tomhanaway
Posted: Tue Oct 10, 2006 4:38 am Post subject: pilot vs. final holes and cogsdill |
Empennage ordered but not here yet so don't have instructions. Are most drilled holes two-part. I.e., 1/8" pilot(0.125) then #30(0.1285)final and 3/32pilot(0.0938) then #40(0.0980)final.
The reason I ask is deciding which burraway drill bits to get. Will the #30 and 40 size do? Or is most of the deburring done off the smaller pilot hole, if both pilot and final are necessary?
I'd obviously prefer to buy only two bits if possible rather than four.
Separately, I do follow the ebay sales but other than the .093, most of the sizes are larger than needed for the Van's kit.
Empennage should arrive early next week.
Thanks in advance,
Tom Hanaway
Todd.Stovall(at)pentagon. Guest
Posted: Tue Oct 10, 2006 5:10 am Post subject: pilot vs. final holes and cogsdill |
Tom,
On the RV-10 VS you pre-drill the 1/8 holes on the rear spar with a 1/8 bit
first and then final drill with a #30. For the 3/32 holes, Van's has you go
straight to final drill with a #40, no pre-drilling identified that I have
seen yet.
Todd
#40631
RV-10 Emp
jjessen
Posted: Tue Oct 10, 2006 6:26 am Post subject: pilot vs. final holes and cogsdill |
#30 and #40 Cogsdill are all you need. Make sure you have the standard
deburring tools from an Avery or Cleveland. Many places you'll want those
over the Cogsdill.
John Jessen
#328 (riveting tailcone)
dav1111(at)cox.net Guest
Posted: Tue Oct 10, 2006 6:44 am Post subject: pilot vs. final holes and cogsdill |
In addition to drill bits (buy at least 5 of each) you should also get #30
and #40 reamers. The reamers are my first choice in doing the initial/final
drilling of pre-punched holes. I have never used the burraway drill bits
but didn't find a real problem with deburring after using a reamer.
In addition, instead of "match drilling" pre-punched holes I would advise
first hitting all of the pre-punched holes with either the #30 or #40 reamer
and debur before putting them together the first time. I found on the VS
that it was real difficult to cleco the parts together but after using the
reamers and deburring first all my parts cleco'd together much easier. By
the time I reached the HS I had stopped match drilling anything that was
pre-punched and didn't do it again all the way to the end of my build.
Not only does it save loads of time but I found the holes lined up much
better and I had fewer drilling errors than I was having with match drilling
the pre-punched holes, many of which the tabs would push down with the drill
bit and I couldn't tell that they had been mis-drilled until after I took
them apart for deburr.
I did find on occasion when I was riveting that I had to go back and run the
reamer through the cleco'd holes sometimes to get the rivet to set like I
wanted it to set. Using the reamer at the point in drilling I didn't feel
any significant areas around the holes that caused me any deburring concerns
since the holes had already been reamed, de-burred, countersunk and the
slight trim caused by another run of the reamer didn't seem to be a problem.
Good luck with your project, I had a wonderful time doing my 33 month build
(even had three major surgeries during such 33 months and lost about 8
months of build time).
Russ Daves
N710RV - Flying RV-10
See everyone at LOE 2006 this weekend
Posted: Tue Oct 10, 2006 7:14 am Post subject: pilot vs. final holes and cogsdill |
Tom,
If I were you I would order the drill bits from Cleaveland or Avery, the
entire set of standard fractional bits and the entire set of numbered bits.
The inherent problem is that you will need a bit which you do not have and
then it stops the entire build process until the bit arrives in the mail.
This can happen a lot of times. It gets frustrating. You get the point!
Also, when it comes to drilling out rivets a good set of undersize bits is
wonderful to have to prevent the chance of adverse hole enlargement.
Get used to biting the bullet, the correct tools make all the difference.
John G. 409
| Quote: | From: "tomhanaway" <tomhanaway(at)adelphia.net>
Subject: pilot vs. final holes and cogsdill
Date: Tue, 10 Oct 2006 05:38:40 -0700
Thanks in advance,
Tom Hanaway
http://forums.matronics.com/viewtopic.php?p=66903#66903
Posted: Tue Oct 10, 2006 7:48 am Post subject: pilot vs. final holes and cogsdill |
Russel,
Having almost finished the entire tail assembly, as I am now doing
fiberglass work, with the new experience I have gained, I have no idea of
what you are advocating. I am not trying to be disrespectful, just would
like to understand what it is you are saying.
"In addition, instead of "match drilling" pre-punched holes I would advise
pre-punched and didn't do it again all the way to the end of my build."
