rvbuilder(at)sausen.net Guest
Posted: Fri Aug 11, 2006 5:37 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
I don't think they are saying leave them loose. What they are saying is
you don't want to crank down taper bearings as you will destroy them at
a much greater rate than normal and cause even more of the slop you are
seeing. What I think they are missing is that this is a design problem
because the small surface area of the SS bushing is in direct contact
with the aluminum fork. No matter what you do to make sure the axle
stays SNUG, this WILL eventually ware into the fork without something
else to increase the surface area against the fork. This could be a cap
or simply a steel washer.
In my opinion you have the right idea Tim, machine down the axle
whatever the thickness of the washers are and put them in with it.
Michael Sausen
RV-10 #352 Buildus Interuptus due to moving
Tim(at)MyRV10.com Guest
Posted: Fri Aug 11, 2006 6:12 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
I just had this exchange off-list that might be nice for
the list. Michael wasn't thinking of how the bearings
are torqued down, and now he realizes that it's by the
spacer length. So I'll post my off-list talk here just
for the list's benefit. (I'm really sorry this is getting
so long, but I think we're all eventually going to learn
and benefit from this discussion).
Ok, I'll leave you with this thought then....
The forks by design will lay right on the axle, a fixed distance. The
spacers also lay directly against the fork.
With this design, as you tighten it, the outer faces of both the axle
and the spacers will be flush, and flat against the fork. Therefore
there isn't really any bearing force adjustment possible, because it is
controlled ONLY by the length of the spacers...and it will be perfect
only if the spacers are the perfect length....and it will stay perfect
only if there is no wear. If one were to only snug the
axle bolt slightly, the center axle itself in theory could be less tight
and not flush with the forks,while the spacers ARE. That would make a
whole additional problem in that the axle itself could be the part that
easily turns.
There's one thing that sure would make this a much slicker design....to
have the axle made so the center axle can't turn, and then to have a way
to keep the bearings from rotating on the axle...so they only rotate in
the hub. If that could be done (i.e.
a press-fit, or splined attachment, or something like that) then the
spacers would never spin, and all of this would be a complete non-issue.
This is where Van's really should step in and clarify the torque,
because IMHO, if you're going to just snug that bolt down, you're just
LOOKING for problems.
The design itself is not great....but certain assembly things could
really make it bad.
Think about it a minute, and if you see what I'm saying, maybe I should
move this post to the list. If you think I'm nuts though, then we
should investigate this further.
RV Builder (Michael Sausen) wrote:
Michael Sausen
speckter(at)comcast.net Guest
Posted: Fri Aug 11, 2006 6:27 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
Glastar has this same issue. The difference is that they use a Cleveland wheel that has seals like the main axels. They use an aluminum spacer between the fork and the bearing (slipped over the axel) and then a small roll pin in the fork that seats into a small slot on the spacer to stop rotation.
With the radius on the bearing that we have the only solution is to have a spacer that has the same radius and a large surface area.
Another thing to try is to have a spacer inside the wheel on the axel so that when you clamp up the whole assembly the inner race of both bearings are clamped between the spacers and thus you can clamp the bearing race tight without preloading the bearing excessively.
All in all not a great design from Van.
Gary
40274
[quote]-------------- Original message --------------
[quote] --> RV10-List message posted by: Tim Olson
Wayne, for what it's worth, I really don't think this will work
that way on the RV-10. I may be wrong, but I think you really need
to tighten that thing well on this plane or you'll REALLY have problems.
I'm betting that the assembly those guys are familiar with isn't the
same thing as what we have. If you have any looseness, you're going
to really screw up your axle. I just updated that page....scroll
to the bottom to read tonights update. I got a little long winded again
(surprise surprise), but I explained the axle and rotation and other
things in a bit of depth. For you -10 builders, that page is really
worth understanding, ju st so you can ponder it and know what's going
on there....even if you come to some other conclusion. (if you do,
let me know...I'd love to hear it, or hear exactly what the mechanics
are that George thinks would be better if it were looser)
I'll post the text of tonights update here again, but you would be
much better served to just read it on the page, and see the latest
photos. This is just for the archive's sake.
