		georgewells(at)adelphia.n Guest
				 Posted: Sun Aug 27, 2006 1:18 pm    Post subject: Gas Caps Leakage |
				On both of the past 2 KF's I have had, a 4 and a  5, when the tanks are topped off the caps seep staining the wing with  gas. I have tried new caps but they still seep. Does anyone have a solution  for this ??
  Also what is good to clean the stain? I have tried  all kinds of cleaners.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		mdps_mc(at)swoca.net Guest
				 Posted: Sun Aug 27, 2006 3:48 pm    Post subject: Gas Caps Leakage |
				There was someone that said a mixture of diet mountian dew and I think maybe baking soda. Sounds a bit strange but I never tried it.  This comment was made on this list.
		flier(at)sbcglobal.net Guest
				 Posted: Sun Aug 27, 2006 4:21 pm    Post subject: Gas Caps Leakage |
				Simple Green works the best and will take the stains right off.
		Clem Nichols
  Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
				 Posted: Sun Aug 27, 2006 4:22 pm    Post subject: Gas Caps Leakage |
				George:
  I have had the same problem even with the rubber  Mercedes gaskets.  I found a product called "Mean Green" which takes the  stain off effortlessly and which does not seem to damage the plane's  finish.  I bought it at a regional discount store (Dollar General), so I  have no idea of whether or not it's nationally distributed, nor can I tell you  offhand what the active ingredient is.
  Clem Nichols
  [quote]   ---
		clemwehner(at)sbcglobal.n Guest
				 Posted: Sun Aug 27, 2006 4:24 pm    Post subject: Gas Caps Leakage |
				Over  the years, this subject has come up many times and the best cleaner mentioned  each time has been a little gasoline on a rag.  Clean the stain  with gasoline, then wipe it off and wash the surface with a little water. It  sounds counter-intuitive, but previous list members say it works  well.
  Clem
  Lawton, OK
  KF  IV-912
		pulsair(at)mindspring.com Guest
				 Posted: Sun Aug 27, 2006 4:25 pm    Post subject: Gas Caps Leakage |
				George,
  I have the same problem with my Classic IV. If you  use Simple Green full strength on a cloth and rub like you are spit polishing  shoes takes it off. I think what is happening is we are filling our tanks  too high. I think that the vent on the cap suctions some of it out. What I  did was empty my tanks until they were bone dry including the header. I then put  6 gallons of gas in and put a mark on a measuring stick. I then put in 2 gallon  increments until I had about 14 gallons showing on the stick (Including the  header). That placed the fuel when full about 1 1/2 inches below the filler  neck. I use my measuring stick religiously and a stop watch. I burn 4.5 gallons  at 4800 rpm and about 5.5 gallons at 5200 rpm. When I taxi in to visit someone  without re-fueling I hit the stop watch on the instrument panel. I always know  exactly how much fuel I have by fuel burn and the dip stick. Jeff Classic IV  912UL
  [quote]   ---
		fredshiple(at)sbcglobal.n Guest
				 Posted: Sun Aug 27, 2006 5:13 pm    Post subject: Gas Caps Leakage |
				I used a Mercedes gasket, part# 140-471-00-79 that Lowell Fitt steered me to.Works well. Simple Green works well, also.
 Fred
 [quote]On both of the past 2 KF's I have had, a 4 and a  5, when the tanks are topped off the caps seep staining the wing with  gas. I have tried new
		morid(at)northland.lib.mi Guest
				 Posted: Sun Aug 27, 2006 6:11 pm    Post subject: Gas Caps Leakage |
				Simple Green is great for removing stains, bugs, grease, etc.  However, let
 me warn you.  That stuff is incredibly corrosive.  Spray a little on a
 camlock and watch what happens to it in a couple days.  So if you decide to
 use the stuff, just ensure you keep it away from metal parts, or give them a
 good rinse when you're finished.
 Deke
		valley361(at)centurytel.n Guest
				 Posted: Sun Aug 27, 2006 7:17 pm    Post subject: Gas Caps Leakage |
				George,
             You may  have a vented cap with a Skystar added vent tube. Look at the underside of the  rim. Are there four shallow slots around the edge? If so, use something small to  let epoxy seep into the slots to form a seal. Worked for me.