"Not only does it save loads of time but I found the holes lined up much
them apart for deburr. In addition, instead of "match drilling" pre-punched
holes I would advise first hitting all of the pre-punched holes with either
the #30 or #40 reamer and debur before putting them together the first time.
I found on the VS that it was real difficult to cleco the parts together
but after using the reamers and deburring first all my parts cleco'd
together much easier. By the time I reached the HS I had stopped match
drilling anything that was pre-punched and didn't do it again all the way to
My thoughts.....The only place I had difficulty getting prepunched holes to
line up was during the assembly of the rudder, as the control horn of the
rudder had a slightly larger bend raduis than it should have. This pushed
the rudder spar away from the skin holes. It all worked out, especially when
you use an ice pick to line up holes before cecoing them. The ice pick is
one of those "Must Have Tools" Use a lot of clecoes during the drilling, the
more the merrier.
JOhn G. 409
[quote]From: "Russell Daves" <dav1111(at)cox.net>
Subject: Re: pilot vs. final holes and cogsdill
Date: Tue, 10 Oct 2006 09:43:28 -0500
initial/final drilling of pre-punched holes. I have never used the
burraway drill bits but didn't find a real problem with deburring after
using a reamer.
reamer and debur before putting them together the first time. I found on
the VS that it was real difficult to cleco the parts together but after
using the reamers and deburring first all my parts cleco'd together much
easier. By the time I reached the HS I had stopped match drilling
anything that was pre-punched and didn't do it again all the way to the end
of my build.
drilling the pre-punched holes, many of which the tabs would push down with
the drill bit and I couldn't tell that they had been mis-drilled until
after I took them apart for deburr.
the reamer through the cleco'd holes sometimes to get the rivet to set like
I wanted it to set. Using the reamer at the point in drilling I didn't
feel any significant areas around the holes that caused me any deburring
concerns since the holes had already been reamed, de-burred, countersunk
and the slight trim caused by another run of the reamer didn't seem to be a
problem.
Russ Daves
tomhanaway
Posted: Tue Oct 10, 2006 9:07 am Post subject: Re: pilot vs. final holes and cogsdill |
Just to clarify. I do have a complete tool kit coming from Cleveland with some optionals coming from Avery, Brown and Planetool.
As to the #30 and #40 debur, Cogsdill doesn't make them. They do have the 1/8 and 3/32" bits
E-z burr has a #40 debur size.
I guess my question should have been clearer. Do the 1/8 and 3/32 deburr sizes work effectively with the slightly larger #30 and #40 holes.
Tom Hanaway
Rick S.
Posted: Tue Oct 10, 2006 9:09 am Post subject: pilot vs. final holes and cogsdill |
John,
In a nutshell this came up about a year ago. What some builders were doing including my friend & fellow builder here in Las Vegas was to predrill (ream), deburr and dimple then final assemble before ever clecoing together an assembly. In theory it sounds good and it seemed to work well for Russ & Bob. I found it much easier to understand the correct way things went together by clecoing, drilling then disassemble deburr...the conventional way most build. It has drawbacks.....the fuselage has several areas that need holes drilled in assembly and if you miss them after you have it partially riveted then you may find yourself drilling out some rivets or trying to complete what was a simple step now almost impossible to do because it is assembled. I always considered the cleco then drill the equivalent of "measuring twice and cutting once" I didn't really find it all that much faster and I know all my holes have been properly deburred and I didn't have any problems by having to go
backwards and disassemble anything.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
jjessen
Posted: Tue Oct 10, 2006 11:22 am Post subject: pilot vs. final holes and cogsdill |
Yes.
John J
Kellym
Posted: Wed Oct 11, 2006 3:52 pm Post subject: pilot vs. final holes and cogsdill |
Do you have a good source for #30 &40 reamers?
Russell Daves wrote:
#30 and #40 reamers. The reamers are my first choice in doing the
advise first hitting all of the pre-punched holes with either the #30
together but after using the reamers and deburring first all my parts
cleco'd together much easier. By the time I reached the HS I had
stopped match drilling anything that was pre-punched and didn't do it
KCHD |
Albert Gardner
Posted: Wed Oct 11, 2006 8:15 pm Post subject: pilot vs. final holes and cogsdill |
Avery for one, probably all the tool outfits have them. I like the reamers
better than the drills because the little to no deburring after using one on
a pilot hole. You will also have some use for the 12" #40 and #30 drill
bits. I bought a 3/16" and 1/4" reamer and use them to finish up those holes
rather than the number bits called for to eliminate as much slop as possible
when fitting parts.
Albert Gardner
Yuma, AZ
40-422 Finish kit
_________________ RV-9A N872RV
RV-10 N991RV |