Here's the link again.
http://www.myrv10.com/N104CD/maintenance/20060809/index.html
Today I stopped by a machine shop and had them take off about .115" off
my axle, to accomodate 2 AN970-6 washers on the outer edge. Yes, they
are .063 each, so .126" would have been the standard, but I wanted the
axle to be even just a little more snug than before, because any flexing
inward will bring that valve cap closer to the fo rk. As a side note,
this from John D. today...a note someone sent him:
"returned the nosewheel to Matco to have it replaced with WHLNW511.25
which is correct for the valve stem on the tube and avoids the clearance
problem with the supplies WHLNW501.25."
In other words, Van's is sending out the wrong wheel for the application
on this plane...because they use this wheel for the RV-7's and such, and
didn't want to have to stock 2 parts. So we get to receive the one that
isn't made for the application, and therefore unless you swap wheels,
you're going to have minimal valve stem clearance.....pretty nice, huh?
Anyway, I had the axle cut shorter at a machine shop, and then I just
had to guesstimate how much to take off the 2 spacers. Knowing they had
worn into a taper on the inside, to fit against the bearing, I had them
only cut d own by .085" total. I did .035" on one side, and .050" on the
other. That way I could have a slightly longer sleeve on the left side,
so my valve stem had just that little extra clearance from the fork.
This brought forth a small problem... Tonight when I assembled it as in
the first photo below, it looked great. VERY much better than original.
Then, when I put the whole wheel together, I found that the spacers
had worn probably at least .120" because there was tons of slop in the
spacers yet, even though they now had a nice flat surface to sit
between, and had been cut less than the axle, and the washers were in
there to fill in some space. The spacers just spun. So, I decided
since I already ordered another axle, I'd take my bandsaw and VERY
carefully trim off some more axle, and just use one more washer on the
left side. That should keep that valve stem even FURTHER away. If I < BR>> was right, I could get it so there would be plenty of pressure on the
bearings and spacers to hold them in place so they don't spin. Sure
enough, it worked just great. I could now torque that bolt down tight
and keep the spacers from spinning, and the bearing too. Just to be
totally sure they never spun again, I drilled a couple of holes in the
stainless spacers, and remounted it all. Then I made a pilot hole in
the aluminum axle shaft, and took it all apart and tapped it for an 8-32
screw on each spacer. Then I cleaned it up, regreased, and put it all
together. Now it is very solid, and should never wear the fork
again....I just am left with a crappy fork...so I'll probably just get a
new one. Once my new spacers and axle come in, I may tear it all apart
and use those pieces, but I'll still probably cut the axle and spacers
down and use the washers on the outer ends. It will prevent your forks
from being the sacrificial component. The bearing, for future
reference, is a Timken LM-6700-LA (I think that's right, but I'll
re-check tomorrow)
A note about tightening the axle nut... Tonight on the RV-10 list,
someone said that George Orndorff (A Van's tech center place), says that
the bolt should only be snugged, and then rechecked often in the first
few hours. I don't personally believe this is true on the RV-10, but
perhaps it is on the other models. Here's why. I studied this long
and hard, and now I fully understand why this is such a huge freaking
issue. It didn't make sense at first, having worked on dozens and
dozens of automotive bearings in the past. You see, on automotive apps,
the bearings are pressed in on the backside, and a nut and washer holds
the bearing tight. But it pushes against a different area of t he > bearing. And the grease seal is usually a seal that is pressed into the
hub, with a seal around the shaft on the ID of the seal. This is NOT
how these bearings are on this application. On THIS application, you
are expecting that the sleeves, the axle, the bolt, AND the inner race
area of the bearing do not ever rotate. The problem is, if these
bearings were a tight knurled, or press fit onto that axle shaft, it
might be easy to keep them from rotating by just not letting the shaft
spin. But, what happens here is that the grease seal is a large seal
that the wheel spins around....so the seal is on the OD of the bearing
in this case. That's why my stinking seals were so torn when the wheel
wobbled. The kicker to the problem is, if you don't have the spacers
very tight against the bearing, there's not enough force to keep the
bearing from turning on the shaft. If the beari ng spins on the axle
shaft, then it's becoming USELESS as a bearing. At that point, you're
using the aluminum axle as the bushing, and the wheel is rolling by
spinning the hard steel bearing race against your soft aluminum axle
shaft.....instead of turning the roller bearings inside of the wheel's
outer race. The seal itself has a lot of drag against the wheel as it
spins, and this drag will make it so that the wheel tries REALLY hard to
make the bearing spin. As it turns out, if you don't have tight
spacers, it's really easy to get that bearing spinning. And once the
bearing is spinning, the spacers stuffed right up against it will spin
too. And once they start spinning, they'll spin against the fork. If
you have the stainless ones like me, they'll ABSOLUTELY then start
carving into your forks. If you have the new and improved thick
aluminum ones (that I can't comme nt firmly on because I haven't seen
them), then they would have more surface area against both the bearing
and the fork....so on one hand the bearing will try to turn it harder,
but the fork will prevent it harder as well. To me, this is STILL
going to be a less than ideal situation until you PREVENT the spacers
from turning, and you PROTECT the forks from being worn if they do turn.