                                                             Jay  C.
  [quote]   ---
		john(at)leptron.com Guest
				 Posted: Sun Aug 27, 2006 7:42 pm    Post subject: Gas Caps Leakage |
				Hi guys,
 Rotax put a note out on simple green, do not use.... it has caused engines
 to quite when it has corroded the wires in the mag area.
 John Oakley
		cliffh(at)outdrs.net Guest
				 Posted: Mon Aug 28, 2006 6:02 am    Post subject: Gas Caps Leakage |
				I also found that simple green will etch the windshield
 Floran H.
		kerrjohna(at)comcast.net Guest
				 Posted: Mon Aug 28, 2006 7:46 am    Post subject: Gas Caps Leakage |
				I'll try to address the seepage problem, though others may have done so.  The cap as provided is 'layered" with the inside layer have two vents in addition to the pitot vent tube.  These vents access the outside via 4 crips in the circumference ov the inner layer. All six opening need to be sealed with RTV or other medium.  The replacement of the gasket with a Mercedes part and the above sealing have kept my wings stain free for the last 6 years.
  John Kerr
  [quote]-------------- Original message --------------
  Clem
  Lawton, OK
  KF IV-912
				 Posted: Mon Aug 28, 2006 8:48 am    Post subject: Gas Caps Leakage |
				The subject of gas stains keeps coming up every few years on this list.
 In the past, several members have said that fresh gasoline on a rag will
 remove the stains. They've said to wipe it on the stain, then wipe it
 off while it is still wet. Then clean the fabric with water. This sounds
 counter-intuitive, but it supposedly works, though I haven't tried it.
 In a similar situation, someone wrote on our office whiteboard with
 permanent marker instead of a dry erase marker. Nothing would get it off
 except tracing over the marks with a new permanent marker, then wiping
 it off while it was still wet. Worked great. Kinda the same idea with
 our gas stains.
 Clem
 Lawton, OK
 KFIV, 912
		Clem Nichols
				 Posted: Mon Aug 28, 2006 6:16 pm    Post subject: Gas Caps Leakage |
				John:
  What is RTV?  By the way, I've tried using  gasoline on a rag to clean the stain off with no luck.  The Mean Green  which I've used, (and obviously the Simple Green as well) does a great  job.  Just be careful where you spray it, and rinse thoroughly as soon as  the stain is removed.
  Clem Nichols
  [quote]   ---
		eskflyer(at)lvcisp.com Guest
				 Posted: Mon Aug 28, 2006 7:29 pm    Post subject: Gas Caps Leakage |
				I use red thunder to clean my stains . it is a  biodegradable product and does not mar or leave any residue when waiped and  washed off leaves a perfect shine . also friendly to aluminum
  http://www.malcopro.com/cgi-win/mallist.exe/Cleaning
  I have used it on the fuel stains after the stains  sitting for months and it takes them right off.
  look these products up i really think you all will  like them .
  John Perry
  Kitfox 2 { still a tail dragger }
  fly safe fly low fly slow and have FUN
		janderson412(at)hotmail.c Guest
				 Posted: Mon Aug 28, 2006 10:50 pm    Post subject: Gas Caps Leakage |
				Silicon sealer but I wouldn't use it with gas. Proseal would be better IMHO.
 John A.
 Subject: Re: Gas Caps Leakage
 Date: Mon, 28 Aug 2006 21:14:34 -0500
 John:
 Clem Nichols
		Richard Rabbers
  Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
				 Posted: Tue Aug 29, 2006 4:34 am    Post subject: Re: Gas Caps Leakage |
 RTV = Room Temperature Vulcanizing
  _________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
		Fox5flyer Guest
				 Posted: Tue Aug 29, 2006 5:17 am    Post subject: Gas Caps Leakage |
				Also silicone caulking
		dave(at)cfisher.com Guest
		Beemer
  Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
				 Posted: Wed Aug 30, 2006 3:31 am    Post subject: Gas Caps Leakage |
				RTV = Really Tough Vaseline     8-O
 Bradley
  _________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
