		dmaib@me.com
  Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
				 Posted: Sat Jan 27, 2007 5:50 pm    Post subject: Washer installation tool |
				I know I have seen some photo's of a tool made out of a popsicle stick or tongue depresser that is made to help get washers installed on bolts for rod end installations and such. I cannot locate anything using the search feature. Anybody help with this?
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
		ScooterF15
				 Posted: Sat Jan 27, 2007 6:01 pm    Post subject: Washer installation tool |
				I use fishing line that is threaded through everything to initially  hold all the washers in place and in the proper order, then I use a 1/8"  punch to get everything aligned. Then I remove the fishing line and push the  punch out with the bolt. It's not all that easy every time, but that's how  I did most of my rod end installations.
  Jim
  40134
  In a message dated 1/27/2007 8:53:30 P.M. Eastern Standard Time,  dmaib(at)mac.com writes:
   	  | Quote: | 	 		  -->    RV10-List message posted by: "dmaib(at)mac.com" <dmaib(at)mac.com>
 David Maib
 RV-10    #40559
 Read this topic online    here:
 http://forums.matronics.com/viewtopic.php?p=90930#90930
   es  Day       -->                - NEW MATRONICS WEB FORUMS -
 bsp;    -->  ======================
  Jim "Scooter"  McGrew
 http://www.mit.edu/~jsmcgrew
		Tim Olson
				 Posted: Sat Jan 27, 2007 7:12 pm    Post subject: Washer installation tool |
				There's one here:
 http://www.myrv10.com/tips/generaltips.html
 dmaib(at)mac.com wrote:
  David Maib
  RV-10 #40559
		LarryRosen
				 Posted: Sat Jan 27, 2007 8:00 pm    Post subject: Washer installation tool |
				I was given this suggestion, but have not used it my self.
 Super glue the edge of the washer to a wire.  Use the wire to hold the
 washer in place.  Insert the bolt and then pull the wire off the washer.
 YMMV
 Larry
  David Maib
  RV-10 #40559
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		dmaib@me.com
				 Posted: Sat Jan 27, 2007 8:57 pm    Post subject: Washer installation tool |
				Jim, Larry, and Tim
 Thanks for all of the information.
 David Maib
 #40559
 On Jan 27, 2007, at 8:00 PM, JSMcGrew(at)aol.com (JSMcGrew(at)aol.com) wrote:
  Jim
  40134
  In a message dated 1/27/2007 8:53:30 P.M. Eastern Standard Time, dmaib(at)mac.com (dmaib(at)mac.com) writes:
   	  | Quote: | 	 		  -->   RV10-List message posted by: "dmaib(at)mac.com (dmaib(at)mac.com)" <dmaib(at)mac.com (dmaib(at)mac.com)>
 David Maib
 RV-10   #40559
RV-10 #40559
		flysrv10(at)gmail.com Guest
				 Posted: Sun Jan 28, 2007 4:55 am    Post subject: Washer installation tool |
				Another easy way also is to use a masking tape to hold the washer in
 place and pull the tape out once the washer is in place and the bolt
 is inserted.
 On Jan 27, 2007, at 10:59 PM, Larry Rosen wrote:
  the washer in place.  Insert the bolt and then pull the wire off
  the washer.
  YMMV
  Larry
 > David Maib
 > RV-10 #40559
		jdalton77(at)comcast.net Guest
				 Posted: Sun Jan 28, 2007 8:12 am    Post subject: Washer installation tool |
				I've been using these funny needlenose pliers I ran across - the end are curved down sharply enabling me to fit them into funny angles.  Works for both washers and nuts.
 [quote] --> RV10-List message posted by: Rob Kermanj
  is inserted.
  > --> RV10-List message posted by: Larry Rosen
  > the washer.
  > YMMV
  > Larry
  > dmaib(at)mac.com w  rote:
  >> David Maib
  >> RV-10 #40559
  &g  t;
		Bob Collins
  Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
				 Posted: Wed Jan 31, 2007 8:48 pm    Post subject: Re: Washer installation tool |
				David:
    I used almost all of the ideas you've read about and they worked to varying degrees; they just took a little longer. In a fit of weakness, I bought those ridiculously priced washer wrenches and they're really sweet and work well. If you'd like to borrow them, let me know and I'll run 'em over to you.
 Bob
  _________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
		dmaib@me.com
				 Posted: Fri Feb 02, 2007 1:11 am    Post subject: Washer installation tool |
				Bob,
 Thank you. When it is time to put the control surfaces back on,  we
 will definitely take you up on your kind offer.
 David
 On Jan 31, 2007, at 10:48 PM, Bob Collins wrote:
  <bcollinsrv7a(at)comcast.net>
 David:
 Bob
 Bob Collins
 St. Paul, Minn.
 RV Builder's Hotline (free!)
 http://rvhotline.expercraft.com
 http://forums.matronics.com/viewtopic.php?p=92017#92017
RV-10 #40559
