RV-10 Axle Extension Group Order - Reply by Wednesday p.m.
Goto page 1, 2  Next
Tim Olson
PostPosted: Sun Jan 28, 2007 4:44 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Good news, everyone...
Today I installed the axle extensions that my friend made from my
drawing and they worked out perfectly. I have some photos from
the install posted here:
http://www.myrv10.com/N104CD/upgrades/20070118/index.html#Installation_of_new_extensions
Now that I know they work, I'm going to do something stupid and
since some people found high machining costs, I'm going to coordinate
a group order for extensions that look like these. I had at least
2 quotes come back with costs significantly lower than what other people
were saying. My earlier drawing might actually be more expensive to
make than the final product drawing too. I'll have to re-quote it to
see if pricing will be any lower.
My present quote that I'd go on was: $17.75ea (at) quantity 40 and
$24.50ea (at) quantity 20. (20 pairs and 10 pairs respectively)
Now, what I'm going to do it this: If you want these extensions
for your plane, I'm only planning to have one run made up, so get them
now. Let me know by Wednesday night, and Thursday a.m. I'll order
them from the machining company and get the hardware on it's
way to me. They need to get the aluminum stock, so there will be
a small delay before they start making them.
You do not need to send payment right away...Yes, I know, that's
stupid, but I'm planning to write a check for well over $1000 to
cover the production, but only if the buyers are willing to commit
to paying for them.
What you'll get:
1 PAIR of Axle entensions, all drilled and tapped, 3-3/8" long so
they don't require the large flat washer. They should directly
replace the original part. You'll also get (3) AN5-6A bolts,
so you have one as a spare, for bolting them to the axle nut.
You'll also get (3) MS24693C298 screws for the outer ends, that
will be 1/4" longer than original so they don't back out and fall
off as easily (mine almost came out...use loctite!) And, I'm
going to send you (3) MS24665-292 cotter pins, and (3)
MS24665-362 cotter pins, so you have all of the hardware required
to attach them.
Your job: Drill your existing holes on the axle nuts out to 5/16"
and deburr (I deburred mine today because I miss all the deburring
so much Wink ) Then assemble the AN5 bolt/washer to the extension and
torque. Then, use a #40 drill through the guide hole and drill
out the hole and the bolt to #40. Pin them together with the small
cotter pins, install the axle nuts and pin with the large pins.
Then secure the fairing with the 1/4" stainless machine screw.
Since this is something I'm not doing for profit, I'm going to
make it easy on myself. They'll all be picked up at the same
time, and I'll throw them all into USPS Priority mail at the
same time. I'll split the costs of everything evenly, and round
any costs up to the next highest dollar. When all is said and
done, I'll tell you if the total with shipping is any higher than
my expectations...which would be between $45 and $55 per pair,
all complete to your door with the hardware.
One exception: Since this isn't for-profit in any way, I'm going
to make it easy on myself and limit it to the US continental 48
states only so I can use USPS Priority mail.
Again, I'll only be doing this group order one time, so if you want
them, now's the time. After this order, if for some reason I'm
crazy enough to do it again, I'd add on extra cost for the time, and
it might be harder to get a good list of people together to keep
the price down. If for some reason we can't get 10 people for
this order, I won't bother, but my gut feeling is that we'll probably
easily make the 20 pair (quantity 40) level. I just want to do this
because after installing them I know they worked well for me, and
it'll keep you all from spending a fortune on one-offs from your
local machinist. In the spirit of "no up front money" that
we have today, you can send your payment either via paypal
or by check after you get them. I know everyone will pay up, because
we're all nice people and if you don't, I'll tell the list on you. Wink
If you pay by paypal though, add a little to cover the fees that
they charge. Tips are not required, but will be accepted if you're
just so happy after getting them that you really want to. Wink
If the price for any reason looks like it'll be over $60, I will not
proceed without contacting everyone who got on the list first.
Email me at my email address if you want to get on the list.
flysrv10(at)gmail.com
PostPosted: Sun Jan 28, 2007 5:21 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Count me in and thanks for doing this. Nice process and organization.
Rob.
people
to paying for them.
What you'll get:
to attach them.
dmaib@me.com
PostPosted: Sun Jan 28, 2007 5:27 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Tim,
I will take a set. Thank you so much for all you do for this group of
builders. Fantastic!
David Maib
#40559
struggling with elevator trim (grrrrrr)
to paying for them.
What you'll get:
to attach them.
David Maib
RV-10 #40559
New Smyrna Beach, FL
rvbuilder(at)sausen.net
PostPosted: Sun Jan 28, 2007 5:32 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Tim, throw me on the list.
I would also like to add my services to this very nice offer. For our
brethren in OZ and NZ that may want to jump in on this, I will be
willing to act as a proxy for you on two conditions. First you have
been present and active on the list so I recognize you, and second I
reserve the right to limit the number of people I proxy this to.