The lock screws I put in should keep the spacers still. The washers
will protect the forks. The one further improvement that would be
simple would be to drill a tiny hole in the fork on one side, that
drills into the aluminum axle, and then tap for a small hex head
internal setscrew lock, so that you could pin the axle from rotating at
all too. Beyond that, the only real improvement I could think of is if
you could find a way to either press-fit, or hold that inner bearing
from tur ning o n the axle. Perhaps knurling it, epoxy, a small keyway
and shear key, or something like that would be the ticket. If you've
done all of the other steps, and have tight spacers, you probably
wouldn't have any huge issues from that point.
The worst thing about it is that no matter what you do, you really don't
have independent control over how tight the bearings are
seated...separate from how tight the axle bolts are and how long the
spacers are. Just to let you know how this all ends up the way I have
it tonight, the wheel will not continue rolling if you spin it by hand.
I don't think it's too tight from a bearing perspective, but the
grease seals against the wheel hub provide a lot of drag, so they don't
let the wheel spin real freely.
A couple other tips, while I'm at it. By the time you get to 25 hours
on your plane, re-check that large nut that holds the fork on. Mine
needed to be tightened almost one full flat to the next castle stop, to
retorque it after it took it's set. I think the spec is about 24lbs.
pull of breakout force to rotate the nose at an angle.
The second tip that I can't yet verify is fairing balance. To prevent
shimmy, I've heard that a good idea is to balance your fairing. Since I
had a little lead shot around, and I wanted this all to be perfect now,
tonight I weighed out a little lead and taped it to the nose of the
nosewheel fairing. I got it so that I could hold it where it mounts, in
the centers of those 4 screw areas, and get it to be about neutrally
balanced. Then I just took a little shot away, poured the rest into
the nose of the fairing, and mixed a couple of squirts of epoxy. I
poured the epoxy into the nose over the shot, put down one layer of
cloth, and then a little more epoxy. By tomorrow that stuff won't be
going anywhere, and I already re-checked the balance and it's now much
less tail heavy, so maybe that will improve things too.
Tim Olson - RV-10 N104CD - 107 hours Flying
Wayne Edgerton wrote:
> I'm currently building in Justin, TX in George Orndorff's hangar, he's
> the one that makes the RV building videos and is also a Van's tech
> center, and I was talking to him about this problem, wondering if I
> needed to take some type of action on mine. His response to me on this
> issue was that this was a quite common occurrence on the RV's. He said
> the reason he believes it happens is that when the builder tightens down
> the bolt holding on the bushing and tire that they tighten it down too
> much. He said I should just tighten it down j ust un Downl BR>>
Randy(at)abros.com Guest
Posted: Fri Aug 11, 2006 8:35 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
If the axle spins you have serious problems. You have to have the yoke
tight enough to hold the axle tight. The extra length of the spacers is
only enough so the bearings have a slight preload. The axle must be
locked by the yoke. As Tim has confirmed the axle was not spinning just
the outer spacer. Randy
jjessen
Posted: Fri Aug 11, 2006 9:15 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
There are thousands of production planes with front forks, obviously. What
do these look like relative to the problem? This cannot be a unique issue
that hasn't been solved years, decades ago.
