rparigoris
Posted: Mon Oct 16, 2023 3:42 pm Post subject: Bringing flat AGM back from the dead |
Hi Group
Figured would mention how we brought back four 12 volt 100 amp AGM batteries from the dead. They are being used on a Solar System. About 6 months old. Anyway the charge controller decided to fail and stopped all charging and put a load on batteries. They were flat for about 3 weeks: two reading 5.2 volts and the other two were at 5.5 volts.
I have a 4 station 750mA Battery Tender.
The two 5.2 volters wouldn't take a charge, used a 2 amp charger for about 4 hours, then put on the Battery Tender. The two 5.5 volters started taking a charge right away. Note: For the first day they were only taking 150mA to begin with, then after 6 hours went up to 350mA.
After a week all peaked and were floating.
Then put a 10 amp load for 2 hours and charged with a 10 amp charger for 2 hours and put on the Battery Tender till Float.
Then put a 10 amp load for 4 hours, then a 10 amp charger for 4 hours and put the Battery Tender till float.
Just checked with a load tester and they seem OK. Put on Battery Tender and they are all floating now.
Looks like the Scrap Yard won't get these 4 examples, but they will be getting their hands on the charge controller.
Ron
skywagon185(at)gmail.com Guest
Posted: Mon Oct 16, 2023 7:28 pm Post subject: Bringing flat AGM back from the dead |
Ron,Good report and results...
It would be interesting if they still have their full AH rating after reviving from the dead.
Battery Tenders... I use a lot of them.
One nasty problem: If the wall power fails, i.e. GFI trips and you don't reset it, the BT's will take the battery back down to the dead zone as they usually don't have a blocking diode as part of the charging output.
Dave
On Mon, Oct 16, 2023 at 4:42 PM rparigoris <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
Hi Group
Ron
http://forums.matronics.com/viewtopic.php?p=511609#511609
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
="noreferrer" target="_blank">https://matronics.com/contribution
Posted: Tue Oct 17, 2023 9:21 am Post subject: Bringing flat AGM back from the dead |
Quote: | On Mon, Oct 16, 2023 at 4:42 PM rparigoris <rparigor(at)hotmail.com (rparigor(at)hotmail.com)> wrote: --> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com (rparigor(at)hotmail.com)>
Hi Group Figured would mention how we brought back four 12 volt 100 amp AGM batteries from the dead. They are being used on a Solar System. About 6 months old. Anyway the charge controller decided to fail and stopped all charging and put a load on batteries. They were flat for about 3 weeks: two reading 5.2 volts and the other two were at 5.5 volts. I have a 4 station 750mA Battery Tender. |
<snip>
Quote: | Put on Battery Tender and they are all floating now. Looks like the Scrap Yard won't get these 4 examples, but they will be getting their hands on the charge controller. Ron |
Dead battery recovery is not impossible . . . see: Section 5.6, page 23
of this document.
http://aeroelectric.com/Mfgr_Data/Batteries/Concorde/Chairman_Technical_Manual.pdf
The operative phrase in this excerpt is "Batteries in this
condition may SOMETIMES be recovered".
Indeed, I've read military qualification requirements for
Concorde products where a battery is deliberately discharge
to the degree that shorting jumpers are placed across cells
for a period of time whereupon a recovery process is
exercised; the battery MUST recover to some acceptable
metric.
I suspect there can be large differences in the ability
of various battery products to pass this test . . .
particularly in the relatively short time frame
in a laboratory environment.
Have you conducted cap checks on your recovered
batteries?
� (o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
of the-best-we-know-how-to-do based
on physics and good practice.
rparigoris
Posted: Tue Oct 17, 2023 5:02 pm Post subject: Re: Bringing flat AGM back from the dead |
Hi Bob
The Batteries are 110 amp AGM 12 volt. We load tested them for 10 seconds at 300 amps. All 4 were about the same, after 10 seconds voltage was 9.6 to 9.8 volts. We were about 55F temperature.
I didn't load or capacity test these batteries when new.
At 55f we ran each battery with a 8.95 amp load for 3.33 hours (approx. 30 aHs). Each battery ended with approx. 12.0 volts. Ranged between .4 volts of each other. On a generic graph I have, it shows a lead acid battery with a c/10 load at 50% capacity at 12.0 volts. That's the only capacity testing we did. In service they need to run at 5 amps for 2 hours most of the time.
Do you have any other recommendations on capacity test try?
Ron P.
Posted: Tue Oct 17, 2023 7:03 pm Post subject: Bringing flat AGM back from the dead |
At 08:02 PM 10/17/2023, you wrote:
Quote: | --> AeroElectric-List message posted by: "rparigoris" <rparigor(at)hotmail.com>
Hi Bob
seconds voltage was 9.6 to 9.8 volts. |
That seems a bit 'soggy' for 110 ah batteries. The
'cranking test' that was standard at B&C for years
was to apply a load that produces a terminal voltage
of 9V and hold it for 15 seconds. Read the 9v current
at the 15 second mark. New, 18AH SVLA batteries would
routinely produce 500+ amps over that interval.
Just for grins, I've got a group 65 battery in
the shop with a 1200W inverter bonded to the side.
Handy for portable power in the field.
It's got a August 2019 manufacturing date
sticker. The sticker cranking value is 850A.
I just did a 9V/15S load test on it and got
a value of 620 Amps. It had not been topped
off in some time so I left it in the care of a
YONHAN charger.
I'll do a WestMountain Radio CAP check on it
in the morning. The battery weighs about 55
pounds so I would expect it to have a new
capacity on the order of 50AH.
After I suck out and measure all its juices, I'll
recharge with the YONHAN and plot the curve. This is
going to take a few days so I'll have to report
back.
(I'm in process of setting up a vacuum pump
drive pad test stand with an 8-30A electrical
system mockup. It will feature an electronic
load bank capable of much larger loads than
my WMR battery tester . . . so I'll be able
to evaluate big batteries in less time. I
dug out a data acquisition system I last used
on a project at Beech. It's an 8-channel, 12-
bit system capable of 1000 samples/second. The
quality of my data plots should take a quantum
jump!)
(o o)