This is only for Australia and New Zealand. If someone else wants to
handle the UK or another part of the world more power to them. Oceania
is enough for me. Smile So if you are in one of those two locations and
want a set let me know and I will ask Tim to add them to my order. You
will pay whatever I pay + the cost of shipping to your part of the world
and you can pay me via paypal also.
Of course this is assuming Tim doesn't have a problem with it.
Michael Sausen
-10 #352 Limbo
millstees(at)ameritech.ne
PostPosted: Sun Jan 28, 2007 5:52 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Tim:
I'll take a pair
Steve Mills
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
EFDsteve(at)aol.com
PostPosted: Sun Jan 28, 2007 6:07 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Thanks, Tim.
Please add me to the list for a pair of axle extensions.
Steve Weinstock
40230
In a message dated 1/28/2007 6:46:49 P.M. Central Standard Time, Tim(at)MyRV10.com writes:
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
to paying for them.
What you'll get:
to attach them.
acs(at)acspropeller.com.a
PostPosted: Sun Jan 28, 2007 6:45 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Michael and Tim,
I would like a set and thanks for your kind offer.
Please advise me offlist and I can arrange funds transfer to you.
John 40315
Do Not archive
DAVELEIKAM(at)wi.rr.com
PostPosted: Sun Jan 28, 2007 7:33 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Send me a pair if you have a slot left.
Dave Leikam
40496
S79 W16389 Woods Rd
Muskego, WI 53150
orchidman
PostPosted: Sun Jan 28, 2007 7:38 pm    Post subject: Re: RV-10 Axle Extension Group Order - Reply by Wednesday p. Reply with quote
Tim,
Please add me to the list. In no hurry. Wings should arrive in about 10 days.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
rene(at)felker.com
PostPosted: Sun Jan 28, 2007 8:10 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Tim, add me to the list. Thanks for doing it.
Rene'
801-721-6080
pierre(at)danieljofriel.c
PostPosted: Sun Jan 28, 2007 8:29 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Tim: I will take a set.
Pierre
Pierre Levy
Builder Number 40690
taildragon(at)msn.com
PostPosted: Sun Jan 28, 2007 9:03 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
Hi Tim,
I will take a set.
Roger
#40291
CJohnston(at)popsound.com
PostPosted: Sun Jan 28, 2007 9:29 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
I'm in!
cj
#40410
fuse
www.perfectlygoodairplane.net
VHMUM(at)bigpond.com
PostPosted: Sun Jan 28, 2007 11:44 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
I will take a set via Michael if that is ok.
Chris 388 Melbourne Australia
Hans-Dieter Aue
PostPosted: Mon Jan 29, 2007 3:38 am    Post subject: Re: RV-10 Axle Extension Group Order - Reply by Wednesday p. Reply with quote
Yes Tim,
add me to the list.
Since I'm located in Germany I will try to arrange a delivery spot in US. I will tell you a shipping address soon.
Thanks for doing this.
Hans-Dieter Aue
Germany
40424
N110GH (reserved)
Jim & Julie Wade
PostPosted: Mon Jan 29, 2007 5:40 am    Post subject: Re: RV-10 Axle Extension Group Order - Reply by Wednesday p. Reply with quote
Us Too!!! One set.
40383
N369JW
60Hrs
jwt(at)roadmapscoaching.c
PostPosted: Mon Jan 29, 2007 6:29 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Tim,
I will take a pair of extensions.
Thanks for taking the initiative to help us all out.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
FWF, engine, wiring
PostPosted: Mon Jan 29, 2007 6:31 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Thanks Chris, I added you to my list.
Just a reminder to anyone in AU or NZ that is ordering these through
me, make sure you tell me and not just Tim. If I don't know about you
when Tim and I compare lists it will get dropped if I can't contact you
before the order is submitted.
I am paying Tim on your behalf so he doesn't have the headaches and
then you will pay me after you have received it. Essentially Tim is
getting these for me and then I'm selling/shipping them to you. I'll
ship them out and email you with the final cost. No one will pay me
back until you receive them. As of right now I have the following:
John Dunne
Indran Chelvanayagam
Neil Colliver
Chris Darcy
Michael
Ray.R.Doerr(at)sprint.com
PostPosted: Mon Jan 29, 2007 6:43 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Thanks Tim, I will take one set for up to $60.
Thank You
Ray Doerr
CDNI Principal Engineer
Sprint PCS
16020 West 113th Street
Lenexa, KS 66219
Mailstop KSLNXK0101
(913) 859-1414 (Office)
(913) 226-0106 (Pcs)
(913) 859-1234 (Fax)
etandrews(at)optusnet.com
PostPosted: Mon Jan 29, 2007 11:48 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. Reply with quote
Michael
Can you please add me to the list for down under!
Evan Andrews 40379
Gladstone, Australia
Goto page 1, 2  Next
Page 1 of 2
