Jaybannist(at)cs.com Guest
Posted: Sun Nov 19, 2006 9:49 am Post subject: Fresh Air |
On the 601XL, with the NACA fresh air intakes installed where ZAC shows them, a duct would have to be severely contorted to get to outlets mounted directly on the instrument panel. Mounting the outlets below the panel, next to the sidewall will definitely intrude on my knee space. Yes, with my keen 20-20 hindsight, I know I should have mounted the scoops above where ZAC shows them, but at this point, I can't replace the side skins. Has anyone mounted the outlets directly on the outlet of the plastic intake shroud? It would probably require a mounting plate, fastened to that adjacent vertical angle (the one that is curved at the lower end). Is that feasible? If it is, which outlet model would work best?
Jay in Dallas
Posted: Sun Nov 19, 2006 12:27 pm Post subject: Fresh Air |
| Quote: | From what I have seen it is fairly common to mount the vents right on the
ducts. AMD does this although they appear to build a metal plenum over the
duct. See the attached picture.
I take it things are so tight that you can't reach the panel with a tight
S-bend?
Can you reach the end of the NACA duct to adjust a vent mounted there when
in flight?
Anyway Aircraft Spruce has an adapter (p/n 13-00833) which bolts to the back
of any vent and gives you a 2 inch diameter flange. You should be able to
couple this directly to the 2 inch outlet of the NACA duct. It is the second
item from the top in the left column on this catalog page:
www.aircraftspruce.com/pdf/2007Individual/Cat07190.pdf
The vent just below it (p/n 05-00779) would work nicely with it without
having a corner to catch your leg.
-- Craig
77.19 KB |
451 Time(s) |
Posted: Sun Nov 19, 2006 5:35 pm Post subject: Fresh Air |
Craig, I have ordered the vents from Aircraft Spruce. Didn't order the adapter. When I get the vents, I'll see what it takes to install them directly to the NACA duct.
Thanks for the reply and info. - Jay
"Craig Payne" <craig(at)craigandjean.com> wrote:
| Quote: | >From what I have seen it is fairly common to mount the vents right on the
S-bend?
in flight?
-- Craig
MaxNr(at)aol.com Guest
Posted: Sun Nov 19, 2006 7:19 pm Post subject: Fresh air |
I saw some eyeball vents at www.steinair.com 1.5 in $90.00 and 2.0 in $100.00. They are in the Minneapolis area.
Bob Dingley
Pace,Fl
601XL/Lyc [quote][b]
tonyplane(at)bellsouth.ne Guest
Posted: Mon Nov 20, 2006 7:26 am Post subject: Fresh Air |
I placed the fresh air outlets on my panel using eyeball vents with adapters
(from Aircraft Spruce) to pick up SCAT tubing from the NACA outlets placed
in the dwg location. No problem, except vents use up panel space. See
http://www.zenithair.com/zodiac/6-photo79.html picture
http://www.zenithair.com/zodiac/pic05/493tg3.jpg
The headset jack locations below the panel in the corners directly below the
vents can sometimes be a problem. I relocated the pickups further forward
for a little more room.
Tony Graziano
601XL/Jab3300; N493TG, 173 hrs
| Quote: | Time: 09:49:51 AM PST US
Subject: Fresh Air
them,
directly
the sidewall
hindsight,
outlets
require
is
would
work best?
Jay in Dallas
btucke73(at)yahoo.com Guest
Posted: Mon Nov 20, 2006 8:53 pm Post subject: Fresh Air |
I used the following vent system from Vans:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1164084586-262-300&browse=heatvent&product=ventilation-components
VENT SV-COMBO X2
It was fairly cheap, and worked fine.
R/
Brandon
Degrees for working adults in as fast as 1 year. Bachelors, Masters, Associates. Top schools [quote][b]
Gig Giacona
Posted: Tue Nov 21, 2006 8:31 am Post subject: Re: Fresh Air |
That SV-1 NACA vent is pretty much exactly what Zenith shipped with my kit.
601XL Under Construction
Trainnut01(at)aol.com Guest
Posted: Wed Nov 22, 2006 3:55 pm Post subject: Fresh Air |
The vent system that you used is the same one that came with my RV kit. They were great in the summer, they will blow the chart out of your hand when they are open. In the winter they don't work so great. They won't close all the air off. I replaced the "eyeball" with machined aluminum vents I got from Affordable Panels. I like these. When they are closed they are firmly closed. No air flow at all. Downside-they were terribly expensive.
Carroll Jernigan
Posted: Wed Nov 22, 2006 9:53 pm Post subject: Fresh Air |
Carroll,
Did you seal the eyeball vents with silicon? I have not done it yet, but the documentation supplied with the system gave a pretty clear explanation on how to do it. Living in San Diego, I don't worry about it much...
VR/
Brandon
Posted: Thu Nov 23, 2006 4:20 am Post subject: Fresh Air |
Brandon
Yes they were sealed with silicone. But I couldn't get them to stay sealed. After a few weeks the silicone would flake off and would have to be re-applied. You are probably right about being in San Diego, but Tennessee in January with an OAT around 10 degrees or less it doesn't take much of an air leak to put goose bumps on your skin. I have a friend in the Chicago area who takes the hoses off of his NACA ducts in the winter and tapes them shut.
He says he may be the first person in history to use duct tape to tape ducts.
Carroll
amyvega2005(at)earthlink. Guest
Posted: Thu Nov 23, 2006 1:09 pm Post subject: Fresh Air |
VR and Carroll,
I have used Proseal, Silicone tends to dry7 out in the Florida heat and crack. In fact Proseal is the only thing holding the vent in place.
Juan
