works like a charm for me, your results may differ.
On 7/31/06, LEE CREECH <dcreech3(at)hotmail.com (dcreech3(at)hotmail.com)> wrote: [quote]--> Kolb-List message posted by: "LEE CREECH" < dcreech3(at)hotmail.com (dcreech3(at)hotmail.com)>
prop wash."
how it goes? Smile
Lee
From: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net) >
Reply-To: kolb-list(at)matronics.com (kolb-list(at)matronics.com)
Date: Mon, 31 Jul 2006 08:28:58 -0500
--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
Kolbers,
the
high
like a Mini-Max.
Jack B. Hart FF004
Winchester, IN
Don't just search. Find. Check out the new MSN Search!
PostPosted: Tue Aug 01, 2006 10:50 am    Post subject: Control positioning during ground handling Reply with quote
John & Kolbers,
If this is so, then why there so little pitch control after you open the
throttle for takeoff? Why did Homer put that little hoop under the nose? Why do some
even move their landing gear forward? If this was true, I should be able to
hold the stick back against the stop and be able to advance the throttle
aggressively and not put the FireFly on it's nose.
Jack B. Hart FF004
Winchester, IN
PostPosted: Tue Aug 01, 2006 12:19 pm    Post subject: Control positioning during ground handling Reply with quote
throttle
| Jack B. Hart FF004
Jack B:
This subject is getting beaten to death.
Aggressive throttle control doesn't have any place in aircraft, rotary
or fixed, real ones or UL's.
Pilot technique has a lot to do with how well a Kolb behaves.
Undoubtedly, you have your way of flying and I have mine. I'm not
telling anyone how to fly their airplane. If that is the impression I
gave in previous posts, I was wrong. I like to share how I do it, if
it works well. If it doesn't, I like to share that too, hopefully
someone will learn from it. If not, no sweat.
Ralph Hoover
PostPosted: Tue Aug 01, 2006 12:41 pm    Post subject: Re: Control positioning during ground handling Reply with quote
John, and others;
I am amazed, truly amazed that there can be two different extremes that provide the same response from the plane. And as you stated in a previous post, John, "They all fly, very basically, the same way. I can assure you that prop blast also hits the horizontal stabilizers, elevators, and rudder of every model, including the two I have never flown."
All pushers, all Kolbs, all tail draggers and with the little difference of side by side, front-back, single, as well as engine size and prop size, they all have the same dynamics of existing physical laws to follow.
Forward stick, all the way, back stick, all the way....absolutely amazes me that both can possibly work. This single piece of discussion exceeds any piece of work that I have read (and I have read each and every one from the beginning). How can that be possible?
The ONLY way that both methods can co-exist is if :
1). Everyone is talking about something completely different but the same in all outward appearances, like downwind taxiing verses lifting off (going into the wind). Now when I taxi down to position myself for turning around and taking off, and there IS wind, I still am full back stick. AMAZING!
2). Controls are backward, you know “lefty-loosie,righty-tighty, or mirror image as in being levitated and looking back at yourself from without rather than within. AMAZING!
Did I say AMAZING here in Ohio Ralph?
Page 2 of 3
