kitfox555(at)sbcglobal.ne Guest
Posted: Sat Dec 30, 2006 8:59 am Post subject: new kitfox2 |
I'm new to kitfox , Just purchased a kitfox 2 and I was interested in making the rudder and the stab taller to help the yaw ? I'm still in the stage of building before the covering. What is the thoughts has anyone done this? Also is there anyone in North Cal near paradise that I can see there kitfox and ask questions about building? [quote][b]
lcfitt(at)sbcglobal.net Guest
Posted: Sat Dec 30, 2006 9:46 am Post subject: new kitfox2 |
Jerry,
I am in Cameron Park. Not too far from you as the crow flies. I have a
Model IV and would be happy to hook up with you. The models are different,
but I followed a couple of guys with Models I and II in my early building
and it was helpful then.
Lowell
eskflyer(at)lvcisp.com Guest
Posted: Sat Dec 30, 2006 9:57 am Post subject: new kitfox2 |
Jerry welcome to the most fun you ever experienced, The Kitfox.
I have a Kitfox 2 N718PD , I have almost 700 hours on her now . Never have ever had one single problem with crosswind or adverse Yaw problems on takeoff or landing or just flying . In my humble opinion there is no need to enlarge the Vertical stabilizer or rudder .
Fly safe fly low fly slow
John Perry
580-695-8778
eskflyer(at)lvcisp.com (eskflyer(at)lvcisp.com)
Kitfox2 N718PD
582 cbox 2:62-1
Ivo inflight 3 blade 68"
I'm new to kitfox , Just purchased a kitfox 2 and I was interested in making the rudder and the stab taller to help the yaw ? I'm still in the stage of building before the covering. What is the thoughts has anyone done this? Also is there anyone in North Cal near paradise that I can see there kitfox and ask questions about building? [b]
Float Flyr
Posted: Sat Dec 30, 2006 12:14 pm Post subject: new kitfox2 |
For more fun try floats!
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Sat Dec 30, 2006 1:48 pm Post subject: new kitfox2 |
I have a set of straight floats WAHOOOO just no fun putting on and off trailer at lake to go flying . Someone needs to reinvent the amphibs with the tundra tires so we can land with floats in the bush also . Maybe that is my next calling OFFROAD AMPHIBS
John Perry
DO NOT ARCHIVE
Float Flyr
Posted: Sat Dec 30, 2006 2:47 pm Post subject: new kitfox2 |
Build them so they can be retrofitted to Aerocet 1100s...PLEASE!!!
Noel [quote]
Kitfox III-A
Malcolmbru(at)aol.com Guest
Posted: Sat Dec 30, 2006 3:41 pm Post subject: new kitfox2 |
forget about it , dont worey, I land mine every time I fly and never had a problem mal
msm_9949(at)yahoo.com Guest
Posted: Sat Dec 30, 2006 10:27 pm Post subject: new kitfox2 |
Hi Jerry. Amen to what John says. The Model 2 is a sweet little airplane as designed. Just leave it alone and have fun!
john perry <eskflyer(at)lvcisp.com> wrote:
[quote] Jerry welcome to the most fun you ever experienced, The Kitfox.
John Perry
580-695-8778
Kitfox2 N718PD
582 cbox 2:62-1
jose_m_toro(at)yahoo.com Guest
Posted: Tue Jan 02, 2007 7:36 am Post subject: new kitfox2 |
The beauty of Model II is that it is light, can take off and land from very short fields, and has excellent cross wind handling as it!
Jose
Ex Kitfox II/582 (and missing it)
kitfoxmike
Posted: Tue Jan 02, 2007 11:02 am Post subject: Re: new kitfox2 |
Adverse yaw, what's that, oh! that's what makes the kitfox fun. Just build it and go fly it, after awhile you won't realize the airplane has the adverse yaw.
Michel
Posted: Thu Jan 04, 2007 12:15 pm Post subject: new kitfox2 |
On Jan 2, 2007, at 8:02 PM, kitfoxmike wrote:
| Quote: | Adverse yaw, what's that, oh! that's what makes the kitfox fun.
Gosh! Then I am not the only one to enjoy adverse yaw! I just love to
put my model 3 in a coordinated turn on one side, then to the other
side, using my feet to keep the ball in the center. I must have been a
horseman ... in a parallel universe!
Cheers,
Michel
rjdaugh
Posted: Thu Jan 04, 2007 12:54 pm Post subject: new kitfox2 |
I actually wish my Fox had MORE adverse yaw.
It is always fun to take a Cessna driver for a ride and let them fly to Fox
a bit. This is always a real easy way to pick out the tail dragger pilots
or glider pilots. It may take them a few turns to fine tune their foot
work, but at least they know what their feet are for.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Posted: Thu Jan 04, 2007 9:39 pm Post subject: new kitfox2 |
I haven't flown a -2, but here is an idea:
I know that some others have added a center stringer
and fillet to the front of the verticle stab for
looks. I think this would also help with the
stability as well as make it look better.
Gap filling to the rudder will help and adding ribs to
the verticle stab will help too. That flat sided stab
wanders more than an aerodynamic airfoil and you might
gain an mph or 2 as well.
None of these things will require a lot of weight or
changing to the basic plane.
Maybe someone can lend a pic of their top stringer and
fillet, or verticle stab ribs to assist?
Kurt S.
--- jerry evans <kitfox555(at)sbcglobal.net> wrote:
| Quote: | I'm new to kitfox , Just purchased a kitfox 2 and I
Lynn Matteson
Posted: Fri Jan 05, 2007 11:33 am Post subject: new kitfox2 |
I've got pictures of my vertical ribs, but the last time I tried to
post, the file was huge...could I send 'em your way, Kurt, and you
could post em? Each picture is about 56KB when I send via email. I've
got pics of several stages of the airfoiling process.
Lynn
On Jan 5, 2007, at 12:38 AM, kurt schrader wrote:
<smokey_bear_40220(at)yahoo.com>
Kurt S.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Fri Jan 05, 2007 1:53 pm Post subject: new kitfox2 |
Lynn I would love to see those pic new builder Jerry
Lynn Matteson <lynnmatt(at)jps.net> wrote: [quote]--> Kitfox-List message posted by: Lynn Matteson
Lynn
[quote] --> Kitfox-List message posted by: kurt schrader
Kurt S.
> Cal near paradise that I can see there kitfox [quote][b]
Posted: Fri Jan 05, 2007 8:37 pm Post subject: new kitfox2 |
Lynn and Michel,
My best contact for this is Michel, or Norski sailor
and computer hacker....
Michel. Can you take Lynn's pics, reduce them and
post them to the old Sportflight site?
I made my verticle stab ribs by taking the one bottom
rib to a copy machine and making a copy of it before
installing it. Then I used the % reduction function
on the copier to make the other ribs to size. Cut
them from hobby shop plywood and that was that.
Unfortunately I will not be home to help with this for
over a week. Michel! Can you help?
Kurt S. S-5
--- Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | I've got pictures of my vertical ribs, but the last
time I tried to
Kurt, and you
process.
Lynn
Michel
Posted: Sat Jan 06, 2007 12:48 am Post subject: new kitfox2 |
On Jan 6, 2007, at 5:36 AM, kurt schrader wrote:
| Quote: | Michel. Can you take Lynn's pics, reduce them and
Certainly, Sire!
Lynn, send them to me directly, thank you.
Michel
Jester to the court of one pope and two cardinals
do not archive (unless you are a list's sinner)
