		Tim Olson
				 Posted: Sun Jan 28, 2007 4:44 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Good news, everyone...
 Today I installed the axle extensions that my friend made from my
 drawing and they worked out perfectly.  I have some photos from
 the install posted here:
 http://www.myrv10.com/N104CD/upgrades/20070118/index.html#Installation_of_new_extensions
 Now that I know they work, I'm going to do something stupid and
 since some people found high machining costs, I'm going to coordinate
 a group order for extensions that look like these.  I had at least
 2 quotes come back with costs significantly lower than what other people
 were saying.  My earlier drawing might actually be more expensive to
 make than the final product drawing too.  I'll have to re-quote it to
 see if pricing will be any lower.
 My present quote that I'd go on was:  $17.75ea (at) quantity 40 and
 $24.50ea (at) quantity 20. (20 pairs and 10 pairs respectively)
 Now, what I'm going to do it this:   If you want these extensions
 for your plane, I'm only planning to have one run made up, so get them
 now.  Let me know by Wednesday night, and Thursday a.m. I'll order
 them from the machining company and get the hardware on it's
 way to me.  They need to get the aluminum stock, so there will be
 a small delay before they start making them.
 You do not need to send payment right away...Yes, I know, that's
 stupid, but I'm planning to write a check for well over $1000 to
 cover the production, but only if the buyers are willing to commit
 to paying for them.
 What you'll get:
 1 PAIR of Axle entensions, all drilled and tapped, 3-3/8" long so
 they don't require the large flat washer.  They should directly
 replace the original part.  You'll also get (3) AN5-6A bolts,
 so you have one as a spare, for bolting them to the axle nut.
 You'll also get (3) MS24693C298 screws for the outer ends, that
 will be 1/4" longer than original so they don't back out and fall
 off as easily (mine almost came out...use loctite!)  And, I'm
 going to send you (3) MS24665-292 cotter pins, and (3)
 MS24665-362 cotter pins, so you have all of the hardware required
 to attach them.
 Your job:  Drill your existing holes on the axle nuts out to 5/16"
 and deburr (I deburred mine today because I miss all the deburring
 so much   )  Then assemble the AN5 bolt/washer to the extension and
 torque.  Then, use a #40 drill through the guide hole and drill
 out the hole and the bolt to #40.  Pin them together with the small
 cotter pins, install the axle nuts and pin with the large pins.
 Then secure the fairing with the 1/4" stainless machine screw.
 Since this is something I'm not doing for profit, I'm going to
 make it easy on myself.  They'll all be picked up at the same
 time, and I'll throw them all into USPS Priority mail at the
 same time.  I'll split the costs of everything evenly, and round
 any costs up to the next highest dollar.  When all is said and
 done, I'll tell you if the total with shipping is any higher than
 my expectations...which would be between $45 and $55 per pair,
 all complete to your door with the hardware.
 One exception:  Since this isn't for-profit in any way, I'm going
 to make it easy on myself and limit it to the US continental 48
 states only so I can use USPS Priority mail.
 Again, I'll only be doing this group order one time, so if you want
 them, now's the time.  After this order, if for some reason I'm
 crazy enough to do it again, I'd add on extra cost for the time, and
 it might be harder to get a good list of people together to keep
 the price down.  If for some reason we can't get 10 people for
 this order, I won't bother, but my gut feeling is that we'll probably
 easily make the 20 pair (quantity 40) level.  I just want to do this
 because after installing them I know they worked well for me, and
 it'll keep you all from spending a fortune on one-offs from your
 local machinist.  In the spirit of "no up front money" that
 we have today, you can send your payment either via paypal
 or by check after you get them.  I know everyone will pay up, because
 we're all nice people and if you don't, I'll tell the list on you.
 If you pay by paypal though, add a little to cover the fees that
 they charge.  Tips are not required, but will be accepted if you're
 just so happy after getting them that you really want to.
 If the price for any reason looks like it'll be over $60, I will not
 proceed without contacting everyone who got on the list first.
 Email me at my email address if you want to get on the list.
		flysrv10(at)gmail.com Guest
				 Posted: Sun Jan 28, 2007 5:21 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Count me in and thanks for doing this.  Nice process and organization.
 Rob.
 On Jan 28, 2007, at 7:41 PM, Tim Olson wrote:
  people
  to paying for them.
  What you'll get:
  to attach them.
		dmaib@me.com
  Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
				 Posted: Sun Jan 28, 2007 5:27 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Tim,
 I will take a set. Thank you so much for all you do for this group of
 builders. Fantastic!
 David Maib
 #40559
 struggling with elevator trim (grrrrrr)
 to paying for them.
 What you'll get:
 to attach them.
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
		rvbuilder(at)sausen.net Guest
				 Posted: Sun Jan 28, 2007 5:32 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Tim, throw me on the list.
   I would also like to add my services to this very nice offer.  For our
 brethren in OZ and NZ that may want to jump in on this, I will be
 willing to act as a proxy for you on two conditions.  First you have
 been present and active on the list so I recognize you, and second I
 reserve the right to limit the number of people I proxy this to.
   This is only for Australia and New Zealand.  If someone else wants to
 handle the UK or another part of the world more power to them.  Oceania
 is enough for me.    So if you are in one of those two locations and
 want a set let me know and I will ask Tim to add them to my order.  You
 will pay whatever I pay + the cost of shipping to your part of the world
 and you can pay me via paypal also.
