dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Sat Jan 27, 2007 5:50 pm Post subject: Washer installation tool |
I know I have seen some photo's of a tool made out of a popsicle stick or tongue depresser that is made to help get washers installed on bolts for rod end installations and such. I cannot locate anything using the search feature. Anybody help with this?
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
ScooterF15
Posted: Sat Jan 27, 2007 6:01 pm Post subject: Washer installation tool |
I use fishing line that is threaded through everything to initially hold all the washers in place and in the proper order, then I use a 1/8" punch to get everything aligned. Then I remove the fishing line and push the punch out with the bolt. It's not all that easy every time, but that's how I did most of my rod end installations.
Jim
40134
In a message dated 1/27/2007 8:53:30 P.M. Eastern Standard Time, dmaib(at)mac.com writes:
| Quote: | --> RV10-List message posted by: "dmaib(at)mac.com" <dmaib(at)mac.com>
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=90930#90930
es Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> ======================
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
Tim Olson
Posted: Sat Jan 27, 2007 7:12 pm Post subject: Washer installation tool |
There's one here:
http://www.myrv10.com/tips/generaltips.html
dmaib(at)mac.com wrote:
David Maib
RV-10 #40559
LarryRosen
Posted: Sat Jan 27, 2007 8:00 pm Post subject: Washer installation tool |
I was given this suggestion, but have not used it my self.
Super glue the edge of the washer to a wire. Use the wire to hold the
washer in place. Insert the bolt and then pull the wire off the washer.
YMMV
Larry
David Maib
RV-10 #40559
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
dmaib@me.com
Posted: Sat Jan 27, 2007 8:57 pm Post subject: Washer installation tool |
Jim, Larry, and Tim
Thanks for all of the information.
David Maib
#40559
On Jan 27, 2007, at 8:00 PM, JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) wrote:
Jim
40134
In a message dated 1/27/2007 8:53:30 P.M. Eastern Standard Time, dmaib(at)mac.com (dmaib(at)mac.com) writes:
| Quote: | --> RV10-List message posted by: "dmaib(at)mac.com (dmaib(at)mac.com)" <dmaib(at)mac.com (dmaib(at)mac.com)>
David Maib
RV-10 #40559
RV-10 #40559
flysrv10(at)gmail.com Guest
Posted: Sun Jan 28, 2007 4:55 am Post subject: Washer installation tool |
Another easy way also is to use a masking tape to hold the washer in
place and pull the tape out once the washer is in place and the bolt
is inserted.
On Jan 27, 2007, at 10:59 PM, Larry Rosen wrote:
the washer in place. Insert the bolt and then pull the wire off
the washer.
YMMV
Larry
> David Maib
> RV-10 #40559
jdalton77(at)comcast.net Guest
Posted: Sun Jan 28, 2007 8:12 am Post subject: Washer installation tool |
I've been using these funny needlenose pliers I ran across - the end are curved down sharply enabling me to fit them into funny angles. Works for both washers and nuts.
[quote] --> RV10-List message posted by: Rob Kermanj
is inserted.
> --> RV10-List message posted by: Larry Rosen
> the washer.
> YMMV
> Larry
> dmaib(at)mac.com w rote:
>> David Maib
>> RV-10 #40559
&g t;
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Wed Jan 31, 2007 8:48 pm Post subject: Re: Washer installation tool |
David:
I used almost all of the ideas you've read about and they worked to varying degrees; they just took a little longer. In a fit of weakness, I bought those ridiculously priced washer wrenches and they're really sweet and work well. If you'd like to borrow them, let me know and I'll run 'em over to you.
Bob
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
dmaib@me.com
Posted: Fri Feb 02, 2007 1:11 am Post subject: Washer installation tool |
Bob,
Thank you. When it is time to put the control surfaces back on, we
will definitely take you up on your kind offer.
David
On Jan 31, 2007, at 10:48 PM, Bob Collins wrote:
<bcollinsrv7a(at)comcast.net>
David:
Bob
Bob Collins
St. Paul, Minn.
RV Builder's Hotline (free!)
http://rvhotline.expercraft.com
http://forums.matronics.com/viewtopic.php?p=92017#92017
RV-10 #40559
