Speedy11(at)aol.com Guest
Posted: Wed Aug 02, 2006 4:06 pm Post subject: CB Power Source |
I am using circuit breakers in my electrical system.
I had planned to use copper bars to provide power to the "line" side of the CBs.
However, it seems that would make maintenance more difficult if I needed to remove only one CB.
SO, what do you think about using jumper wires from CB to CB to provide power to the CBs? Maybe use #12 AWG to carry the load.
Has anyone done that? Any issues?
Stan Sutterfield
FLYaDIVE(at)aol.com Guest
Posted: Wed Aug 02, 2006 6:51 pm Post subject: CB Power Source |
In a message dated 8/2/06 8:09:51 PM Eastern Daylight Time, Speedy11(at)aol.com
writes:
| Quote: | I am using circuit breakers in my electrical system.
the
| Quote: | CBs.
to
| Quote: | remove only one CB.
power
Stan Sutterfield
Stan:
There is nothing wrong with that, the procedure works very well.
A little trick is to use one continuous length of wire, no cuts, no splices.
Leave enough bare wire between each CB to form a nice loop and so that you
can fold it back on itself and insert it into a ring lug. Low resistance, solid
mechanical connection, looks good and as you said, easy to maintain.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
nuckollsr(at)cox.net Guest
Posted: Wed Aug 02, 2006 7:22 pm Post subject: CB Power Source |
the CBs.
Suggest brass strip available from hobby shops. MUCH easier
to work with than copper.
| Quote: | However, it seems that would make maintenance more difficult if I needed
Yup . . .
Yup . . . the definition of a "bus" is a conductor with multiple
taps for power distribution that are totally independent of each
other. Loss of one tap has no effect on the remainder of the system.
See:
http://www.aeroelectric.com/Pictures/Breakers/Bus_Bar_Not_1.jpg
http://www.aeroelectric.com/Pictures/Breakers/Bus_Bar_Not_3.jpg
http://www.aeroelectric.com/Pictures/Breakers/Bus_Bar_Not_2.jpg
Here's an example of a non-bussed assembly taken from an
old Piper. Note the 3-piece "bus bar" . . . if a screw
loosens at one of these joints, you loose not only the
breaker fed with the loose screw but every thing downstream
as well.
A "real" bus is a contiguous conductor with holes for each
tap that feeds and affects one and only one breaker.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
Posted: Thu Aug 03, 2006 7:21 am Post subject: CB Power Source |
My appreciation to Bob and Chop'd Liver0for their advice regarding powering circuit breakers.
Stan Sutterfield
Posted: Thu Aug 03, 2006 6:48 pm Post subject: CB Power Source |
At 10:46 PM 8/2/2006 -0400, you wrote:
writes:
the
> CBs.
to
> remove only one CB.
> power
> Stan Sutterfield
Stan:
solid
Generally the cross section of a "bus" conductor is sized for
the alternator capacity of the airplane. If you use wire as suggested,
then the terminals to accept the doubled-over wires get pretty hoggy.
The terminals and service loops hang way outside the mounting footprint
of the breakers.
99.9% plus of all breakers installed on all airplanes go the lifetime
of the airplane never being called upon to "trip" nor do they require
a maintenance action. Solid bus bars as described earlier have been
used on tens of thousands of aircraft. I guarantee you that ten years
from now "breaker replacement" will be WAaaaayyyy down on the list
of service expenses for your airplane.
Posted: Sun Aug 06, 2006 11:15 pm Post subject: CB Power Source |
Good point, Bob. Thanks. I'll use the bus bars.
Stan Sutterfield
| Quote: | 99.9% plus of all breakers installed on all airplanes go the lifetime
of service expenses for your airplane. |