   Of course this is assuming Tim doesn't have a problem with it.
 Michael Sausen
 -10 #352 Limbo
		millstees(at)ameritech.ne Guest
				 Posted: Sun Jan 28, 2007 5:52 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Tim:
 I'll take a pair
 Steve Mills
 RV-10 40486 Slow-build
 Naperville, Illinois
 finishing fuselage
		EFDsteve(at)aol.com Guest
				 Posted: Sun Jan 28, 2007 6:07 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Thanks, Tim.
  Please add me to the list for a pair of axle extensions.
  Steve Weinstock
  40230
  In a message dated 1/28/2007 6:46:49 P.M. Central Standard Time,  Tim(at)MyRV10.com writes:
   	  | Quote: | 	 		  -->    RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
 to paying for them.
 What    you'll get:
 to attach    them.
 Tim Olson - RV-10 N104CD -  Flying |
		acs(at)acspropeller.com.a Guest
				 Posted: Sun Jan 28, 2007 6:45 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Michael and Tim,
 I would like a set and thanks for your kind offer.
 Please advise me offlist and I can arrange funds transfer to you.
 John 40315
 Do Not archive
		DAVELEIKAM(at)wi.rr.com Guest
				 Posted: Sun Jan 28, 2007 7:33 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Send me a pair if you have a slot left.
 Dave Leikam
 40496
 S79 W16389 Woods Rd
 Muskego, WI  53150
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Sun Jan 28, 2007 7:38 pm    Post subject: Re: RV-10 Axle Extension Group Order - Reply by Wednesday p. |
				Tim,
 Please add me to the list.  In no hurry.  Wings should arrive in about 10 days.
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		rene(at)felker.com Guest
				 Posted: Sun Jan 28, 2007 8:10 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Tim, add me to the list.  Thanks for doing it.
 Rene'
 801-721-6080
		pierre(at)danieljofriel.c Guest
				 Posted: Sun Jan 28, 2007 8:29 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Tim:  I will take a set.
 Pierre
 Pierre Levy
 Builder Number 40690
		taildragon(at)msn.com Guest
				 Posted: Sun Jan 28, 2007 9:03 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->
  Hi Tim,
  I will take a set.
  Roger
  #40291
  [quote]   ---
		CJohnston(at)popsound.com Guest
				 Posted: Sun Jan 28, 2007 9:29 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				I'm in!
 cj
 #40410
 fuse
 www.perfectlygoodairplane.net
		VHMUM(at)bigpond.com Guest
				 Posted: Sun Jan 28, 2007 11:44 pm    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				I will take a set via Michael if that is ok.
 Chris 388 Melbourne Australia
		Hans-Dieter Aue
				 Posted: Mon Jan 29, 2007 3:38 am    Post subject: Re: RV-10 Axle Extension Group Order - Reply by Wednesday p. |
				Yes Tim,
 add me to the list.
 Since I'm located in Germany I will try to arrange a delivery spot in US. I will tell you a shipping address soon.
 Thanks for doing this.
 Hans-Dieter Aue
 Germany
 40424
 N110GH (reserved)
		Jim & Julie Wade
				 Posted: Mon Jan 29, 2007 5:40 am    Post subject: Re: RV-10 Axle Extension Group Order - Reply by Wednesday p. |
				Us Too!!! One set.
 40383
 N369JW
 60Hrs
		jwt(at)roadmapscoaching.c Guest
				 Posted: Mon Jan 29, 2007 6:29 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Tim,
 I will take a pair of extensions.
 Thanks for taking the initiative to help us all out.
 John Testement
 jwt(at)roadmapscoaching.com
 40321
 Richmond, VA
 FWF, engine, wiring
				 Posted: Mon Jan 29, 2007 6:31 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Thanks Chris, I added you to my list.
   Just a reminder to anyone in AU or NZ that is ordering these through
 me, make sure you tell me and not just Tim.  If I don't know about you
 when Tim and I compare lists it will get dropped if I can't contact you
 before the order is submitted.
   I am paying Tim on your behalf so he doesn't have the headaches and
 then you will pay me after you have received it.  Essentially Tim is
 getting these for me and then I'm selling/shipping them to you.  I'll
 ship them out and email you with the final cost.  No one will pay me
 back until you receive them.  As of right now I have the following:
 John Dunne
 Indran Chelvanayagam
 Neil Colliver
 Chris Darcy
 Michael
		Ray.R.Doerr(at)sprint.com Guest
				 Posted: Mon Jan 29, 2007 6:43 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Thanks Tim, I will take one set for up to $60.
 Thank You
 Ray Doerr
 CDNI Principal Engineer
 Sprint PCS
 16020 West 113th Street
 Lenexa, KS 66219
 Mailstop KSLNXK0101
 (913) 859-1414 (Office)
 (913) 226-0106 (Pcs)
 (913) 859-1234 (Fax)
		etandrews(at)optusnet.com Guest
				 Posted: Mon Jan 29, 2007 11:48 am    Post subject: RV-10 Axle Extension Group Order - Reply by Wednesday p.m. |
				Michael
 Can you please add me to the list for down under!
 Evan Andrews 40379
 Gladstone, Australia
