rparigor(at)suffolk.lib.n Guest
Posted: Wed Aug 16, 2006 8:26 am Post subject: Favorite cable guide and wire holders? |
What is favorite rudder cable guides material?
Nylaflow or Nylo-Seal? (Nylaflow is thinner wall, slight more flexible)
What is favorite way to adhere to baggage bay ribs? Going through fuse?
What is favorite way of holding wires in aft fuse?
Do supplied sticky back ty-wrap bases really hold up in use?
Is preference to use bases, but stick another way? Redux?
Any other preferences?
Thx.
Ron Parigoris
europa(at)pstewart.f2s.co Guest
Posted: Wed Aug 16, 2006 3:32 pm Post subject: Favorite cable guide and wire holders? |
Ron
I couldn't get tie wrap bases to stick with anything including redux
(Ampreg) Ended up laying up a sandwich of scraps of bid around a
piece of thin tube covered in release wax Pulled the tube out and cut
5mm strips of the sandwich. They bond on well with redux and the
cable tie goes through the hole. Don't know if attached pic will be
stripped on the list but should appear in the owners forum
Paul
G-GIDY
On 16 Aug 2006, at 17:25, <rparigor(at)suffolk.lib.ny.us>
<rparigor(at)suffolk.lib.ny.us> wrote:
flexible)
fuse?
Thx.
Ron Parigoris
37.01 KB |
441 Time(s) |
SPurpura(at)aol.com Guest
Posted: Wed Aug 16, 2006 6:44 pm Post subject: Favorite cable guide and wire holders? |
Try the ones from AS, cant remember the brand name , they were self adhesive/epoxied on and worked pretty good or scuff sand a nylon one and 5 min epoxy works well. [quote][b]
Kevin Klinefelter
Posted: Wed Aug 16, 2006 7:19 pm Post subject: Favorite cable guide and wire holders? |
Nylo-seal is the best fit for the cable.
I attached to baggage bay ribs with adel clamps.Then thru the balance
weight plywood reduxed. Same for thru the sternpost and side of fuse.
sticky back bases did not hold for me, so i sanded and reduxed em.(peel
the sticky foam off first)
Kevin
rparigor(at)suffolk.lib.ny.us wrote:
Thx.
Ron Parigoris
_________________ Europa XS, Mono Wheel N211KA
Intercooled 914, Airmaster Prop |
hurstkr(at)growzone.com.a Guest
Posted: Thu Aug 17, 2006 2:26 am Post subject: Favorite cable guide and wire holders? |
| Quote: | What is favorite way to adhere to baggage bay ribs? Going through fuse?
Ron,
Attached is what I did. The clamps in the baggage bay did not have their
bolts inserted at the time this photo was taken.
Note that I extended the black tubing back underneath the flap drive cross
tube because the cables just touch the tube when the flaps are down. I have
fitted Graham Singleton's tail wheel mod which elevates the cable at the
rear end more than the factory set-up.
Cheers
Kingsley in Oz.
56.66 KB |
431 Time(s) |
65.41 KB |
429 Time(s) |
57.47 KB |
435 Time(s) |
daseitz(at)cfl.rr.com Guest
Posted: Thu Aug 17, 2006 5:55 pm Post subject: Favorite cable guide and wire holders? |
ClickBond are about the best. But not cheap. Metal base with tiewrap or
threaded stud, made to be glued on. They will never come off. Being as we
use hundreds of them a month at work they are easy for me to get. They are
made for aviation. http://www.clickbond.com/ They are sold by Aircraft
Spruce.
Dean Seitz