John J
Tailcone
wayne.e(at)grandecom.net Guest
Posted: Sat Aug 12, 2006 3:14 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
Hi Tim,
I talked to Gus at Van's yesterday about this issue0 and since I also have the steel sleeves he will be sending me out the aluminum0 ones. But I did ask him about the tightness issue and he told me I should0 tighten the bolt to about 160 to 190 " lbs and the wheel and if I try and turn0 it by hand it will be a little hard to turn and shouldn't spin0 freely.
Again for what ever that worth
Wayne Edgerton
#40336
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Tue Aug 15, 2006 9:47 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
_________________ Kevin
40494
do not archive |
KiloPapa
Posted: Tue Aug 15, 2006 10:11 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
I have attached a pic from the parts manual of the nose wheel and axle of a
C-182 for reference.
Kevin
40494
tail/empennage
52.85 KB |
606 Time(s) |
40494
do not archive |
Vern(at)teclabsinc.com Guest
Posted: Tue Aug 22, 2006 2:03 pm Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
Hi All,
I've lost the email, but someone asked about ship dates of finishing
kits and if they had the aluminum or stainless spacers (part number
U-1032.) I checked and my kit was packed on 2-6-06 and included the
stainless steel spacers.
Vern (#40324)
bcondrey
Posted: Tue Aug 22, 2006 6:49 pm Post subject: Re: Serious Front Axle Maintenance Issue on the RV-10 |
I just received my new wheel from Matco today and already had the spacers so it was swap time. After reassembly and torque to standard value (160-190 in lbs) I was dismayed to see the spacers turning with the wheel. Only way this can happen is that the axle is slighly longer than the wheel/bearing/spacer assembly. I'm going to call Van's tomorrow to see what they recommend before shaving a bit off the axle or doing another mod like set screws through the fork, etc. Seems like with some preload they wouldn't be able to turn at all...
Posted: Tue Aug 22, 2006 8:46 pm Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
That's getting pretty far along in an absolute and complete
contradiction to the "very few kits shipped with" that someone
was told on the phone. I mean, if you ship kits for a couple
of years, that's just not "very few" anymore.
Vern W. Smith wrote:
Hi All,
Vern (#40324)
Posted: Tue Aug 22, 2006 8:50 pm Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
Yeah, and if there's not enough preload to keep the spacers from
spinning, there's probably not enough preload on the bearings to
keep everything as tight as it should be to prevent slop....and
it'll only get worse over time as things wear in. The axle shaving
thing is scary, but if you're willing to put in the AN970 washers
on the outside, then at least adding washers can make up for some
removed material.
bcondrey wrote:
<bob.condrey(at)baesystems.com>
http://forums.matronics.com/viewtopic.php?p=56548#56548
bcondrey
Posted: Wed Aug 23, 2006 6:43 am Post subject: Re: Serious Front Axle Maintenance Issue on the RV-10 |
I just talked w/Tom at Van's and his suggestion is to check spacing with a feeler gauge and adjust the axle accordingly. He also said that behavior would be possibly be very different with the wheel off the ground than with full weight on it.
I guess I'll be measuring and adjusting the front axle length tonight...
On related note - what's the best way to jack up the plane for nose wheel work? I've been using my engine hoist but assume there's another option for "in the field" work.
Posted: Thu Aug 24, 2006 3:18 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
Hi Bob - I saw this lift type thing the other day that might do the trick.
http://www.rvtraining.com/html/handy_jack.html
Wayne Edgerton #40336
Ray.R.Doerr(at)sprint.com Guest
Posted: Mon Aug 28, 2006 6:56 am Post subject: Serious Front Axle Maintenance Issue on the RV-10 |
I have a ratchet strap around 6 - 50 lbs bags of gravel (300 lbs total) that I connect to the tail tie down.
Thank You
Ray Doerr
CDNI Principal Engineer
Sprint PCS
16020 West 113th Street
Lenexa, KS 66219
Mailstop KSLNXK0101
(913) 859-1414 (Office)
(913) 226-0106 (Pcs)
(913) 859-1234 (Fax)
