user9253
Joined: 28 Mar 2008 Posts: 1919 Location: Riley TWP Michigan
Posted: Mon May 20, 2024 2:47 pm Post subject: Z-Zero, A Simple Basic Electrical System |
Bob N., how about publishing the simplest electrical system possible?
Over the years, builders have requested extra features like an E-Bus, dual
alternators, dual batteries, brownout protection and etc. And you have
accommodated with architecture that meets those goals.
But what about the little guy who wants something simple and safe without
all of the bells and whistles? He only wants to fly Day VFR. He doesn't
believe the old wives' tale about needing to shut off avionics during engine
start. His engine is not electrically dependent. He doesn't need a battery
bus or avionics bus. A single battery provides a backup for the single
alternator. The main power bus is as reliable as prop bolts. He won't need a
battery bus because there is no clock or baggage compartment light. His
modern EFIS shows the exact time from GPS. The EFIS also has a HOBBS
meter. His baggage compartment light was purchased at Walmart for $10.
It turns on via sensing motion and its LEDs are powered by AAA batteries.
He won't have to worry about leaving the light on and draining the aircraft battery.
The EFIS has its own internal backup battery. Over voltage and under voltage
warning lights won't be needed because the EFIS has those features too.
Fuses will be used to keep it simple and to save money. He will use one
circuit breaker for over voltage protection.
_________________ Joe Gores |
Posted: Tue May 21, 2024 8:15 am Post subject: Z-Zero, A Simple Basic Electrical System |
Joe,
I have pretty close to this ....based on the z16. I have a rotax powered europa with dynon skyview (with backup battery) with a mechanical and electric fuel pump. Everything is powered off a main bus with fuses. My trim runs off the battery with a circuit breaker.
I have ovp through a bandc voltage regulator. You reset this by shutting off the generator.
Its about as simple as it gets i think.
And i have a 30a fuze to protect the main bus at your recommendation.
im a very satisfied customer.
And i keep everything on when i start the engine.
I dont have a baggage bay light but my landing light came from amazon.
Will
On Mon, May 20, 2024, 19:07 user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
alternators, dual batteries. brownout protection and etc. And you have
voltage warning lights won't be needed because the EFIS has those features
too. Fuses will be used to keep it simple and to save money. He will use one
Joe Gores
http://forums.matronics.com/viewtopic.php?p=513594#513594
Electric-List" rel="noreferrer noreferrer noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
eferrer noreferrer noreferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer noreferrer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
="noreferrer noreferrer noreferrer noreferrer" target="_blank">https://matronics.com/contribution
William Daniell
+1 786 878 0246
kenryan
Posted: Tue May 21, 2024 10:33 am Post subject: Z-Zero, A Simple Basic Electrical System |
Joe,
I think that is a great idea. I would like to see that, followed by an evolution toward more complex electrical systems. Start with the most basic. Then add a component/feature and explain how it compares to the most basic -- advantages, disadvantages. And then further up the complexity tree, with each system being compared to the previous. An approach like that would be very helpful to those of us who don't have the broad general knowledge that so many on this list do have.
Ken Ryan
On Tue, May 21, 2024 at 8:21 AM William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
Will
Joe Gores
FORUMS -
WIKI -
b Site -
William Daniell
+1 786 878 0246
user9253
Posted: Wed May 22, 2024 10:24 am Post subject: Re: Z-Zero, A Simple Basic Electrical System |
The part of Z-101B in black print comes pretty close to Z-Zero if the battery bus
were eliminated. But the electrically challenged novice builder would be
overwhelmed by all of colored options. It would be nice to have architecture
devoted to the simplest possible electrical system while being safe, reliable, and
easy to understand.
Posted: Fri May 24, 2024 4:55 am Post subject: Z-Zero, A Simple Basic Electrical System |
At 05:47 PM 5/20/2024, you wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
Bob N., how about publishing the simplest electrical system possible? |
Is that not what Z-01 does?
Quote: | Over the years, builders have requested extra features like an E-Bus, dual
accommodated with architecture that meets those goals. |
Actually, builders 'requested' none of those features.
They were included in various versions of the
Z-figures as a result of conversations with builders
on the 'net and at OSH.
I'm not sure that I was clear on the design goals
for Z-101. Inclusion of every architectural feature
depicted, it's my suggestion that one would
address the all contingencies need for electrical
energy in a single engine light aircraft.
Now, depending on the goals and anticipated mission
for the project, features can be DELETED as
superfluous. Remove all ancillary features from
Z-101 and you have Z-01.
To be sure, an expansive NOTES section needs
to accompany the Z-101 graphics . . .
I have never published a 'filled out' architecture
drawing because as you've noted in your missive,
there are an infinite number of combinations for
builder's choices. The goal of AEC architecture
drawings is to craft a FAILURE TOLERANT architecture
wherein no critical accessory is likely to go
begging for 'juice'.
I've produced custom wirebooks for clients over
the years . . . those are consulting jobs
billed at my exorbitant rates. But the Z-figures
are intended to provide FOUNDATION for
builder's to craft their own wirebook. The
granular details of that task are best managed
here on the List in discussions and deliberations
by the learned membership.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
In the interest of creative evolution
for the-best-we-know-how-to-do based
on physics and repeatable experiment.
