georgewells(at)adelphia.n Guest
Posted: Sun Aug 27, 2006 1:18 pm Post subject: Gas Caps Leakage |
On both of the past 2 KF's I have had, a 4 and a 5, when the tanks are topped off the caps seep staining the wing with gas. I have tried new caps but they still seep. Does anyone have a solution for this ??
Also what is good to clean the stain? I have tried all kinds of cleaners.
mdps_mc(at)swoca.net Guest
Posted: Sun Aug 27, 2006 3:48 pm Post subject: Gas Caps Leakage |
There was someone that said a mixture of diet mountian dew and I think maybe baking soda. Sounds a bit strange but I never tried it. This comment was made on this list.
Mike
flier(at)sbcglobal.net Guest
Posted: Sun Aug 27, 2006 4:21 pm Post subject: Gas Caps Leakage |
Simple Green works the best and will take the stains right off.
Clem Nichols
Joined: 10 Jan 2006 Posts: 88 Location: Munfordville, Ky
Posted: Sun Aug 27, 2006 4:22 pm Post subject: Gas Caps Leakage |
George:
I have had the same problem even with the rubber Mercedes gaskets. I found a product called "Mean Green" which takes the stain off effortlessly and which does not seem to damage the plane's finish. I bought it at a regional discount store (Dollar General), so I have no idea of whether or not it's nationally distributed, nor can I tell you offhand what the active ingredient is.
Clem Nichols
clemwehner(at)sbcglobal.n Guest
Posted: Sun Aug 27, 2006 4:24 pm Post subject: Gas Caps Leakage |
Over the years, this subject has come up many times and the best cleaner mentioned each time has been a little gasoline on a rag. Clean the stain with gasoline, then wipe it off and wash the surface with a little water. It sounds counter-intuitive, but previous list members say it works well.
Clem
Lawton, OK
KF IV-912
pulsair(at)mindspring.com Guest
Posted: Sun Aug 27, 2006 4:25 pm Post subject: Gas Caps Leakage |
George,
I have the same problem with my Classic IV. If you use Simple Green full strength on a cloth and rub like you are spit polishing shoes takes it off. I think what is happening is we are filling our tanks too high. I think that the vent on the cap suctions some of it out. What I did was empty my tanks until they were bone dry including the header. I then put 6 gallons of gas in and put a mark on a measuring stick. I then put in 2 gallon increments until I had about 14 gallons showing on the stick (Including the header). That placed the fuel when full about 1 1/2 inches below the filler neck. I use my measuring stick religiously and a stop watch. I burn 4.5 gallons at 4800 rpm and about 5.5 gallons at 5200 rpm. When I taxi in to visit someone without re-fueling I hit the stop watch on the instrument panel. I always know exactly how much fuel I have by fuel burn and the dip stick. Jeff Classic IV 912UL
fredshiple(at)sbcglobal.n Guest
Posted: Sun Aug 27, 2006 5:13 pm Post subject: Gas Caps Leakage |
I used a Mercedes gasket, part# 140-471-00-79 that Lowell Fitt steered me to.Works well. Simple Green works well, also.
Fred
[quote]On both of the past 2 KF's I have had, a 4 and a 5, when the tanks are topped off the caps seep staining the wing with gas. I have tried new
morid(at)northland.lib.mi Guest
Posted: Sun Aug 27, 2006 6:11 pm Post subject: Gas Caps Leakage |
Simple Green is great for removing stains, bugs, grease, etc. However, let
me warn you. That stuff is incredibly corrosive. Spray a little on a
camlock and watch what happens to it in a couple days. So if you decide to
use the stuff, just ensure you keep it away from metal parts, or give them a
good rinse when you're finished.
Deke
valley361(at)centurytel.n Guest
Posted: Sun Aug 27, 2006 7:17 pm Post subject: Gas Caps Leakage |
George,
You may have a vented cap with a Skystar added vent tube. Look at the underside of the rim. Are there four shallow slots around the edge? If so, use something small to let epoxy seep into the slots to form a seal. Worked for me.
Jay C.
john(at)leptron.com Guest
Posted: Sun Aug 27, 2006 7:42 pm Post subject: Gas Caps Leakage |
Hi guys,
Rotax put a note out on simple green, do not use.... it has caused engines
to quite when it has corroded the wires in the mag area.
John Oakley
cliffh(at)outdrs.net Guest
Posted: Mon Aug 28, 2006 6:02 am Post subject: Gas Caps Leakage |
I also found that simple green will etch the windshield
Floran H.
kerrjohna(at)comcast.net Guest
Posted: Mon Aug 28, 2006 7:46 am Post subject: Gas Caps Leakage |
I'll try to address the seepage problem, though others may have done so. The cap as provided is 'layered" with the inside layer have two vents in addition to the pitot vent tube. These vents access the outside via 4 crips in the circumference ov the inner layer. All six opening need to be sealed with RTV or other medium. The replacement of the gasket with a Mercedes part and the above sealing have kept my wings stain free for the last 6 years.
John Kerr
Clem
Lawton, OK
KF IV-912
Posted: Mon Aug 28, 2006 8:48 am Post subject: Gas Caps Leakage |
The subject of gas stains keeps coming up every few years on this list.
In the past, several members have said that fresh gasoline on a rag will
remove the stains. They've said to wipe it on the stain, then wipe it
off while it is still wet. Then clean the fabric with water. This sounds
counter-intuitive, but it supposedly works, though I haven't tried it.
In a similar situation, someone wrote on our office whiteboard with
permanent marker instead of a dry erase marker. Nothing would get it off
except tracing over the marks with a new permanent marker, then wiping
it off while it was still wet. Worked great. Kinda the same idea with
our gas stains.
Clem
Lawton, OK
KFIV, 912
Clem Nichols
Posted: Mon Aug 28, 2006 6:16 pm Post subject: Gas Caps Leakage |
John:
What is RTV? By the way, I've tried using gasoline on a rag to clean the stain off with no luck. The Mean Green which I've used, (and obviously the Simple Green as well) does a great job. Just be careful where you spray it, and rinse thoroughly as soon as the stain is removed.
Clem Nichols
eskflyer(at)lvcisp.com Guest
Posted: Mon Aug 28, 2006 7:29 pm Post subject: Gas Caps Leakage |
I use red thunder to clean my stains . it is a biodegradable product and does not mar or leave any residue when waiped and washed off leaves a perfect shine . also friendly to aluminum
http://www.malcopro.com/cgi-win/mallist.exe/Cleaning
I have used it on the fuel stains after the stains sitting for months and it takes them right off.
look these products up i really think you all will like them .
John Perry
Kitfox 2 { still a tail dragger }
fly safe fly low fly slow and have FUN
janderson412(at)hotmail.c Guest
Posted: Mon Aug 28, 2006 10:50 pm Post subject: Gas Caps Leakage |
Silicon sealer but I wouldn't use it with gas. Proseal would be better IMHO.
John A.
Subject: Re: Gas Caps Leakage
Date: Mon, 28 Aug 2006 21:14:34 -0500
John:
Clem Nichols
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Tue Aug 29, 2006 4:34 am Post subject: Re: Gas Caps Leakage |
RTV = Room Temperature Vulcanizing
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
Fox5flyer Guest
Posted: Tue Aug 29, 2006 5:17 am Post subject: Gas Caps Leakage |
Also silicone caulking
dave(at)cfisher.com Guest
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Wed Aug 30, 2006 3:31 am Post subject: Gas Caps Leakage |
RTV = Really Tough Vaseline 8-O
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
