Posted: Sat Sep 02, 2006 9:08 am Post subject: Propellers - IVO or Warp |
I replaced the tape on my original Warpdrive for cosmetic reasons.
I think I got it from AC Spruce. Plenty thick and durable looking
but the problem is with separation at the leading edge.
If you prebend it with a crease, maybe an iron at low heat, and
weight it down overnight before applying it, the problem may go
away. It's back in the box looking good until I stick it on something,
someday............??
BB, powerfin, some dings and scars, who knows what fell off?
On 2, Sep 2006, at 12:31 PM, N27SB(at)aol.com wrote:
In a message dated 9/2/2006 9:58:01 A.M. Eastern Standard Time,
etzim62(at)earthlink.net writes:
> <etzim62(at)earthlink.net>
> I bought a new Ivo recently from CPS . The leading edge tape was very
> unsatisfactory and I removed it after only a few hrs. I am running
> it without any leading edge protection for the moment. I received
> replacement edges with the prop but they are the same junk as what
> was on originally. It would be a wast of time to install them.
> I have had satisfactory experiences with Ivo props in the past but
> with their current quality control I can no longer recommend them. I
> recommend Powerfin for anything running a B box gear reduction.
Eugene,
The Firefly I bought from Duane came with a 2 blade IVO. The tape
leading edge was holding up OK for the first few hours of Seaplane
use. After I dinged it up with a loose bolt I called IVO for
replacement tape. That was 2 years ago. The replacement tape was much
thinner and failed in about 2 hours. I asked them why they went to a
thinner tape and they said that the original vender no longer had the
thicker tape. After a few hours on the Internet I found a tape
supplier with a thicker tape. They sent me a sample roll. I also found
that they had supplied tape to IVO but IVO no longer bought from them.
I never tried the tape because shortly after that I received the Kiev
prop. I suspect that they are still using the thin stuff. I don't know
how either tape holds up with normal use, but with a lot of water
exposure both fail quickly. If you want to try some of the sample
roll, let me know.
I think IVO makes a good product, It just is not suitable for
Seaplanes.
Steve
Richard Pike
Posted: Sat Sep 02, 2006 9:50 am Post subject: Propellers - IVO or Warp |
So far the best replacement tape I have found for an Ivo or anything
else that uses tape is the tape that Powerfin sells. Sticks like crazy,
no peeling problems at all. I have a whole bunch of the tape that
Aircraft Spruce sells. It would work good on something other than a prop...
Richard Pike
MKIII N420P (420ldPoops)
robert bean wrote:
| Quote: | I replaced the tape on my original Warpdrive for cosmetic reasons.
was very
running
received
what
but
them. I
Eugene,
much thinner and failed in about 2 hours. I asked them why they
went to a thinner tape and they said that the original vender no
longer had the thicker tape. After a few hours on the Internet I
found a tape supplier with a thicker tape. They sent me a sample
roll. I also found that they had supplied tape to IVO but IVO no
longer bought from them. I never tried the tape because shortly
after that I received the Kiev prop. I suspect that they are still
using the thin stuff. I don't know how either tape holds up with
normal use, but with a lot of water exposure both fail quickly. If
you want to try some of the sample roll, let me know.
Seaplanes.
Steve
http://forums.matronics.com
http://wiki.matronics.com
size color="#000000" face="courier new,courier">
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Eugene Zimmerman
Posted: Sat Sep 02, 2006 12:05 pm Post subject: Propellers - IVO or Warp |
Thanks Richard,
I have a 64" Powerfin with the leading edge still as good as new.
My Ivo is a 72" and I believe because it flexes more than the
Powerfin it is harder for the stainless steel tape to stay attached
without buckling and cracking. The thing that makes me unhappy is the
extra leading edges that were supplied with the new Ivo prop were
folded in half for shipping. They would have an obvious distortion
even before and after installation.
Perhaps I'll contact Powerfin and give theirs a try.
On Sep 2, 2006, at 1:49 PM, Richard Pike wrote:
anything else that uses tape is the tape that Powerfin sells.
Sticks like crazy, no peeling problems at all. I have a whole bunch
of the tape that Aircraft Spruce sells. It would work good on
Richard Pike
> something,
> do not archive
> was very unsatisfactory and I removed it after
> running it without any leading edge protection for
> the moment. I
> received replacement edges with the prop but they
> what was on originally. It would be a wast of time
> to install them.
> past
> but with their current quality control I can no
> longer recommend
> them. I recommend Powerfin for anything running a
> Eugene,
> Seaplane
> still
> quickly. If
> Seaplanes.
> Steve
> http://www.matronics.com/Navigator?Kolb-List
> http://www.matronics.com/contribution
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Mon Sep 04, 2006 12:30 am Post subject: Re: Propellers - IVO or Warp |
There's quite a good article on Prop balance, harmonics etc on this weeks AvWeb 'MotorHead' column (#15)
http://www.avweb.com/news/columns/193075-1.html
Just helps one appreciate the factors that make for a smooth engine/prop combination.
David.
HShack(at)aol.com Guest
Posted: Mon Sep 04, 2006 4:16 pm Post subject: Propellers - IVO or Warp |
In a message dated 9/2/2006 12:32:59 PM Eastern Standard Time, N27SB(at)aol.com writes:
| Quote: | | It just is not suitable for Seaplanes. |
But the Kiev seems ideal.......
Howard Shackleford
FS II
SC
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Thu Sep 07, 2006 7:42 pm Post subject: Re: Propellers - IVO or Warp |
I bought 4 sets of Powerfin leading edge tape after reading Rev. Pike's recommendation. My 66" 2 blade Ivo is still on the first set 200hrs later. The tape is pretty thin. I didn't see how it could provide enough protection, but it does a great job.
I often fly off of gravel, sand and crushed granite runways and used to get small dings in the metal tape. The plastic tape takes it in stride and the prop underneath is undamaged so far. If you are having tape problems on your Ivo, put the Powerfin tape on it. Thanks for the tip Mr. Pike.
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
Richard Pike
Posted: Thu Sep 07, 2006 8:02 pm Post subject: Propellers - IVO or Warp |
Thank you for the kind words. Certain aspects of life have been
challenging of late, and it's encouraging to know I did somebody some good.
Richard Pike
R. Hankins wrote:
Roger in Oregon
1992 KXP 503
http://forums.matronics.com/viewtopic.php?p=60304#60304
Kingsport, TN 3TN0
jsflan(at)valornet.com Guest
Posted: Thu Sep 07, 2006 9:09 pm Post subject: Propellers - IVO or Warp |
Richard,
You have done more good that you realized, and your advice is counted on in
these quarters. Hang in there. The site below is a standard reference for
my endeavors and I may even have flaps working tomorrow because of your
efforts and helpful jpgs. The tailwheel is doing okay and your
encouragement and direction have been a help each step on renovating the red
beast.
This is the gospel of Pike referred to often here
Kolb MKIII Tweaks & Hints
jsf
